It is currently Fri Aug 15, 2025 1:08 am
 Post subject: A black acoustic guitar?
PostPosted: Sat Sep 17, 2016 4:14 pm
Hi
Someone has asked me to build them an acoustic which is great news but he wants it in his words "all in black"
Not discussed any details yet but bit concerned about making something that if he doesn't take for any reason I am stuck with.
Thought it best to get some advice on here before taking it any further
Questions:
is there a naturally dark wood set I could offer to use ?
What's the best way to change wood if I have to colour stain/spray?
PostPosted: Sat Sep 17, 2016 4:51 pm
First name: Brad
Last Name: Combs
Maybe Wenge for the back, sides and binding? No clue about the top though. Would look awesome with some of that ancient Sitka though I think.
These users thanked the author bcombs510 for the post: cablepuller1 (Sun Sep 18, 2016 2:03 am)
PostPosted: Sat Sep 17, 2016 4:53 pm
First name: Heath
Last Name: Blair
City: Visalia
If I were going to build a nearly all black guitar, I would probably use ebony back and sides and find a really dark set of sinker redwood for the top. I don't like paint or dyes, but that's just me. No judgement if you want to.
sweat the small stuff.
These users thanked the author Heath Blair for the post: cablepuller1 (Sun Sep 18, 2016 2:03 am)
PostPosted: Sat Sep 17, 2016 5:22 pm
First name: Braedyn
Last Name: Schultz
City: Calgary
State: Alberta
Zip/Postal Code: T2X 1N7
I know Charles Fox has built a few guitars with black tops.
I also found this one made by Tim Greenfield:
I'm not sure exactly how they dyed/stained the spruce, but I'm sure you can find out if you get in touch with them.
These users thanked the author Braedyn for the post: cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sat Sep 17, 2016 6:45 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I would ask Hesh. Take a look at the black guitar in his avatar. Killer!
Alex
These users thanked the author Alex Kleon for the post: cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sat Sep 17, 2016 7:06 pm
Black woods or just opaque black color? Because it would be easy enough to just spray black nitro and call it a day.
These users thanked the author jfmckenna for the post: cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sat Sep 17, 2016 7:28 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
You might want to look into the process of "ebonizing", which can achieve a very black (ebony-like) appearance with many hardwoods like mahogany, oak, walnut or acacia. I have recently been playing around with this as I want a black neck on my current build. I will be using a Tasmanian Blackwood neck blank and it can be made jet black after soaking in an ebonizing solution. The beauty of it is that you create truly “black wood”, to a depth of a milimeter or so, but the character of the timber (grain and pores) is still evident – unlike a painted surface.
The ebonizing technique is widely known in general woodworking circles, and there is lots of good instructional information on the web if you google the word "ebonizing". It involves preparing a solution of iron acetate (just soak some steel wool in a jar of vinegar for a week or two), and then using this to chemically alter the tannins in the wood, achieving a uniform dark appearance. It only works on timbers that have a high tannin content. You can intensify it by adding more tannin to the mix (strong black tea is a good source).
It won’t work on spruce (very little tannin), so you might have trouble making a black soundboard with this method. I don’t know if cedar or redwood, as alternative soundboard material, have enough tannin to work. You could experiment with some offcuts. If your customer is prepared to depart from the completely black concept, I agree with the suggestion that an ancient spruce top on an otherwise black guitar could look awesome.
You still have the problem that it is a black guitar, which is not a super-popular look. So if the customer doesn’t end up buying it you might have trouble moving it on. But surely some canny product placement on goth-fashion sites, or pitching to New Zealand rugby fans, might find a willing buyer? You could crack open a whole new luthier market niche.
These users thanked the author Mark Mc for the post (total 2): Pmaj7 (Sun Sep 18, 2016 1:33 pm) • cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sat Sep 17, 2016 9:42 pm
Hi Braedyn,
Being a good Canadian Brother, I'll gently correct you.....That would be Michael Greenfield, also a good Canadian Brother.
These users thanked the author Rod True for the post (total 2): Braedyn (Sun Sep 18, 2016 6:01 pm) • cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sat Sep 17, 2016 10:15 pm
Lots of black guitars are desirable to someone and my Black Tiger(s) that had black tops only were inspired by both the Fox Ergo and traditional 1930's L-OOs that could be at times black. The historical precedence is there.
Black lacquer or black finish of your choice and perhaps clear coats too depending on the finish. I never did painted backs and sides but I used a lot of ebony and when under finish it looks like black pl*stic.....
These users thanked the author Hesh for the post: cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sun Sep 18, 2016 12:14 am
I'm working on a black faced baritone. The sides and back are naturally colored rosewood. I'm using black lacquer for the top. If I were to do an all black guitar I might use maple or some other close grained wood under black lacquer.
If you don't get carried away on high priced woods (african blackwood , ebony , etc.) you won't have too much invested even if he backs out. Black guitars if well done (i.e. - flawless finish) look nice, and will find buyers.
These users thanked the author Clay S. for the post: cablepuller1 (Sun Sep 18, 2016 2:04 am)
PostPosted: Sun Sep 18, 2016 8:04 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
This is my 1st and only adventure with a black top with a Bloodwood back and sides. The customer wanted the black top, I used the dye from Stewmac in lacquer sprayed with an air brush then clear lacquer sprayed in my normal way. I think this would look good on Macassar ebony, Ziricote, African blackwood, or other real dark back and sides.
Fred Tellier
These users thanked the author Fred Tellier for the post: cablepuller1 (Sun Sep 18, 2016 8:05 am)
PostPosted: Sun Sep 18, 2016 1:01 pm
Nice Fred!!
PostPosted: Sun Sep 18, 2016 6:03 pm
First name: Braedyn
Last Name: Schultz
City: Calgary
State: Alberta
Rod True wrote:
Hi Braedyn,
Oh, of course! Darn this brain fog. Haha. Thanks for the correction! :)
PostPosted: Mon Sep 19, 2016 9:06 am
I have only made one black guitar (not an acoustic), but I can tell you I found it difficult to make the finish look reasonably good. Tiny flaws and irregularities are quite visible, much more so than on natural finishes.
These users thanked the author Arnt Rian for the post: cablepuller1 (Mon Sep 19, 2016 11:28 am)
PostPosted: Mon Sep 19, 2016 9:33 am
Gosh, I really want to build a black guitar now :)
So how do you prep the purflings for finishing or do you scrape it off after? Seems like if you taped it off it would create a visible ledge but I guess you could blend and melt that in with subsequent coats of clear lacquer.
These users thanked the author jfmckenna for the post: cablepuller1 (Mon Sep 19, 2016 11:28 am)
PostPosted: Mon Sep 19, 2016 10:55 am
City: Escondido
Zip/Postal Code: 92029
Here's a black one I made. For some reason the top didn't need any black tint.... laughing6-hehe
These users thanked the author rlrhett for the post: cablepuller1 (Mon Sep 19, 2016 11:28 am)
Users browsing this forum: Chris Pile and 16 guests
