It is currently Fri Aug 15, 2025 1:08 am
 Post subject: Binding Tape
PostPosted: Sat Aug 13, 2016 6:43 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I really got attached to the brown binding tape from Stew Mac. But I understand it was "replaced" and there were issues with the new one. Has this been resolved?
Edit: "Attached" pun not intended, but yet appreciated.
 Post subject: Re: Binding Tape
PostPosted: Sun Aug 14, 2016 3:54 pm
First name: Josh
I'm not sure about the new one; I switched to the filament tape when that happened and found I liked it better than the old brown stuff - stronger, more tack, yet still reasonable easy to get off and available to me locally. Bit harder to cut. Could be an option if you have reservations about the current offering from Stew Mac.
PostPosted: Sun Aug 14, 2016 6:53 pm
Last Name: Sollod
Is the Stew Mac tape different from the LMI tape?
www.swiftcreekguitars.com
PostPosted: Sun Aug 14, 2016 11:25 pm
Mike I squirreled away 2 - 3 rolls of the Sm brown tape before I quit building. I'm happy to send you a roll (free) if you want to PM me a mailing addy?
PostPosted: Mon Aug 15, 2016 5:50 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The steel industrial tape dispensers we use hold two or three rolls of tape, are heavy enough to stay put on carpeted or waxed maple bench tops, and easily handle the cutting tasks with a sharp serrated blade. All appear to be made by the same company and branded by the vendors - U-Line, In-Line, etc. We have one on each repair and building bench and a few more scattered around the shop with specialty adhesives like drafting tape and super low tack paper tape for protecting vintage or delicate finishes during work. U-Line has the best prices on new dispensers, with two and three roll dispensers at about $22 per, and sells the replacement cutter blades. Amazon also sells these same deluxe industrial tape dispensers, but at about twice the price.
http://www.uline.com/BL_7302/Multi-Roll ... 0dispenser
We have a few rolls of the old brown binding tape, but it is seldom used due to its tendency to tear too easily when any real tension is applied and for the adhesive to come off the backing and fouling the surface when heated for easier release. We use 18mm width Scotch brand 897 filament tape for binding, and pay about $3.60 per 60 yard roll in 12-packs from Amazon. Besides a stronger, more tear-resistant tape, the adhesive stays put if heated for ease of release on spruce. A good tape dispenser is a must for this tape - it is impossible to tear by hand and even the sharp edges on unprepped binding will not do the job.
https://www.amazon.com/gp/product/B0081 ... UTF8&psc=1
- Beth Brower
These users thanked the author Woodie G for the post: Mike OMelia (Sat Aug 27, 2016 7:41 pm)
PostPosted: Mon Aug 15, 2016 7:08 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I got some brown tap from Stewmac that was not a good as what they had been selling but the new orange tape they now supply seems to be good. I have joined a top and bound one guitar with it so far and it worked.
Fred
Fred Tellier
PostPosted: Wed Aug 17, 2016 6:51 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks all. Hesh, I'm not looking for more... at least I don't think so. I've got enough for a few more bodies. But I need to think about the future. I have been thinking about filament tape. May give that 897 stuff a try. I just bought a roll of 899 (expensive!!) because I think its the same stuff used to make pneumatic sanding rolls. Will let you know.
These users thanked the author Mike OMelia for the post: Hesh (Wed Aug 17, 2016 11:09 am)
PostPosted: Wed Aug 17, 2016 6:54 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Woodie, so you've been happy with filament? Are those dispensers heavy? (don't move around easily when one-handing the tape grab)??
Others using it... happy?
PostPosted: Wed Aug 17, 2016 8:58 am
First name: Willard
Last Name: Guthrie
City: Cumberland
The dispensers work well and don't move about when dispensing on either the usual waxed hardwood bench tops or on the carpet samples we use for cushioning - the dispensers are heavy gauge sheet steel screwed together with sheet metal screws and a few plastic pieces for holding the cutter and tape, so pretty heavy and stable at 4+ pounds for the triple roll and 3 pounds for the double roll dispensers.
We have several builders in the area using filament tape, but I believe there are some threads in the archives and over on MIMF with recommendations. One tape not mentioned yet on this thread is the green 3M lacquer-safe masking tape that have both very high tack and are fairly strong for a paper tape. We use that tape for some tasks, and have tried it in the past for binding duty, but like most crepe paper tapes, it needs to be doubled if going around a sharp edge or subject to a lot of tension.
- Beth Brower
PostPosted: Wed Aug 17, 2016 9:32 am
The 3M 2060 Green Tape, for hard to stick surfaces, is what I use. It is nearly exactly the same tape as the Scotch 401. Both have a rubber adhesive that releases very cleanly without tearing fibers out, and has a 25 lb. tear strength. I do round the edges of my binding to help with tearing. I tried some non 3M packing tape once but it doesn't stick. Need to try the good stuff, but felt I'd need a holder to tear it. I tear the green tape by hand.
PostPosted: Wed Aug 17, 2016 10:07 am
I use 3M 233+. If a little extra pressure is needed I double it up.
PostPosted: Wed Aug 17, 2016 10:12 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Available at auto supply stores for less $'s than Lee Valley Tools.
Alex
PostPosted: Tue Aug 23, 2016 5:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, I bought the tape dispenser from Uline, but after shipping it cost same as Amazon one. No biggee. Do love the heft of it. And the spacer bars. 897 tape on the right.
These users thanked the author Mike OMelia for the post: Pmaj7 (Sat Aug 27, 2016 12:00 am)
PostPosted: Tue Aug 23, 2016 9:14 pm
Last Name: Farmer
City: Durango
State: CO
On the subject of tape, I just bought some regular masking tape 1/4" wide for fret jobs and with shipping came out to something like $0.38 a roll on sale at findtape.com
https://www.findtape.com/JVCC-MT-02-Crepe-Paper-Masking-Tape/p534/?cid=22&idx=16&tid=23&info=Sale%2b%2526%2bOverstock%2bItems
These users thanked the author david farmer for the post (total 3): DannyV (Sat Aug 27, 2016 9:58 am) • Pmaj7 (Sat Aug 27, 2016 12:00 am) • Woodie G (Wed Aug 24, 2016 4:36 am)
PostPosted: Wed Aug 24, 2016 4:39 am
First name: Willard
Last Name: Guthrie
City: Cumberland
Thanks for the link, Mr. Farmer - I've been looking for both low tack and standard narrow-width crepe tapes for masking and it seems the common options are either very expensive hobby/modeler's tape in tiny quantities or 3M fine line tapes that do not work that well for the task. Much appreciated!
- Beth Brower
PostPosted: Fri Aug 26, 2016 8:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Wow. How did I ever get by without one of these dispensers? Note the tape guides. That's the upgrade model. I would not advise the model without guides. I have three different rolls of my fav tapes on it. This thing is heavy, so one handed operation is a given. I have been using the 897 as recommended here. Filament tape. Fair warning, not nearly as sticky as old SM tape. Had to adjust my technique for binding work. But I have found it to be every bit as effective once I figured it out. And, fiber rip-out is essentially zero on removal. No heat gun required to soften tape.
These users thanked the author Mike OMelia for the post: Pmaj7 (Fri Aug 26, 2016 11:59 pm)
PostPosted: Fri Aug 26, 2016 9:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm using the SM tape for initial hold for measuring and fitting. And end part holding while gluing. 897 for everything else. Use the blue tape for light hold where it would have been a waste to use SM tape.
PostPosted: Sat Aug 27, 2016 6:49 am
First name: Willard
Last Name: Guthrie
City: Cumberland
[:Y:]
I am glad you are pleased with the dispenser - they are a bargain compared to the cost of installing a third hand! We also use the blue 3M medium tack tape for positioning and fitting - easy to remove and strong enough to keep things in place.
- Beth Brower
These users thanked the author Woodie G for the post: Mike OMelia (Sat Aug 27, 2016 7:40 pm)
PostPosted: Sat Aug 27, 2016 1:02 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Here's the hi-tech tape dispenser I use when installing binding:
PostPosted: Sat Aug 27, 2016 4:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've used that system for quite a while. :)
PostPosted: Sat Aug 27, 2016 7:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
But seriously, once u get that 897 tape figured out, like it very much.
Users browsing this forum: Chris Pile and 16 guests
