It is currently Sat Aug 16, 2025 6:57 am
 Post subject: Supersoft 2 AND water?
PostPosted: Mon Aug 15, 2016 11:18 am
First name: George
City: Seattle
After wetting sides with Supersoft 2 and letting them dry, do you then re-wet the sides with water before bending? I've drilled down through miles of old threads, but can't figure out what people are doing during that part of the process. idunno
George :-)
PostPosted: Mon Aug 15, 2016 11:25 am
First name: Rob
Last Name: Roither
City: Williamsburg
Zip/Postal Code: 23188
I use a spray bottle and immediately rewet (not drench) both sides with water before they go on the hot pipe. Then rewet as necessary if the area being worked on gets too dry.
PostPosted: Mon Aug 15, 2016 12:21 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We do not directly re-wet the wood prior to bending because most of the woods we treat with SuperSoft II (e.g., figured mahogany, figured maple, curly ash, etc.) are better bent fairly dry to avoid fiber collapse and fractures. Instead, we use damp butcher paper on both sides of the wood to provide enough water to generate the steam needed for bending, but not enough water to saturate the fibers and cause collapse or tensile failure in tight bends.
- Beth Brower
PostPosted: Mon Aug 15, 2016 12:22 pm
Last Name: Beaver
City: Lake Forest
I do the same as Rob.
John at bluescreek posted his procedure on YouTube several years ago. I don't remember exactly what it was but I bet you can find it on youtube. It would be worth a look.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Aug 15, 2016 12:28 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I also do the same as Rob.
PostPosted: Mon Aug 15, 2016 12:51 pm
First name: George
City: Seattle
Thanks for the replies. Your input is appreciated.
George :-)
PostPosted: Mon Aug 15, 2016 4:56 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
There are a series of three videos on bending figured wood with SuperSoft 2 in the Fox bender.
https://www.youtube.com/watch?v=Q7vd9wGG4LM
https://www.youtube.com/watch?v=qhrHvfzfDLo
https://www.youtube.com/watch?v=ZjRDv9e6MFM
SuperSoft II helps - no fiber collapse and no springback on figured mahogany.
- Beth Brower
Users browsing this forum: Chris Ide, rbuddy and 15 guests
