It is currently Sat Aug 16, 2025 9:50 am
PostPosted: Tue Jul 19, 2016 3:07 pm
Finishing Indian Laurel with Enduro-Var.
Sprayed a seal coat of EV over epoxy pore fill and found these "eruptions" in the sides. They follow the grain, and appear in bookedmatched places on the sides.
Sanded level, sprayed with further 3 coats EV , and found as pictured after drying but not levelled.
Not as much as before, but still not good.
Could these be small pitch or resin pockets as I suspect?
Any suggestions of how to treat them/seal them off? (I would prefer not to use shellac if possible)
PostPosted: Tue Jul 19, 2016 3:42 pm
How absolutely odd. Looks terrible. Wish I had an answer for you.
These users thanked the author Chris Pile for the post: Colin North (Tue Jul 19, 2016 3:56 pm)
PostPosted: Tue Jul 19, 2016 4:14 pm
They are not all over the sides, only on a couple of places each side.
PostPosted: Tue Jul 19, 2016 4:20 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Are they located where you can see the inside surface where those spots are. Anything funky happening on the inside like being concave/sunken?
PostPosted: Tue Jul 19, 2016 4:28 pm
Difficult to be sure, but there was a split in the sides at or near where the longer area is, which was filled with CA before bending.
PostPosted: Tue Jul 19, 2016 6:41 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Could the epoxy grain fill have had some bubbles that were sanded through, allowing the WB EnduroVar to reach the wood, causing some grain raising?
Alex
These users thanked the author Alex Kleon for the post: Colin North (Wed Jul 20, 2016 4:29 am)
PostPosted: Wed Jul 20, 2016 4:22 am
I suppose anything is possible, I believe I only raised the grain on the top during prep.
It's getting some thin CA before levelling this time, see how it goes.
PostPosted: Wed Jul 20, 2016 6:24 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Looks like the natural oils welling up through the finish. Especially since you say it appears as a book-match on the other piece. While not as oily and problematic as CocoboloIndian Laurel does is a somewhat oily wood. Water based finishes seem to be more sensitive to this but these oils will cause problems in all types of finishes....
An isolation coat would have prevented this. I would keep filing with EV at this point....
Brian
These users thanked the author B. Howard for the post: Colin North (Wed Jul 20, 2016 6:44 am)
PostPosted: Wed Jul 20, 2016 7:15 am
Thanks.
Didn't know this, and there was no indications of oilyness when working the wood and I've had no problems with edges of FBs with EIR and ABW, both oily woods I believe.
Any recommendations for an isolating coat I might find in UK?
PostPosted: Thu Jul 21, 2016 6:28 am
Last Name: Howard
City: Magnolia
State: Delaware
A quick and cheap iso coat is thin CA. Wipe on a coat and it will lock down the oils. Beware the fumes though as they can be quite wicked when having that much CA off gassing....
Vinyl sealer can be used as well, apply two coats. Cut the first coat with 25% fast evap thinner. The lab guys all recommend this but I have had problems with it on the oiliest woods like Cocobolo
Not sure of what all is available on your side of the pond but Cardinal, ICA, Sherwin Williams all have isolators in their products catalog.
Brian
These users thanked the author B. Howard for the post (total 2): Colin North (Thu Jul 21, 2016 2:22 pm) • DannyV (Thu Jul 21, 2016 9:45 am)
