It is currently Sat Aug 16, 2025 6:55 am
PostPosted: Sun Jun 19, 2016 11:45 pm
Hi all. I've been googling for a "mill gauge card," and for the life of me, can't find anything.
Does anyone have a link to one of these, or something else I can use to measure finish film thickness?
Thanks [:Y:]
PostPosted: Mon Jun 20, 2016 12:30 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Try local cabinetmakers supply shops.
PostPosted: Mon Jun 20, 2016 1:28 am
Couple choices here, I use the trycomb https://www.gardco.com/pages/filmthickness/wf/nordson.cfm
Searching for "Wet Film Thickness Gauge" on ebay throws up some too.
PostPosted: Mon Jun 20, 2016 7:29 am
When all done, if you used acetate or similar in the soundhole, applied finish will flake off easily & you can mic it.
Milton, ON
PostPosted: Mon Jun 20, 2016 8:44 am
First name: Tom
Last Name: West
State: Nova Scotia
I also do it this way and suggest this is much more accurate . I may be all wet on the accuracy thing but it works for me.
Tom
PostPosted: Mon Jun 20, 2016 8:53 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
You should be able to find a wet film gauge at any quality paint supply store. If you order your finish, ask for one the next time you place an order.
Alex
These users thanked the author Alex Kleon for the post: pkdz (Mon Jun 20, 2016 9:40 am)
PostPosted: Mon Jun 20, 2016 9:10 am
Last Name: McDonald
You can have this, shoot me your address and I will throw it in an envelope.
PostPosted: Mon Jun 20, 2016 10:03 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
The wet mill gauge cards are to set up your spray gun. Spray a test card and test the film thickness before spraying the instrument. I use EM6000 wb lacquer and find it critical to spray the correct thickness 3-4 mils. Too thin and it will not flow out too thick and the product can have a blue cast.
http://www.thefinishingstore.com/wet-mil-gauge/
These users thanked the author johnparchem for the post: James Orr (Mon Jun 20, 2016 12:15 pm)
PostPosted: Mon Jun 20, 2016 10:07 am
First name: Tom
Last Name: West
State: Nova Scotia
John: Thanks for clearing that up for me. Quite obvious I did not understand the use of the wet mil gauge. Makes more sense now.
Tom
PostPosted: Mon Jun 20, 2016 12:15 pm
Thanks, guys! John hit he nail on the head. I'm interested in measuring the wet thickness of each coat.
PostPosted: Mon Jun 20, 2016 3:18 pm
There is also a way to measure the film thickness when dry - not on a flaked off pert, but it isn't cheap -
Like this one:
https://www.zoro.com/extech-coating-thi ... lsrc=aw.ds
PostPosted: Mon Jun 20, 2016 4:48 pm
First name: Tom
Last Name: West
State: Nova Scotia
Like this one:
Don: I may be wrong(Quite often I am) but I think that is eddy current and is generally used on metal sub-strate.
Tom
PostPosted: Mon Jun 20, 2016 8:38 pm
I use a micrometer (not a dial caliper) about a 1/2" in from the soundhole prior to spraying and then after every few coats once it's had a chance to dry for a while. I measure in the same spot everytime and I know exctly how much lacquer I've sprayed and what my average dry flim thickness per coat comes out to be.
PostPosted: Tue Jun 21, 2016 7:32 am
Tom
I believe that you're probably right for this one, but there is something out there that is used by a well-known builder that I know that works on a guitar. Might be laser based instead or something else. I'm afraid I was guilty of just posting something too quickly without reading the product description closely enough.
Users browsing this forum: Chris Ide, rbuddy and 20 guests
