It is currently Fri Aug 15, 2025 7:04 am
 Post subject: I've seen the light...
PostPosted: Sat Jun 04, 2016 6:21 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
No, I didn't go see Brother Cloephus.....
But I Have seen the light, The UV light! I have just finished setting up my new UV finish curing system. We are currently only using it for pore fill and base coat but I will be trying out some of the topcoats in another month or so.
There is a definite learning curve, this stuff is different from anything else I ever used and I've used it all from pumice & shellac and shellac to spayable polyesters. Should have made this leap years ago..... Completely green technology ( at least on my end...), no fumes, VOC's or HAP's. No cleaning spray equipment, no instantly clogged booth filters either. And efficient? My, yes! A quart of filler will do at least 50 guitars by the looks of it!
Brian
These users thanked the author B. Howard for the post (total 3): Durero (Mon Jun 06, 2016 11:58 pm) • Clinchriver (Sat Jun 04, 2016 12:07 pm) • pkdz (Sat Jun 04, 2016 11:17 am)
PostPosted: Sat Jun 04, 2016 7:25 am
Pictures of the system?
Ken Cierp
PostPosted: Sat Jun 04, 2016 7:50 am
Last Name: Colbert
City: Anacortes
Who's system did you settle on?
PostPosted: Sat Jun 04, 2016 9:54 am
Last Name: Howard
City: Magnolia
State: Delaware
Went with system to start out. http://www.uv3.com/products/mobile-handheld-uv/cure-buddy
Using isolator and UV gel filler from Cardinal.
Brian
These users thanked the author B. Howard for the post (total 2): Durero (Tue Jun 07, 2016 12:03 am) • Michaeldc (Sat Jun 04, 2016 1:16 pm)
PostPosted: Sat Jun 04, 2016 11:14 am
Seems as though the link and UV3 site are dead?
Fixed --- local problem windows DNS settings
Ken Cierp
PostPosted: Sat Jun 04, 2016 11:20 am
link worked just fine for me
These users thanked the author SteveSmith for the post: Clinchriver (Sat Jun 04, 2016 12:07 pm)
PostPosted: Sat Jun 04, 2016 11:32 am
Google Chrome Problem fixed --- windows DNS settings
Ken Cierp
PostPosted: Sat Jun 04, 2016 12:54 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Is this because the filler and base coat don't set up at all without the UV?
PostPosted: Sun Jun 05, 2016 6:16 am
Last Name: Howard
City: Magnolia
State: Delaware
The Isolation coat is very thin and does not surface load the filters like heavier vinyl sealers. But mainly because the filler isn't sprayed.....it is a wipe on type product. The sprayable peroxide cured polyesters like simtec are very thick and gel quickly thereby clogging paint arrestors almost instantly.
Brian
These users thanked the author B. Howard for the post: J De Rocher (Sun Jun 05, 2016 1:07 pm)
PostPosted: Sun Jun 05, 2016 7:52 am
Just wondering what sort of investment you're looking at - didn't dsee anything on the website.
PostPosted: Sun Jun 05, 2016 8:37 am
Last Name: Colbert
City: Anacortes
I'm also curious what the final number was. They say somewhere in the neighborhood of $2000 on the website.
PostPosted: Mon Jun 06, 2016 5:57 am
Last Name: Howard
City: Magnolia
State: Delaware
Yep right around $2000 for the lighting and another couple hundred for materials.
Brian
PostPosted: Mon Jun 06, 2016 4:38 pm
Since this curing technology has become popular for use in beauty salons (nail techs) -- the LED lights of the proper frequency are now readily available -- 50,000 hour life! which is much better than the CFL tubes. I am pretty happy with Zpoxy but the ultra fast dry of the UV cure filler is very intriguing -- I just may try and make a curing unit -- $2000 is out of the question for our shop since I only build for family these days.
Ken Cierp
PostPosted: Mon Jun 06, 2016 6:11 pm
I know of a couple of people selling their UV lamps. Contact me for more info.
PostPosted: Tue Jun 07, 2016 7:02 am
Last Name: Howard
City: Magnolia
State: Delaware
I doubt the lights they use at the nail salons are powerful enough to cure these materials.... This light is industrial. Throws a light much like an arc welder.
Brian
PostPosted: Tue Jun 07, 2016 7:14 am
Last Name: Colbert
City: Anacortes
Brian,
Have you tried pore filling wenge or paduak yet? Ive read that deeper pores can be problem due to the light not penetrating deep enough. I've also heard that uv cure finish can be a tone killer. I look forward to hearing more over the coming months.
Thanks for sharing, Michael
PostPosted: Tue Jun 07, 2016 8:56 am
The comment is in regard to UVA component availability --- if one has the wherewithal to use them a device of any power output and UVA light spectrum wave length range can be constructed.
Ken Cierp
PostPosted: Tue Jun 07, 2016 10:08 am
Quote:
" uv cure finish can be a tone killer"
Sounds like something that might said by those that can't afford the technology --- Negative Marketing
Ken Cierp
PostPosted: Tue Jun 07, 2016 10:16 am
Last Name: Colbert
City: Anacortes
Could be... Second hand info a the very least.
PostPosted: Tue Jun 07, 2016 1:16 pm
Last Name: Colbert
City: Anacortes
Robbie,
I sent you a PM regarding a used lights.
Thanks, Michael
PostPosted: Wed Jun 08, 2016 7:33 am
Last Name: Howard
City: Magnolia
State: Delaware
Michaeldc wrote:
Brian,
Deeper pores seem to need a third coat to fill level but I did not see any problems on the Ash test panel I ran and then cut up and ash has some of the worst grain to fill. Uncured has been a problem at times, usually because the product was put on too thick or wasn't cooked long enough. A good Isolante as an initial sealer will prevent pore bleed if some of the filler doesn't quite cook all the way.As for a tone killer? I highly doubt it. Taylor has been using the stuff for 20+ years and all the major makers are using this tech on at least some of their guitars.
Brian
These users thanked the author B. Howard for the post: Michaeldc (Wed Jun 08, 2016 9:12 am)
PostPosted: Thu Jun 09, 2016 7:45 pm
Last Name: Colbert
City: Anacortes
Brian,
I understand one is encouraged not to expose the filler to an ignition source. What safety gear are you using before cooking, and once cooked is the filler now benign with no offgassing?
Michael
PostPosted: Fri Jun 10, 2016 7:17 am
Last Name: Howard
City: Magnolia
State: Delaware
Michaeldc wrote:
Brian,
Michael
There are no fumes and no off-gassing even before curing. The product is 99% solids so it is completely without any solvents whatsoever in it. I really don't see much chance of ignition unless you drop a spoonful of the stuff on your cigar...... Vinyl gloves is about it for safety gear during the application.
Brian
These users thanked the author B. Howard for the post: Michaeldc (Fri Jun 10, 2016 7:34 am)
Users browsing this forum: Chris Ensor, doncaparker and 17 guests
