It is currently Fri Aug 15, 2025 6:31 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 23, 2016 8:06 pm
Last Name: Cox
Clinchriver wrote:
I'm on a binge to get all my lumber re-sawn, sanded, graded and shelved :mrgreen: .... Saved a lot of money and its nice to use wood you processed.
I started a similar binge, sawed about 10 sets and a pile of tops - and I had to stop and build a couple. I still need to get back after it. I just have a couple guitars in the way now.
On the "saved". Yeah ;) I "saved" a bunch too... bliss . And everybody knows you have to spend money to save money ;). oops_sign The problem is that I have probably 10 lifetimes worth of wood if I didn't buy another scrap. But I just bought 3 cedar posts yesterday oops_sign
PostPosted: Thu May 26, 2016 3:14 pm
I find resawing with the proper tools for the job to be pure pleasure. After struggling with a 1.25HP Craftsman saw for 15 years I'm finally putting this beast to work. Just last weekend cutting up old oak and pine boards from a barn. The speed and accuracy in which this saw cuts makes me giddy :D
PostPosted: Thu May 26, 2016 3:28 pm
Very Nice
PostPosted: Thu May 26, 2016 3:51 pm
Last Name: Cox
Wow. That thing is a hoss!
Well. All good things must come to an end... And last night so did my carbide band. It was a Morse carbide and held up very well... But it finally cracked and split in half last night.
Switched to a Bi-metal Lennox Diemaster 2.
Seems like a decent band but shows a tendency to self-feed.... And when it does, the cut gets quite rough and wobbly. We will see how she does.
PostPosted: Thu May 26, 2016 8:17 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
John, the diemaster is for metal work, though could be used on thin wood. For our purposes you need a band with deep gullets and ideally 1.5 - 3 tpi. The thicker your stock is, the more important this becomes. The waste material from the kerf needs a place to go. Once the gullets are full, the cutting action becomes a little unpredictable, not to mention the heat buildup.
I have found that releasing the tension on the band tends to increase longevity. I taped a note on the power switch to remind me.
JF, cant see your image, need tool pics!
PostPosted: Sat May 28, 2016 5:53 pm
State: Tennessee
JF No pic that I can see?
Well this is all thats left inside the shop............ and when milling lumber from logs that Jointer really comes in handy.
Sawed a pile of Honduran Mahogany, (back and sides) and Black Locust yesterday, (a few backs, lots of bridge plate stock) this should year some very nice backs.
PostPosted: Fri Jun 03, 2016 6:41 am
I have access to a bit of good quality spruce, and I have resawed quite a few sets for 'tonewood' over the years. I enjoy the work, not because there is so much money to save or make; I don't sell any, and good spruce isn't that expensive to begin with, but its nice to be able to work with local woods, and you learn a lot. The best sets are just as nice as the primo alpine stuff I have bought from German and Italian sellers, it is the same species after all (picea abies). I split everything from freshly cut logs, and cut it and store it in my shop. A giant vintage band saw and jointer is a bit help, of course. There is a LOT of scrap, but since the wood is free, the only cost is my time and some machine maintenance, plus I get a lot of kindling... ;-) It can also be a selling point for some customers, some folks like the idea of a strictly local instrument.
PostPosted: Fri Jun 03, 2016 7:27 pm
Clinch, not sure why you cannot see the pics, sorry, but those wedges sure look nice :)
Here's some pics of my resaw. I still don't 'get' Google photo's and they keep changing it so it annoys the helk out of me.
https://goo.gl/photos/PJC6ocn6BEVVzfM88
These users thanked the author jfmckenna for the post: Clinchriver (Sat Jun 04, 2016 5:44 am)
PostPosted: Sat Jun 11, 2016 1:32 pm
Last Name: Cox
Wow. That thing is a hoss.
With the stack of wood I have accumulated in hopes of resawing... I could probably do well with a saw like that. That looks like about a 2" wide band - which no doubt makes for a much more stable cut than my little 1/2" band.
PostPosted: Wed Jun 15, 2016 3:57 pm
^ that's a 3 inch blade. Once I get into the cut it's almost like I don't need the fence at all as the wide blade feels like it just holds the line. It's a pure joy using that machine :)
PostPosted: Thu Jun 16, 2016 9:14 am
City: Southwick, MA
I'm DIY everything if I can - woodworking skills are a must and resawing does take a little practice to get right - but having the control over how you slice up the stock is worth it. If I had limited tools or limited shop space, then buying sets would be a no brainer - but I'm fortunate enough to have a good sized shop with a lot of great investments in tooling over the years (Including a CNC that I also built myself).
And I enjoy the work!
Mitch
PostPosted: Thu Jun 16, 2016 12:12 pm
Last Name: Beaver
City: Lake Forest
I have run into to many pieces of nice wood to not venture into resawing
To me it's a wide carbide blade and good saw setup that make all the difference.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jun 22, 2016 4:26 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
what is the kerf on those 3" blades & are those saws still being mad?
Mike McNerney
PostPosted: Wed Jun 22, 2016 5:42 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
.023" kerf. I think this saw is not made anymore but you can usually find one used pretty easily. I love mine.
PostPosted: Wed Jun 22, 2016 9:19 pm
I used to have access to the big brother of that Hitachi saw. Still a 3" blade. I made some mistakes, no doubt, but I still have a really great stash of wood as a result. I wish I had sanded more of it, the same shop had a 48" belt sander that was extremely well tuned.
PostPosted: Thu Jun 23, 2016 3:58 pm
The band is .02x. I have a 3 inch Resaw King on mine. The advertised kerf is about .050, but it seems to be more like .060.
