It is currently Fri Aug 15, 2025 8:39 am
 Post subject: Smokin' ziricote
PostPosted: Tue May 24, 2016 3:43 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
I was cutting small pieces of ziricote for "patio stones" to be inlaid in a rosette. The wood actually started to smoke from the fret saw blade (honest, I wasn't sawing that fast).
Then I was putting the jointed ziricote back through the thickness sander, and after about 7 or 8 passes, it started to smoke too! Checked the sanding belt, it looked fine.
So today, I'm finally leveling the rosette, again with the sander, and after about 10 passes, the ziricote was HOT.
In every case with the sander, I was taking very light passes, trying to avoid gumming up the belt.
Anyone else ever run across this?
 Post subject: Re: Smokin' ziricote
PostPosted: Tue May 24, 2016 5:14 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Geez, I thought maybe I was missing something from back in my teen years, Steve! Is that why they call it Mexican crack wood? :D pizza :D
Sorry. Nothing intelligent to add, Steve.
Alex
These users thanked the author Alex Kleon for the post: JSDenvir (Tue May 24, 2016 5:20 pm)
PostPosted: Tue May 24, 2016 6:35 pm
Alex
Nothing intelligent here either but dang Alex, that made laugh laughing6-hehe
PostPosted: Wed May 25, 2016 2:59 am
+1!
PostPosted: Wed May 25, 2016 4:18 am
Nothing intelligent to add here either.... but Steve if you are going to be smoking the drapes at least have the decency to share???? :)
Hope all is well with ya too Bro!
These users thanked the author Hesh for the post: Ken Jones (Fri May 27, 2016 1:42 am)
PostPosted: Wed May 25, 2016 6:44 am
First name: Alex
Last Name: Kleon
City: Whitby
While enjoying an icy scotch and soda last night, I wondered if you had flooded the ziricote with CA glue, and if the heat from the sanding could have caused the CA to smoke.
I often ponder the mysteries of the universe after a (second or third) beverage. Usually, to no avail! :D
Alex
PostPosted: Wed May 25, 2016 10:59 am
Steve,
Haven't worked with ziricote a lot, only a couple of guitars and headstock veneers, but haven't had that problem.
PostPosted: Wed May 25, 2016 2:59 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Have had similar problems with Ipe. Predrilling is mandatory and the wood would smoke and occasionally boiling oil would appear while at the drill press. Went through dozens of counter sink bits that summer.
The bocote I currently have seems like it is doing what you you describe on the sander.
I think I will switch down to 60 grit.
PostPosted: Thu May 26, 2016 6:31 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Worst part about those smokes from dense hardwoods is that they seem to be poison. One breath of that stuff and I feel bad for days. Needless to say I try to use positive ventilation and/or slow down the tool enough to stop the smoke. The explanation I have heard is that trees make poison oils to stop bugs from eating the wood,
PostPosted: Thu May 26, 2016 8:31 pm
Last Name: Beaver
City: Lake Forest
That is interesting Steve.
I don't have a clue but I will be starting a Zircote build soon. I'll pay close attention.
Joe Beaver
Maker of Sawdust
PostPosted: Thu May 26, 2016 9:46 pm
First name: Fredrik
I had a similar experience with smoke and a gumming belt, but only in one particular piece of ziricote - another piece, cut from the same board, didn't give me any trouble
PostPosted: Fri May 27, 2016 11:53 pm
Last Name: Shanklin
City: Windsor
State: ON
Brian, Ipe is very hard wood. It is used for the floors of semi trailers because of the abuse it can take.
Bob
PostPosted: Sat May 28, 2016 7:04 pm
First name: Ringo
Depends on the piece... some dense ziricote with a lot of black can burn and gum things up. With sanding go fast and take very little off each pass... it takes forever but that's the way it works sometimes. Also feeding into a drum sander at an angle so the same width of sandpaper doesn't have to do all the work can help an awful lot.
Sharp edge tools are your friends for these woods... ideally using abrasives should be reserved for only the final finishing steps but that's not always practical.
Users browsing this forum: Bing [Bot], Glen H and 22 guests
