It is currently Fri Aug 15, 2025 3:45 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 13, 2016 1:04 pm
bcombs510 wrote:
Terence Kennedy wrote:
Looking better. I agree transitions are a little abrupt but I'd go with what you have, record all the specs, see how it turns out and tweak the next one accordingly.
As mentioned I'd tuck the upper X and UTB but feather the lower stuff to the edge of the linings.
Let us know how you like it.
Thanks, Terence! I have archived the specs. I'm thinking of adding the soundhole bracing as well, which shouldn't take but just a few minutes.
So that I'm 100% sure what we are talking about. In the pic below you can see both the top and bottom of the X brace. The red boxes I was planning to tuck into the lining. The green boxes go down to zero a bit before the edge of the soundboard. Look correct?
Thanks!
Brad
Yes that is what I was thinking.
These users thanked the author Terence Kennedy for the post: bcombs510 (Wed Apr 13, 2016 1:07 pm)
PostPosted: Wed Apr 13, 2016 1:09 pm
First name: Brad
Last Name: Combs
Cool. I'll add the soundhole bracing, sand things up and close the box! :)
PostPosted: Thu Apr 14, 2016 8:19 pm
First name: Jonny
Last Name: Fifield
meddlingfool wrote:
Most folk use a triangle shaped brace profile, not rectangular like that.
Is the reason for this(shape) to reduce mass but maintain strength ?
"Practice enough till the results aren't hopes but expectations" forum member Peter Havriluk
PostPosted: Fri Apr 15, 2016 9:48 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Yes, you can shed a great deal of the weight of the brace without sacrificing much stiffness.
Bryan Bear PMoMC
PostPosted: Wed Apr 27, 2016 10:32 am
First name: Brad
Last Name: Combs
Woodie G wrote:
One thing that was emphasized by the boss (emphasis as in "cut off all that bracing and start over.") was the need to keep the curves of the tapers and scallops smooth and moderate in terms of change in depth. A catenary-like curve - think suspension bridge - is a smooth curve that avoids 'elbows' in the stiffness curve. I think of it as that suspension bridge-like shape as opposed to the profile that looks like two widely separated ant hills on a flat stretch of ground.
I carved braces for a second top on another parlor I'm working on. I tried to think suspension bridge, I got closer but not quite there yet I think. :)
PostPosted: Wed Apr 27, 2016 11:01 am
First name: Freeman
Last Name: Keller
Brad, I'm not going to wade thru all the discussion up to this point but I just want to show you what I have done. I've built three guitars from the Antes plans (and yes the first one was braced backwards but it sounds OK). The last two were lutz spruce (0.110) over Brazilian and Mad rose, and they are incredible little guitars - very loud, punchy and fairly complex sounding (however they definitely have that "parlor" sound). Braces are 1/4 wide, tapered (not really scalloped) and look like this
Here is the first one, the braces look a lot like yours (except for the tone bar of course). It is Sitka over EIR so there are several differences besides just the bracing - everyone who has played them like the last two better
Yours look like they are way over braced, but then maybe mine will blow up LOL.
Btw, if you build the depth shown on the plans they will just barely fit in a TKL case, next time I will reduce the depth by maybe an 1/8 of an inch or so.
These users thanked the author Freeman for the post: bcombs510 (Wed Apr 27, 2016 11:03 am)
PostPosted: Wed Apr 27, 2016 11:05 am
First name: Brad
Last Name: Combs
Thanks, Freeman!
Is this the case you are talking about? http://www.tkl.com/site_item_details.ph ... uitar+Case
Thanks!
Brad
PostPosted: Wed Apr 27, 2016 11:17 am
First name: Freeman
Last Name: Keller
bcombs510 wrote:
Thanks, Freeman!
Thanks!
Brad
Pretty sure that is the one. The guy that I built the Braz guitar for has moved it into another case that he already had - he didn't like the way the lid of the TKL case was pushing on the top. I kept the Mad rose guitar for myself and I put a couple of paint cans in the case that were a little bit taller than the guitar, closed the lid and "coaxed" it into a slight dome. Taking an 1/8 or 1/4 off the sides would be a much better solution and I don't think would change the air volume appreciably.
Show off time
viewtopic.php?f=10101&t=46874
These users thanked the author Freeman for the post: bcombs510 (Wed Apr 27, 2016 11:19 am)
PostPosted: Wed Apr 27, 2016 2:04 pm
I have posted this here before but Cedar Creek does a custom case for my size 2's. It fits the Antes specs nicely and is a very nice case. I think they were charging me around $135 last time I ordered. I actually need more so we'll see if the price has gone up.
If you call Cedar Creek and ask for the parlor guitar case they make for Kennedy Guitars in Alexandria MN they should be able to fix you up.
These users thanked the author Terence Kennedy for the post: bcombs510 (Wed Apr 27, 2016 2:07 pm)
PostPosted: Wed Apr 27, 2016 2:07 pm
Looking better, the peaks at the end of the X are a little high. Mine are a little under 1/2"
These users thanked the author Terence Kennedy for the post: bcombs510 (Wed Apr 27, 2016 2:08 pm)
PostPosted: Wed Apr 27, 2016 7:21 pm
First name: Jan-Alexis
Last Name: Tremblay
City: Montreal
Here is mine. It's an old parlor I refurbished. It is braced for gut/nylon strings.
These users thanked the author Johny for the post: bcombs510 (Wed Apr 27, 2016 9:45 pm)
Users browsing this forum: Bing [Bot], Ken Lewis and 14 guests
