It is currently Fri Aug 15, 2025 12:18 am
 Post subject: My first bridge
PostPosted: Tue Apr 19, 2016 12:33 pm
Last Name: Fields
City: Granite Falls
Zip/Postal Code: 28630
A friend brought me a Gibson Hummingbird Pro that has never had a bridge and asked me to install one. Well, not being able to find one ready made that I was happy with, I decided to do what real luthiers do and make my own. It took me a while, as I spent a lot of time researching and practicing on scrap wood, but I thinks it's going to work. We'll see.
Mike Fields
 Post subject: Re: My first bridge
PostPosted: Tue Apr 19, 2016 1:09 pm
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
That's clean
PostPosted: Tue Apr 19, 2016 1:42 pm
VERY nice.
PostPosted: Tue Apr 19, 2016 2:48 pm
Well done!
PostPosted: Tue Apr 19, 2016 2:58 pm
IT looks pro to me.
PostPosted: Tue Apr 19, 2016 5:02 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Looks like you may have been a machinist at a time in your past!
PostPosted: Tue Apr 19, 2016 5:15 pm
First name: Brad
Last Name: Combs
Looks great!
PostPosted: Tue Apr 19, 2016 5:36 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Could have fooled me that it was your first! Looks like it's ready to go!
Alex
PostPosted: Tue Apr 19, 2016 11:24 pm
Last Name: Waszazak
City: Vancouver
State: Wasington
Zip/Postal Code: 98665
Nice work!
PostPosted: Thu Apr 21, 2016 9:03 am
Last Name: Fields
City: Granite Falls
Thanks for the encouragement, guys. We beginners need that occasionally. I don't have a woodworking nor machining background, but I am blessed with a very high mechanical aptitude. All my friends and family bring me their broken stuff to fix, so I do have a lot of experience making things work.
Mike Fields
PostPosted: Mon Apr 25, 2016 11:32 am
Last Name: Fields
City: Granite Falls
It's official . . . I don't know what I'm doing.
After gluing on the bridge and clamping it over-night, here's what I have. With a straightedge on the frets, it hits the front of the 3/8" tall bridge about 1/16" below the top of the bridge. Before gluing, it would lay just on top of the bridge. The bridge was flat on top, but now has a slight curve and yes, I did sand the bottom of the bridge to match the curve of the guitar top. Also, I don't remember the top having as much curve to it as it does now. But here's what really concerns me: with the neck straight, the fingerboard extension (beyond 14th fret) rises visibly. With a straightedge across all frets, there's a gap at the 12th fret of .006". I put a hygrometer inside the guitar and sealed the sound hole with tape. After a couple of hours, it read 53%. Any ideas, guys? Thanks.
Mike Fields
PostPosted: Mon Apr 25, 2016 12:52 pm
Last Name: Fields
City: Granite Falls
One thing that came to mind after my last post and studying the picture is that maybe I screwed down the wing portions of the clamping caul too tight. I wanted to make sure the wings wouldn't stick up, so I got them pretty snug. Maybe I bent the bridge?
Mike Fields
PostPosted: Mon Apr 25, 2016 1:35 pm
First name: Brad
Last Name: Combs
Was there a clamping caul between the bridge plate and the clamps? If not, would that cause things to flex? Just a guess, I use a caul but I don't know if not using one could cause this. :)
PostPosted: Mon Apr 25, 2016 1:49 pm
Last Name: Fields
City: Granite Falls
No, I'm afraid I didn't have a caul to use underneath the bridge plate, although I did tape a small block of wood to the center clamp and the other two have plastic feet 7/8" in diameter.
Mike Fields
These users thanked the author cs51762 for the post: bcombs510 (Mon Apr 25, 2016 1:49 pm)
PostPosted: Mon Apr 25, 2016 1:51 pm
First name: Brad
Last Name: Combs
Let's see what some of the more experienced folks have to say. I'm new to all of this as well.
PostPosted: Mon Apr 25, 2016 9:11 pm
Last Name: Fields
City: Granite Falls
Photobucket stinks. Here's the picture again.
Mike Fields
PostPosted: Mon Apr 25, 2016 9:40 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Just curious how thick the bridge is.
PostPosted: Tue Apr 26, 2016 7:58 am
Last Name: Fields
City: Granite Falls
3/8".
Mike Fields
PostPosted: Tue Apr 26, 2016 10:02 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Before you worry too much about the issues you have noticed, try stringing up the guitar. This will give you a much clearer picture of which problems you will have to figure out how to solve and which will turn out to be not much problem after all.
The fingerboard rising after the 14th fret is (sadly) quite normal and most acoustic guitar players don't seem to care. If the guitar is playable in the lower frets it would be better to let the guitar be strung up for ideally a few years before attacking this problem as all the wood on a new guitar takes time to warp to its final shape. Find out how annoying the high frets turn out to be by putting on strings and playing it. File (sand) the heck out of those high frets as temporary first aid while you ponder thinning the fretboard, or a neck reset.
Your bridge is a bit on the thick side, so if you find that the action is too high even when the saddle is barely above the wood, take off some of the wood. Or you might decide to take the bridge off and reglue it with a strong caul inside the guitar which keeps the clamps from bending the guitar top and bridge. But you can't know what is neccesary until you try playing the thing.
PostPosted: Tue Apr 26, 2016 8:16 pm
That is exactly what happened. The same thing happened to me the first time I used that clamp and did not have a stiff caul inside.
These users thanked the author Pmaj7 for the post: cs51762 (Thu Apr 28, 2016 7:28 pm)
PostPosted: Tue Apr 26, 2016 10:53 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I'm not a fan of this gizmo. Without a rigid inside caul, tightening the wing screws will distort the bridge (and top). Add a rigid caul, and over-tightening the wing screws will reduce or eliminate clamping pressure in the center of the bridge (where it matters most).
With experience, and a sense of touch, it should work just fine. But three clamps (center, wing, wing), and a caul is nearly fool proof.
These users thanked the author Eric Reid for the post (total 2): TimAllen (Mon Aug 22, 2016 6:25 pm) • cs51762 (Thu Apr 28, 2016 7:28 pm)
PostPosted: Wed Apr 27, 2016 7:14 pm
I agree, you need a VERY rigid clamp in the center to prevent the wing clamps from relieving pressure in the center with that device. Something like a deep throat welding c-clamp. I had the clamp shown and it was not rigid enough. I tried it on a few guitars but abandoned it quickly going back to individual clamps in the center and wings. A fitted caul is mandatory I would think.
Looks like you may learn the art of bridge removal, that is not a bad thing at all and it is a beautiful bridge. BTW how deep is the saddle slot? It looks a little shallow in the picture.
These users thanked the author Terence Kennedy for the post: cs51762 (Thu Apr 28, 2016 7:28 pm)
PostPosted: Thu Apr 28, 2016 7:27 pm
Last Name: Fields
City: Granite Falls
[quote=BTW how deep is the saddle slot? It looks a little shallow in the picture.[/quote]
7/32".
Mike Fields
PostPosted: Thu Apr 28, 2016 10:29 pm
7/32".[/quote]
That's perfect.
PostPosted: Fri Apr 29, 2016 4:43 am
I agree with Terrence and Eric above, I also abandoned the SM Bridge Clamping Caul and went back to 3 normal clamps, after a couple of mishaps. I'm sure it can work beautifully with the right inside caul etc, but I prefer 3 Klemmensias, much more fool proof (a good idea in my case). I use a wooden, kerfed inside caul, it will conform to the any curvature of the bridge / top with no added stress.
These users thanked the author Arnt Rian for the post (total 2): TimAllen (Mon Aug 22, 2016 6:26 pm) • cs51762 (Fri Apr 29, 2016 8:17 am)
Users browsing this forum: Bing [Bot], J De Rocher and 8 guests
