It is currently Fri Aug 15, 2025 10:15 am
PostPosted: Wed Apr 13, 2016 10:07 am
Hi
Being fairly new I am struggling to figure this one out
I have om plans which I am following but I am using a slightly longer scale length (25.5") to the plan
Now is it just simply a case of moving down the bridge plate a bit or do I need to move the x bracing and what about moving the soundhole?
PostPosted: Wed Apr 13, 2016 10:55 am
The plans likely are based on an actual 25.4" scale length (.05" variance bridge placement)-- so I'd do nothing -- but either of the things you mention could also be done. Or make the bridge plate wider.
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Wed Apr 13, 2016 11:07 am)
PostPosted: Wed Apr 13, 2016 12:48 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What Ken said. You are looking at a scale that is only going to be 0.1" longer. More than half that will be on the neck side of the scale (0-14th fret). I wouldn't bother adjusting anything for a 50th of an inch. You are going to locate the bridge/saddle based on the frets anyway; that small of a variation will not cause the bridge wings to miss the X or bridge pins to miss the bridge-plate.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: cablepuller1 (Wed Apr 13, 2016 12:50 pm)
PostPosted: Wed Apr 13, 2016 1:22 pm
First name: Tom
Last Name: West
State: Nova Scotia
Bryan: Just to be picky.........think that is a 20th of an inch.
Tom
These users thanked the author Tom West for the post: Bryan Bear (Wed Apr 13, 2016 1:52 pm)
PostPosted: Wed Apr 13, 2016 1:54 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Tom
Ha! Right you are. oops_sign Still, I wouldn't adjust anything (other than my feeble brain) :D
Bryan Bear PMoMC
