It is currently Sat Aug 16, 2025 5:56 am
 Post subject: Heat blanket on eBay?
PostPosted: Fri Mar 25, 2016 9:18 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
I'm starting my 2nd guitar build soon. The first one I bent my sides with a pipe and I want try a side bending machine for the next one. I found a 6 x 36 1200watt heat blanket that comes with a controller that ranges from 0 to 200 degrees Celsius. Will that work? It's only $90
PostPosted: Fri Mar 25, 2016 10:57 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
It would for my purposes as long as it heats up quickly. You don't want to be waiting all day to bend. My max. temp when I'm bending is 375*F. 200* C = approx 392*F
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Sat Mar 26, 2016 1:18 am
Last Name: Beaver
City: Lake Forest
It should be fine, especially at that price! Just make sure it is the correct voltage. I would guess you want 120V
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 26, 2016 7:18 am
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Yeah it's 120v. I was going to get a surface temp gauge also and should I do 1 or 2 slats and what kind and thickness?
PostPosted: Sat Mar 26, 2016 8:56 am
First name: Tim
Last Name: Benware
City: Creedmoor
Folks like to different things when bending. My sandwich is: slat, brown paper, wood, brown paper, slat, blanket. I spritz my wood enough to keep it from scorching. Bending goes: 220*F lower bout, 270* upper bout, 300* waist, take it up to 375*, set my controller to variable (I use a router controller to vary my heat) and gradually over 12-15 minutes bring the temp down to 220*. Turn everything off and let it cool to room temp before I remove the side.
Edit: I use a fox style bender
Tim Benware
Creedmoor, NC
PostPosted: Tue Mar 29, 2016 6:47 am
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Hopefully it is the Keenovo brand one. Their biggest market is for skateboard bending. They are good quality, better manufactured than lmi. Mine gets to temp in 2 minutes.
They have 2 controllers, one uses a thermal switch with rotary knob, the other is digital. The digital one uses a sensor in the heater, so is more tightly controlled.
The version with rotary control has a bimetallic heat control switch, so it is not sensing the blanket temperature. Still better control than a heated pipe
PostPosted: Tue Mar 29, 2016 9:02 am
First name: Brad
Last Name: Combs
+1
I use the rotary knob type in the uke side bender I built. I use the digital one on my purchased side bender that the original blanket failed on it. Works great!
PostPosted: Tue Mar 29, 2016 8:34 pm
+1 on Keenovo with digital controller. Bought one a few months ago.
Heats fast and heat control is very accurate. The price is right.
Brent
PostPosted: Wed Mar 30, 2016 7:49 am
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
What size should I get I want to do some cutaways to so should I get 6 by 36?
PostPosted: Thu Mar 31, 2016 12:46 am
Last Name: Beaver
City: Lake Forest
You will need the 6"x 36" for side bending. You can also use a 6"x 6" for waists and a 6 x 12 for cutaways.
Joe Beaver
Maker of Sawdust
