It is currently Sun Aug 17, 2025 11:44 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Mar 11, 2016 6:41 pm
caribou wrote:
I use three since two years for resawing mostly ebony and rosewood, I made something about 30-40 acoustic sets, 70 fingerboards, 70 solid body tops and of course a big bunch of various little works.
Did you cut all that with 1 blade or 3?
PostPosted: Fri Mar 11, 2016 6:49 pm
Ken McKay wrote:
Good to know. I have three of the RK but use meat blades mostly.
I've heard this b4. Can you really resaw with them? I saw some for about $10. I guess if you could get more than 10 slices off a rosewood block, you would be ahead of the RK.
PostPosted: Fri Mar 11, 2016 7:14 pm
First name: Franck
Last Name: Chérubin
With 3 blades, When one is dirty (by resins) I put another one waiting to have the 3 to clean up. But at this day all of the three blades are still working without resharpening (not as well as the first day of course, but it works).
http://www.cherubin-luthier.fr
https://www.facebook.com/FranckCherubinLuthier
PostPosted: Fri Mar 11, 2016 8:36 pm
Meat blade on my Hitachi resaw. Mahogany and adi.
I can't really say what would be better for a person doing it day in and day out. But for me I switch out blades all the time. And even though I have the 2 inch blades and the rk blade The three quarter-inch meat cutting blade is easy to install and I can leave it on and get some even curved cuts with it.
Ken
PostPosted: Fri Mar 11, 2016 8:38 pm
Here's my saw
I forgot to say an important point. With the meat cutting blade I don't have to change the guides. There are special guides for the R king and the 2 inch blade. But the guide for narrow blades works well with the 3/4 inch meat blade. Plus the curve is very thin 0.022 inch
Ken
These users thanked the author Ken McKay for the post: Durero (Fri Mar 11, 2016 11:55 pm)
PostPosted: Sun Mar 13, 2016 7:41 am
Last Name: Colbert
City: Anacortes
I noticed that the gullets on my RK seem to load up, stopping the material. As soon as they clear, alway we go again as if like new. At least that's the only explanation I can come up with. I'm wondering if inadequate dust collection could be part of the problem.
I look forward to trying the Lennox CT.
M
PostPosted: Sun Mar 13, 2016 1:23 pm
In our case, we have a 5hp oneida on about an 8' duct run, so I sure hope that's not the problem..
PostPosted: Sun Mar 13, 2016 11:59 pm
First name: Ringo
meddlingfool wrote:
Meat blades?
Well, there is still the possibility that better setup of the saw might help.
When I sawed my bubinga side billets though, it literally pulled the wood down so hard that it chattered hard enough to turn the throat plate irreversibly concave. Not just a little bit either.
Sometime I'll start a new thread on getting it set up exactly right...
Hmm, that sounds like it might be not enough tension on the blade. Did it feel like the wood was being pulled into the blade at all?
PostPosted: Mon Mar 14, 2016 1:53 am
It's quite strange. It's happened on multiple billets aside from the bubinga, including walnut and mahogany. Basically, I'll push and nothing will happen, then it'll cut 3-4" in a blink of an eye, gang up, stop moving through/bounce...it's a bit disconcerting to say the least.
The blade seems very tight...
PostPosted: Mon Mar 14, 2016 9:23 pm
Check the thrust bearing clearance behind the blade. If the gap is too much, it can do that. About the thickness of a piece of paper is about right.
Grant
And, yes, ++++ on the Woodmaster CT and Spectrum Supply [:Y:]
PostPosted: Mon Mar 14, 2016 10:08 pm
I use a Canadian tire bill...
PostPosted: Thu Mar 17, 2016 10:04 am
Just don't use a Canadian dollar. Might be a little thin.
Sent from my SM-T350 using Tapatalk
These users thanked the author Pmaj7 for the post: Durero (Thu Mar 17, 2016 10:45 pm)
PostPosted: Thu Mar 17, 2016 11:16 am
Ha ha! Rub it in...
These users thanked the author meddlingfool for the post: Pmaj7 (Fri Mar 18, 2016 4:09 pm)
PostPosted: Thu Mar 17, 2016 1:15 pm
First name: David
Last Name: Falkner
City: Bossier City
State: LA
Zip/Postal Code: 71111
Bobc wrote:
Looks like it's cutting fine for you David. No good for us. We cut too many sets. :D
And I have been the recipient of some of those great sets, Bob! I think I bought about 6 sets from you last year so I can attest to how well your setup works. I hope to get to build a few guitars from some of those sets this year.
Thanks!
David
David
David Falkner - Woodworking YouTube channel and Instagram
Romans 3:23
PostPosted: Thu Mar 17, 2016 8:28 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Bobc wrote:
Mike O'Melia wrote:
Bobc wrote:
Bob, could you make a recomendation in blade width and TPI?
I'm also interested in a 3/8" blade. My wheels are 18"
I realize that's where u get them. I was looking for blade width and TPI you think would work on an 18" jet, 3hp motor
PostPosted: Wed Mar 23, 2016 10:51 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I got a chance to talk with Bob on the phone. For resaw, he uses the Woodmaster CT. On my saw, (Jet 18", 137" blade), that would cost about $115. For general purpose cutting (use of a 3/8" blade), he suggested the Trimaster. The only selection was 0.032" kerf, 3 TPI. This blade rings in at $224.
Can anyone explain this to me? Seems high for a small blade. Is it worth it? OR should I consider something else?
PostPosted: Wed Mar 23, 2016 11:13 am
Mike I forgot how much those Tri Masters cost. Definitely not worth it for your use. Other options are the Bi-Metal blades and or the carbon steel blades. Just keep in mind... more TPI = smoother but slower cut less TPI = rougher but faster cut.
We use a 6 TPI x 1/4" carbon steel for rough cutting neck blanks. The Bi-Metal blades are in the $50-$75 range and last a long time.
PostPosted: Wed Mar 23, 2016 6:13 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ah. Much better. I assume Lenox? I'll look at those. I do want higher TPI than 3. As I said, mostly used for brace wood cutting, back and top and sides cutting. And miscellaneous stuff. Andy does my necks on CNC, so no need there.
PostPosted: Wed Mar 23, 2016 6:56 pm
First name: John "jd"
City: Santa Barbara
Mike,
Lenox Diemaster 3/8 10/14 TPI is a great general purpose blade if you can stand slower feed rates. Lasts much longer than Carbon and cost is not so dear as carbide.
If it is just thin plates and Spruce you want to cut, carbon steel is a pretty good choice
-jd
PostPosted: Wed Mar 23, 2016 8:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you. I'll check that out. Feed rate is not an issue. Clean cut is. Long lasting is too.
PostPosted: Fri Mar 25, 2016 11:25 am
First name: Aaron
If those three are your priorities, you want the CT with lower TPI. If feed rate is an issue, with clean cut being a concession, then the Woodmaster B (bi-metal) is a beast. I use this now for dimensioning down lumber, and the CT for resawing. Don't read TOO much into that, until I got the CT, the B was my end game blade, better than the 3" Stellite on the Hitachi.
I have a strange deja vu feeling I posted this here, but anyway, here's a CT in action. Again, slower than a B, but I have time. Not sure how to embed the vid.
https://m.youtube.com/watch?v=HEPCP1IxRBw
PostPosted: Fri Mar 25, 2016 7:00 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, for resaw, I'm getting the wood master ct, 1" blade, 1.3 TPI. I don't resaw hardwood billets for back and side sets, but I do a bit of other hardwood resaw. The 3/8" blade to me is an all-purpose utility blade. Prolly go bimetal.
Users browsing this forum: No registered users and 41 guests
