It is currently Fri Aug 15, 2025 11:34 pm
PostPosted: Tue Mar 08, 2016 6:49 pm
Does anyone know if the abnd on the Woodmaster is thin enough to be used on a 14" bandsaw?
Anyone doing so?
PostPosted: Tue Mar 08, 2016 7:55 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The band on the Woodmaster CT 1" is .035", so pretty heavy. Have you looked at a 1/2" Trimaster? Band is .025" on the 1/2" x 3 tpi blade, and apparently we ran these on 14" Delta and Rikon saws with long term success resawing anigre, cocobolo, and other denser and more abrasive woods.
- Beth Brower
PostPosted: Tue Mar 08, 2016 10:42 pm
Thanks...
PostPosted: Sun Mar 13, 2016 9:16 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I use them on a 16" resaw without problems, but most any other 0.035" steel blade will eventually fatigue. With that in mind, I would be dubious about using one on a 14" saw. Blade fatigue and inadequate tensioning are the concerns. In addition to the 1/2" Trimaster, you may consider a 3/4" steel blade with 3 TPI. I used these Timber Wolf blades for many years, and although they do not perform like carbide on dense hardwoods, they are less than 1/4 the cost.
http://timberwolfblades.com/proddetail.php?prod=3403AS
PostPosted: Sun Mar 13, 2016 9:48 pm
Thanks John!
PostPosted: Mon Mar 14, 2016 8:15 am
First name: Danny
Last Name: Vincent
I've had one break on a 16" saw. Likely due to fatigue and it didn't have all that many hours. Unfortunately 1" is as small as they come. I would consider a Trimaster.
