It is currently Fri Aug 15, 2025 5:49 pm
PostPosted: Sat Mar 05, 2016 12:05 am
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
I was sharpening a scraper and had some lubricant oil on my fingers. I forgot and touched the guitar now the back has a few spots with oil in the wood. How should I go about removing it?
PostPosted: Sat Mar 05, 2016 12:35 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Naphtha.
PostPosted: Sat Mar 05, 2016 7:50 am
I've found out about "K2R" many years ago when I built and flew gas powered model airplanes.
Its a spray on product that dries and turn into a white power that you dust or vacuum off. In process of drying it absorbs the oil, kinda suck it out of the wood fibers rather than deluting the oil with a solvent and spreading it out over a larger area.
http://www.truevalue.com/product/5-oz-S ... /44035.uts
Ken Cierp
PostPosted: Sat Mar 05, 2016 8:56 am
Dish washing liquid. Then rinse with water.
PostPosted: Sat Mar 05, 2016 11:21 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I like to use nose grease. Yeap, just rub the skin on top of your nose with you thumb and index finger and wipe on the scraper, or put on a plane sole and you'll notice a big difference.
PostPosted: Mon Mar 07, 2016 3:48 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I absentmindedly set an unfinished body on a surface treated with mineral oil. A few days later I went back down to the shop and found the stain. The oil was even showing through on the other side. The advice I got was to use naptha. It took about three liberal applications to remove all traces of the oil. No finish (shellac) issues either.
Bryan Bear PMoMC
PostPosted: Fri Mar 11, 2016 12:09 am
First name: Mark
City: Concord
If the Naptha doesn't work or you can't get it where you live you may want to try Corn Starch or finely ground kitty litter. Leave it on for a day or so and it will absorb the oil. +1 on the nose grease. It's what I've used for a long time.
Users browsing this forum: doncaparker, Michaeldc, Mike Thomas, rbuddy and 10 guests
