It is currently Sat Aug 16, 2025 6:48 am
PostPosted: Sun Feb 21, 2016 4:12 am
Hi
Received my order today from UK supplier but not very happy with it and wanted your opinions on it
The back - has a split on one side (in photo) would you glue this or send it back
The spruce top - has big chunks out of the top end of board.. I can move template down to avoid
The top and back wood wants to curl up -i left it on a table and its starting to distort after 1day ..is this normal ?
PostPosted: Sun Feb 21, 2016 4:33 am
I would return the B & S., that's not a good start and it's a long split.
The top, well, do you have comfortably enough to avoid your template and joint the halves?
Otherwise, same story.
As for the curling up, that's the humidity change, probably the plates drying out.
I like to sticker everything immediately as I unpack wood, for that reason - you never know how wood's been stored, or the conditions it's endured in transit.
Do you have humidity control?.
It can be very dry inside a centrally heated house or heated workshop this time of year.
These users thanked the author Colin North for the post: cablepuller1 (Sun Feb 21, 2016 5:01 am)
PostPosted: Sun Feb 21, 2016 5:03 am
Thanks Colin
Yes humidity is pretty good at around 55 which is same as last build and never had this problem.. will keep wood flattened next time while it adjusts. .will contact the seller
PostPosted: Sun Feb 21, 2016 7:11 am
Cracks can happen, especially in transit humidity and temperature. As for the top, great the pattern can get moved. Did they draw the issue area in pattern? I don't understand why there is a pencil line going through it. If they drew that in pattern, that's a miss.
Andy
These users thanked the author AndyB for the post: cablepuller1 (Sun Feb 21, 2016 12:22 pm)
PostPosted: Sun Feb 21, 2016 7:49 am
Just curious - what is the grade of the top, and what is their grading system?
These users thanked the author Clay S. for the post: cablepuller1 (Sun Feb 21, 2016 12:22 pm)
PostPosted: Sun Feb 21, 2016 8:13 am
There grading system is vague.. one price for most woods sold as a kit but you can speak about the qaulity with them..I did and the backs really good ..but pay extra 30 for top stuff (I didn't ) ..cheaper than most I researched
PostPosted: Sun Feb 21, 2016 11:11 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I was just applying templates to some very expensive sets. Both had unexpected cracks and checks. But the templates were positioned to avoid them. I took proof photos before cut and shape and super soft soak. If they fail, I'll send photos to dealer. It's all I can do at this point. Your crack looks unfortunately located. But can you align template to avoid? Or minimize?
PostPosted: Mon Feb 22, 2016 1:44 am
I can position the top template to avoid the bad stuff there Mike ..but the back unfortunately is a 3-4" cracking so will be on guitar
PostPosted: Mon Feb 22, 2016 1:49 am
Andy
Yes Andy that's there pattern drawn on. .I don't get it either
PostPosted: Mon Feb 22, 2016 2:16 am
Return them. Cracks extend past what you can see.
Ken Franklin
clumsy yet persistent
These users thanked the author Ken Franklin for the post: cablepuller1 (Mon Feb 22, 2016 3:21 am)
PostPosted: Mon Feb 22, 2016 8:10 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I think it would depend on how much of crack remained after joining to neck block. And the size of your neck heel. But, yeah, I'd return those if I could. I just looked a bit closer and see that the crack is longer than I first thought. And after thinning, might even be longer yet.
These users thanked the author Mike OMelia for the post: cablepuller1 (Mon Feb 22, 2016 8:10 am)
PostPosted: Mon Feb 22, 2016 9:15 am
Unless the understanding was that this is second quality or rejected material --- most certainly return them.
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Tue Feb 23, 2016 5:10 am)
