It is currently Sat Aug 16, 2025 9:14 am
 Post subject: clamp "explosion"
PostPosted: Sat Feb 06, 2016 12:55 pm
http://www.rockler.com/2-in-spring-clam ... paign=(roi)+product+listing+ads
I had one of these applied to something I was working on, and it failed (shattered) sending parts at high velocity. No injuries, but it could injure an eye or ruin soft wood.
Has anybody else experienced this?
 Post subject: Re: clamp "explosion"
PostPosted: Sat Feb 06, 2016 1:21 pm
Harbor Freight sells them. I had one fall apart under a light load, though it didn't explode. I threw them all away.
These users thanked the author Pat Foster for the post: wbergman (Sun Feb 07, 2016 4:13 am)
PostPosted: Sat Feb 06, 2016 1:44 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Yep, I've had one explode the first time I used it. It was a cheap pack of 6 for £1 though, so can't complain! I've also melted one that I stupidly used on my bending machine.
Very useful clamps though, when they work.
Pablo Picasso
These users thanked the author PeterF for the post: wbergman (Sun Feb 07, 2016 4:13 am)
PostPosted: Sat Feb 06, 2016 2:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've had those self destruct before. Threw them out. Lowes used to sell great versions that had metal ratchets. Then, they decided their customers preferred cheap junk.
These users thanked the author Mike OMelia for the post: wbergman (Sun Feb 07, 2016 4:12 am)
PostPosted: Sat Feb 06, 2016 3:02 pm
Yup. Usually cause the screw in the hinge has worked loose. Check every once in a while.
These users thanked the author meddlingfool for the post (total 2): Shaw (Tue Feb 09, 2016 7:59 pm) • wbergman (Sun Feb 07, 2016 4:12 am)
PostPosted: Sun Feb 07, 2016 12:34 am
Last Name: Shanklin
City: Windsor
State: ON
I bought 2 bags of these http://www.leevalley.com/en/garden/page.aspx?p=69724&cat=2,42194,67373 over the holidays. just to replace those plastic ones for clamping kerfed linings. I find the 3" and 4" plastic clamps break easier than the small ones.
Bob
These users thanked the author Bob Shanklin for the post: wbergman (Sun Feb 07, 2016 4:12 am)
PostPosted: Sun Feb 07, 2016 10:18 am
First name: D
Last Name: S
They make great clips for open potato chip bags.
I had the same exploding experience.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post (total 2): Shaw (Tue Feb 09, 2016 7:59 pm) • wbergman (Sun Feb 07, 2016 3:17 pm)
PostPosted: Sun Feb 07, 2016 1:24 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I have a bunch of them clipped to the over head steel support beam in my shop, and probably haven't used them in ten years. Looks like a good time to get rid of them, as the plastic gets brittle with time.
Alex
These users thanked the author Alex Kleon for the post: wbergman (Sun Feb 07, 2016 3:17 pm)
PostPosted: Mon Feb 08, 2016 2:31 pm
First name: Craig
Last Name: Bumgarner
City: Drayden
I bought a couple bags full from Lowes ~ 5 years ago and had a few break in the middle of the jaw leg, close to the pivot. The ones that survived though have been fine and in constant use. If I threw them out, I'd miss them. Light weight, easy to use one handed, very good for light clamping jobs. They handle non-parallel clamping jobs okay up to point. I think confining them to clamping things not too thick helps their longevity.
Craig Bumgarner
Bumgarner Guitar Blog
PostPosted: Mon Feb 08, 2016 6:37 pm
For all you folks wanting to "get rid" of these clamps you can send them to me. I have been using them for years in 4 different sizes and never had one fail. I use them all the time in the context of a pro woodworking shop which is to say they are not babied or used lightly. I have noticed a difference in spring strength with some and use them accordingly.
L.
PostPosted: Mon Feb 08, 2016 6:52 pm
I've got a couple of dozen or so of those, or similar, and although a few of them have lost a jaw (possibly due to abuse/mishandling) I use them fairly regularly and like them.
I've had about 100 smaller ones (2 sizes, added rubber bands now) I have used for clamping linings in place since I started 6 years ago.
Also I have several 4" and 6".
Certainly none have self destructed explosively.
But thanks for the heads up, routine eye protection may well be in order - can't hurt.
PostPosted: Mon Feb 08, 2016 7:14 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
I have about 20 of these, not very old. I checked them all today and the screw was backed out a minimum of 3 complete turns. I tightened them up and applied a generous drop of ca on the threads at the nut. Seems secure now, but I'll keep an eye on them.
Brad Hall
Mystic Dawg Guitars
Users browsing this forum: dofthesea, rbuddy and 11 guests
