It is currently Sat Aug 16, 2025 8:33 am
PostPosted: Sun Feb 07, 2016 8:50 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
I am going to be starting my first guitar build. I have all the tool except for a drum sander for thickening. I found that LMII will do this for you when you buy the wood from them and also joint them. they only charge $50 which seems pretty reasonable. Their standard that they thickness to is backs-.095", sides-.090", and tops .110". they will do custom thicknesses also for no extra charge. Im building a grand auditorium and im using sitka spruce for the top and indian rosewood for the back and sides. will those thicknesses work or should i have them do different thicknesses?
PostPosted: Mon Feb 08, 2016 1:10 am
I think unless you have particular reasons for deviating from those numbers, which you probably don't since it's your first guitar, that those are very reasonable specs.
PostPosted: Mon Feb 08, 2016 6:52 am
"Sides" should be about .078" (same as the Martin Factory) --- I believe trying bend material that is too thick can be one of the biggest frustrations for the new builder (and not so new builders as well).
Ken Cierp
PostPosted: Mon Feb 08, 2016 7:43 am
+1 When I started taking my sides to .075 - .080 my life got way better, the trees leafed out, I won the lottery, I grew back hair, got taller, and smarter too. :)
Seriously though .078 is a great number IMO.
PostPosted: Mon Feb 08, 2016 9:11 am
Hesh wrote:
, I grew back hair,
Growing hair on you back was a plus??
You're a weird dude, Hesh.
PostPosted: Mon Feb 08, 2016 9:15 am
City: Tyler
I had LMI do the same on my first few guitars and it worked fine, with those specs.
PostPosted: Mon Feb 08, 2016 9:53 am
StevenWheeler wrote:
Hesh wrote:
, I grew back hair,
Steve what' wrong with back hair? :)
PostPosted: Mon Feb 08, 2016 10:24 am
First name: David
Last Name: Riedmiller
State: WI
I have thinned the sides down even more than that (Bubinga and Jotoba), but you have to pray for no wrinkles, as you will thin them down even more when you flatten them out.
Glue in braces to the sides as well.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
PostPosted: Mon Feb 08, 2016 9:23 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
they said the lowest they can go is .085
PostPosted: Mon Feb 08, 2016 9:32 pm
For your first guitar I still think .090 is just fine, especially since rosewood is so cooperative. That gives you a lot to work with for flattening the sides and such. After a few, you might decide you want to go thinner, but .090 will get the job done for you.
PostPosted: Tue Feb 09, 2016 9:54 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I'll second what Ed just said. I've only built 10 guitars but my standard has been back and sides at 0.09 and tops at 0.11 to 0.10 (I've done two western red cedar tops and left them at about 0.12). Back and sides have been of different wood species on all 10 guitars, and I've had no problems thus far (knock on wood).
PostPosted: Tue Feb 09, 2016 2:41 pm
Then at least have them do that -- thinner wood bends easier and has less spring back. I have no doubt that very thick sides have been bent -- but that's not my point of offering this advice. Besides there is always the chance that you can grow "back hair" like Hesh!
Here's some wood bending science:
http://www.fpl.fs.fed.us/documnts/usda/ah125.pdf
Ken Cierp
PostPosted: Tue Feb 09, 2016 3:10 pm
The back hair can be removed but cracked sides can ruin your day...:) +1 to what Ken and others are saying here.
Just as in interesting data point our 1870 Martin that just got way more valuable because Tarantino let the one from the Martin museum get smashed has sides in the neighborhood of .063"... Of course they are cracked in lots of places but that's what glue is for.
You guys wanna talk about glue? :) :o :roll: :D Just kidding....
PostPosted: Tue Feb 09, 2016 4:42 pm
Last Name: Beaver
City: Lake Forest
.085 is fine. You can always take it down a little with a ROS and 220 paper. You will want to smooth it some anyway
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 09, 2016 5:41 pm
0.110 seems a little thin for the starting point of the top to me. 0.115-0.125 would give you more wiggle room for stuff like rosette leveling and voicing the closed box.
PostPosted: Tue Feb 09, 2016 9:23 pm
Last Name: Beaver
City: Lake Forest
So true. That's why it is so nice to thin the top after the rosette goes in. It can also be true of the back if you are using a back strip. But with careful work you can do both after the top and back are joined and thicknesses.
It is a good reason to have LMI do those on the thick side. Then after the rosette and back strip are leveled you can flip them over and finish with a little ROS and scraper.
The sides are different of course.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Feb 15, 2016 1:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I haven't had LMI thickness anything for me for a while... mostly because I'd like to do the work myself (there's a bit of fine tuning needed here) and also I join the plates before any thicknessing to avoid trouble. Get a hand plane and learn how to thickness tops.
Back and side is a fair game though, probably pays to have them thickness it for you, especially to a thickness that is easy to bend.
Typhoon Guitars
PostPosted: Mon Feb 15, 2016 1:09 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
IMHO, appropriate side thickness is totally dependent on the wood. I run it through the sander multiple times, checking it for flexibility after each pass. I just bent some quartered wormy chestnut at 0.100" and it bent just fine. I have gone down to 0.070" on the really dense, stiff woods. Slab cut sides are more likely to ripple, so I generally leave them a bit thicker.
The standard LMII thickness for backs and sides should be fine, but IMHO 0.110" for the top thickness may be too thin on a grand auditorium if the top is not relatively stiff. I would start at 0.120" and do the rest myself, based on the flexibility of the individual top.
PostPosted: Mon Feb 15, 2016 5:10 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
For a big guitar .125 is a good beginning it/s easier to sand off 5 to10 thou and a lot harder to add to it later
PostPosted: Mon Feb 15, 2016 10:25 pm
Martin Guitar factory tour gave out discs from the sound hole cutouts as souvenirs. Mine is 0.125".
Users browsing this forum: bobgramann and 32 guests
