It is currently Sat Aug 16, 2025 8:33 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 38 posts ]  Go to page Previous  1, 2
 Post subject: Re: Fish Glue!
PostPosted: Tue Jan 26, 2016 7:20 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
RaymundH wrote:
Check out this from Taylor Guitar on the use of fish glue in their newly designed 800 Series.
https://www.taylorguitars.com/content/8 ... abs#tabs-3
Looks like fish glue for the bracing and HHG for the bridges.
I have ran across that too in my searches.
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
PostPosted: Tue Jan 26, 2016 7:52 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Made mistake of mentioning thread to boss, who is a nut for credit where due. From the exchange:
Quote:
Is this really necessary? JFrench, David Collins, and especially John Hall should get the blame, at least for the OLF stuff.
Quote:
If you insist - Joshua French mentioned fish as a luthiery glue in early 2005, and I think I read that post shortly after joining. I got out the little vial of the stuff that I had been using with the LV chip-raising chisel (use chisel to lift a chip, nail in a tack, glue down the chip with high-tack fish glue)...maybe the stuff was old (had been in the shop since 1993 or so), but seemed to take forever to tack up and never really dried ll that well. I think I may have PM'd French about it and he (or maybe John Mayes...can't recall) suggested getting a fresh bottle from LV, which I did. Played with it a bit and forgot I had it until Collins mentioned it in one of his first posts after joining OLF in Jan 2006 (might have been December...was around holidays or right after because I used it on #06003 for linings and a few other things).
When Sylvan set up the first Mid-Atlantic Open House in early 2007, I took a fresh gallon to the get -together (Chris and Mark Joy rode up with me - you have not met Mark yet - good guy) and gave anyone that brought a container as much as they would take - John Hall took a pint or so, and gave me his mini-die grinder inlay jig and an Enco die grinder in exchange. Not a good idea to try to refuse John, he is stubborn and generous in equal parts - you need to make the next Mid-Atlantic shindig and meet him.
Not sure who else got glue - I think Filippo and Terry grabbed some, and Joy, but John was fascinated with the stuff and really got into it for building in lieu of Titebond. I used it for some jobs early on, but had gotten good enough with hide that I no longer needed the open time, so stopped using it for primary structure.
We don't use fish for primary structure because it's picky about clamping and takes 3-4 times longer than 315g to set for bridges; otherwise, lots of folks use it for just about everything.
Recap: French, Collins, and especially John Hall had a hand in popularizing the stuff, plus some of the guys over on MIMF and a few on UMGF.
So there you go!
- Beth Brower
PostPosted: Tue Jan 26, 2016 10:21 pm
Hesh wrote:
About ten years ago on the OLF the one who started talking about Fish glue first and introduced us all to it was Dave Collins. He had high hopes and as a Pro repair guy was using it with a frequency that we don't see from builders typically.
Woodie, I'm not sure what the point of your post was, exactly. If Hesh says he and Dave introduced fish glue to the OLF, I don't doubt him for a country moment.
Andy
These users thanked the author AndyB for the post: Woodie G (Wed Jan 27, 2016 8:52 am)
PostPosted: Wed Jan 27, 2016 6:59 am
Andy
No prob Andy and thanks for that.
The only point that is important to me is to get the information out here that we had fish failures with bridges lifting and as such caution for this application might be a consideration. That's all that matters to me and now I've said it so I'm good.
PostPosted: Wed Jan 27, 2016 7:16 am
I remember hearing about Fishglue from David. I bought some soon after
but never really had the time to properly test it like David and Hesh.
PostPosted: Wed Jan 27, 2016 9:34 am
So there you go!
Woodie, it would be great/helpful to link the posts that you quoted this from.
I assume they are in the OLF archives?
PostPosted: Wed Jan 27, 2016 9:56 am
First name: Willard
Last Name: Guthrie
City: Cumberland
All good, Mr. B! I thought we were looking for some historical context, given the recollections of some prominent members of the luthierie community such as Mr. Hall. I can be a bit obsessive about research - especially when it is so interesting to prowl through the old threads here!
I am still curious about the shelf life issue for fish glue, which was touched upon but not really covered in detail. While the manufacturer, Norland, and resellers such as Luthiers' Mercantile and Stewart MacDonald Guitar Supply mention a two year shelf life, there are some posts that come up on searches here and elsewhere that suggest actual shelf life is much longer when properly stored.
Any comments? False Economy? With small containers running many multiples per ounce of what a minimum order from Norland costs, the Sam's Club & COSTCO shopper in me wants to buy a gallon, but the frugal householder in me abhors tossing most of that gallon if not used by the last tick of the shelf life clock. Obviously, a single failure due to failed adhesive obviates and indeed punishes thrift, but given the extremely conservative nature of most shelf life forecasts, what do we actually see as the risk?
Mr. Kragenbrink - I have a morbid fear of borrowing other's words without some indication that they are not mine, so used the quote function for the contents of an email exchange with another builder to summarize his response to my questions. Is there a format you'd prefer? On quoting Mr. B's comment, I assumed having the post in the same thread was sufficient.
- Beth Brower
PostPosted: Wed Jan 27, 2016 10:53 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Shelf life, according to manufacturers, might be like maximum load, according to engineering. If it is rated for 10,000lbs, it will carry double that. Always best to err on the side of caution, from a manufacturing standpoint. Any glue that I have for over a year gets used for jigs and non critical projects.
Alex
PostPosted: Wed Jan 27, 2016 10:57 am
Alex
Exactly my thoughts as well.
After a year I donate my glue to the household projects. School stuff and general use.
PostPosted: Thu Jan 28, 2016 6:22 am
In the interest of accuracy here are some facts:
January 9th, 2006 Dave Collins posts that he is testing Fish glue and that it looks promising. This is the earliest reference to fish glue that is not just mentioning it in passing to be found in the forum archives on the OLF and it's also what I remembered and apparently what Lance is remembering too.
To see this post search the archives only on the keyword "fish." Again this is the earliest post about fish glue that is not just mentioning it but actually providing information about what it is, how it works, etc.
The poster quoted in the anonymous post above if it's who I think it is joined the forum on July 4th, 2005 with his former public ID and was a newb back then just like I was and many of us were. The earliest substantive mention of fish glue by Collins happened 6 months later after this individual joined the forum.
The Sylvan Wells open house happened in January 2007, a year after the Dave Colins post and one and one half years after the unnamed poster joined the forum. After Collins started working with fish glue many of us wanted to try it making it a topic of the open house a year later.
To see posts about the open house select the archive and use keywords "open, house, and Sylvan."
I am sure that others had used fish for Lutherie way before this but again in terms of the OLF being introduced to fish glue in earnest with information provided and it just not mentioned in passing the posts are there/here for anyone to see.
Most of all though I fail to see why any of this should have mattered unless some are not here to learn and share and instead to make trouble.
I too would appreciate that anyone supposedly quoted or even cited who is not participating on the forum be named - that's how quoting works by the way.
PostPosted: Thu Jan 28, 2016 6:33 am
Fish glue was used longer. Michael Gurian and Tom Ribbeke were using this long before I knew what luthery was. Also I failed to mention David LaPlante also was using this long before I head about it from the 2007 gathering.
These users thanked the author bluescreek for the post: Shaw (Fri Jan 29, 2016 9:56 pm)
PostPosted: Thu Jan 28, 2016 8:10 am
First name: Willard
Last Name: Guthrie
City: Cumberland
Quote:
I cannot have a man who is afraid of everything, I don't have the time to soothe insecurities and fears, I cannot have a man who is standing on a stone by a creek, watching for the fish to swim by and every time he sees a fish he says "Oh look, this fish scares me, I wonder what this fish means, this fish might mean- this, or this fish might mean- that" for God's sake, they are just fish, and they don't mean anything! Such a sad thing, so many fine, strong men standing on top of little stones, pointing at fish all the time! Such a waste! Such a waste of time! I can only have a man who will leap into the water, not minding the dang fish and whatever other little things that scare him. I need to have someone who is braver than me; if I am a pirate, he has to be the pirate Captain, if I am a pirate Captain he has to be the flying dragon.”
― C. JoyBell
- Beth Brower
PostPosted: Thu Jan 28, 2016 8:35 am
OK fellas, I am going to lock this thread down. There is some usefull information in here so it shale stay alive.
But I can see this topic trending off into the deep grass.
Instead ill post a TBT pic.
My daughter from 2009 working on her own guitar. By the way, its still not finished :roll:
These users thanked the author LanceK for the post: GRS (Thu Jan 28, 2016 8:46 am)
Users browsing this forum: bobgramann and 32 guests
