It is currently Sat Aug 16, 2025 4:45 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jan 25, 2016 6:48 am
J De Rocher wrote:
That's a very cool and beautiful guitar. The build thread over on the AGF is one of the best I've seen for its extensive details and great photos. The guitar has many interesting design/engineering features and the methods you used give me a lot to think about.
The neck joint reminds me of the adjustable cantilevered neck on a 1951 National archtop I used to have. It also used a three-screw tripod adjustment mechanism and a single bolt to hold the neck on. The biggest difference was that it had no heel at all. Just a cover plate over the adjustment mechanism. It looked like this:
Thanks! I'm glad this has given you stuff to think about.
Thanks for sharing that pic of the National. Yep, pretty much the same thing. I didn't know National had done this in 1951. Cool. I like the lack of heel and the cover plate idea. Very practical. I wonder how that metal piece (it is metal, right? Looks like steel in the pic) is joined to the neck shaft; that's where there could be problems if it wasn't well engineered.
Todd Rose
Ithaca, NY
PostPosted: Mon Jan 25, 2016 1:25 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
You are correct that the block with the adjustment screws is metal. I'm pretty sure it's steel. I had that guitar (and another National with the same mechanism) years before I started building guitars so, unfortunately, I didn't look at how that block was attached to the neck from a builder's perspective. I can say it was rock solid though and that the mechanism worked nicely.
PostPosted: Mon Jan 25, 2016 3:03 pm
Cool. Thanks.
Todd Rose
Ithaca, NY
PostPosted: Mon Jan 25, 2016 8:22 pm
Last Name: Beaver
City: Lake Forest
That's a beauty Todd. Love the smiling bridge!!!
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Todd Rose (Tue Jan 26, 2016 10:14 am)
PostPosted: Tue Jan 26, 2016 11:21 am
Beautiful piece of engineering and workmanship.
These users thanked the author Bobc for the post: Todd Rose (Tue Jan 26, 2016 11:42 am)
PostPosted: Tue Jan 26, 2016 8:57 pm
First name: Jeff
Last Name: Duncan
City: Concord
State: Ma.
Zip/Postal Code: 01742
Wow, just went through 14 pages over at AGF and that is an impressive build! As a beginner just starting his first instrument I'll be re-reading that post a couple times. I hope you don't mind if I ask a couple questions though? One, since you filled the CF tube with a wood dowel anyway, do you think the hardwood dowel on it's own would be adequate for that type of strut? And second, if I'm understanding the construction of the neck to body joint correctly, the only thing mechanically attaching the neck is the single bolt on the bottom? While that does seem as though it will make a strong joint, I can't help but wonder if it could be susceptible to rotational movement from an errant bump?
Figure I'll ask now so someday down the road when my skills have improved I'll be better equipped to 'borrow' some of your ideas:)
thanks
Jeff
PostPosted: Wed Jan 27, 2016 3:30 am
thanks
Jeff
Thanks, Jeff. 1st question: No, I don't think a hardwood dowel alone would be rigid or stable enough. The geometry of the guitar depends on that strut staying dead straight, and it's carrying a heavy load. 2nd question: Not at all likely. With the force of the bolt and string tension, those three set screws are bearing very hard against the brass plugs in the heel. It would take a very strong impact to knock the heel out of place. An impact like that would be likely to damage any guitar.
Todd Rose
Ithaca, NY
PostPosted: Wed Jan 27, 2016 9:02 pm
First name: Jeff
Last Name: Duncan
City: Concord
State: Ma.
Sounds good, and thanks for the response!
Jeff
PostPosted: Wed Jan 27, 2016 10:12 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Hey, Todd,
I am posting again here,
because I am so impressed with that guitar.
Perfect choice of wood combinations,
lovely soundhole placement, concentric with the upper bout,
top with stunning silking,
amazing neck attachment,
beautiful rosette and binding scheme,
smiling bridge (one eyed face),
and it sounds great!
I agree with you about the gold hdwr.
You are a true artist!
PostPosted: Thu Jan 28, 2016 11:38 am
alan stassforth wrote:
Hey, Todd,
Thanks, Alan! Much appreciated. If the work has inspired others, then it was worthwhile.
Todd Rose
Ithaca, NY
PostPosted: Fri Jan 29, 2016 11:16 am
First name: David
Last Name: Riedmiller
State: WI
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
PostPosted: Fri Jan 29, 2016 11:30 am
First name: David
State: WI
Todd-
This shows us all what the true meaning of an artisan is: the melding of functionality with the keen eye of an artist. Congratulations on showing us a great accomplishment. BTW I can't wait to see how you top this.
Dave Riedmiller
Mark Twain
These users thanked the author Rocky Road for the post: Todd Rose (Fri Jan 29, 2016 1:12 pm)
PostPosted: Fri Jan 29, 2016 1:04 pm
Hi Todd .. checked out the thread on the AGF .. very interesting way of building, and lots of thought put into the design and engineering - Kudos !!! I like the way you think ... Carry on !!
These users thanked the author TonyKarol for the post: Todd Rose (Fri Jan 29, 2016 1:13 pm)
