It is currently Sun Aug 17, 2025 12:14 am
 Post subject: NO. 6 finished.
PostPosted: Mon Jan 18, 2016 12:39 pm
Well, I haven't been on here in... well, years really. An extensive house renovation is eating up all the free time that I didn't have to begin with. I finished this guitar close to a year ago, but I'm only getting around to posting pics now. Ha! Sorry for the quality of the pics.
So this one had many "firsts" for me.
-First time making a segmented rosette (note that I replicated the pale sapwood of the back down the middle)
-First time trying hemispherical fret ends
-New bridge design
-New headstock design
-New neck block design with support (and bolts) under FB extension
-New bracing patern (Somogyi like double X under main X)
-Use of moose bone nut and saddle. I had to laminate pieces together to get them wide enough. I had heard that moose bone was very dense and having played this guitar for a year, I have absolutely no idea if that's true or not... ;)
Particulars:
Body shape : Proprietary Grand Auditorium'ish
Back sides and rosette : Curly Claro Walnut
Top : Lutz Spruce
Headplate : Macassar Ebony
Binding, bridge and fingerboard : Ebony
Finish : French Polish with dewaxed garnet shellac
This guitar is part of a "triplet" project I have going. I noticed that it was measuring, setting up tools and humming & hawing that took up most of my time. The actual cut/machining is quickly done. I decided to try and make 3 guitars at once. I figured that if it takes me 100 hours to build one, it shouldn't take me 300 for all 3. So far, my theory holds true, but I'm not crazy about having a bunch of guitars in different stages of construction lying around.
On the other hand, it will be interesting to see the difference in tone across all 3 guitars, since all of them will basically be the same, asides from the tone woods used. I managed to tune the backs to the same pitch, although I won't be able to do the same for the tops as I like to close the box ASAP once I'm done.
These users thanked the author Alain Desforges for the post (total 3): Pmaj7 (Fri Jan 22, 2016 10:07 am) • Johny (Mon Jan 18, 2016 9:16 pm) • Durero (Mon Jan 18, 2016 7:07 pm)
 Post subject: Re: NO. 6 finished.
PostPosted: Mon Jan 18, 2016 12:51 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Looks pretty tasty. I like your headstock shape
PostPosted: Mon Jan 18, 2016 1:25 pm
City: Escondido
Zip/Postal Code: 92029
Beautiful. Do you have pics of your neck block and bracing?
PostPosted: Mon Jan 18, 2016 2:02 pm
First name: Heath
Last Name: Blair
City: Visalia
Looks great and welcome back!
sweat the small stuff.
PostPosted: Mon Jan 18, 2016 5:01 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Sweet! I love the body shape - very elegant.
Pablo Picasso
PostPosted: Mon Jan 18, 2016 8:25 pm
First name: Fred
City: Winnipeg
Everything works really well together.
PostPosted: Mon Jan 18, 2016 10:07 pm
Al, I've missed you my Friend.
That is stunning!!! Well worth the wait. I love everything about it. I really like that body shape, 15" LB?
It would be great of you with all the spare time to play a tune for us.....you're a great player and I'm sure you make that guitar sound just as good as it looks. Great job on the FP too.
And very good to see you "back" even if it's just to show off :D
PostPosted: Tue Jan 19, 2016 7:15 am
Thanks for the kind words everyone!
I did manage to find some pictures of the neck block and of the bracing. However, they the bracing isn't from this guitar, but it's triplet sister. I will post those soon.
Rod, good to be back my brother! That Lutz top came from you, if you recall. I will try to record myself and post a vid on youtube. It will be another first for me. You know, as aweful as it sounds, I'm not quite sure about the LB measurement. LOL I've been away too long! I think it's in the 15-15.5" range. I still think that segmented mosaic rosette of yours is the sweetest I've ever seen!
PostPosted: Tue Jan 19, 2016 10:06 am
So here is the bracing. It's loosely, or not so loosely, based on that of he who shall not be named... Ha!
There had been a picture floating around the interwebs, years back. I thought it looked like a good idea. I did try this bracing pattern in my baritone, and it's proved very stable and it sounds pretty awesome, if I do say so myself.
On this guitar, the sound is very bright and balanced. It doesn't have the boxy bottom end of a more traditional Martin style bracing pattern, but there's still plenty of bass. It projects like crazy. Everyone who tries it can't believe the volume that emanates from the small box. I play mostly fingerstyle, but it'll take a violent plectrum attack with poise. It also loves a drop D or C tunning.
I had always found that a big problem with my earlier guitars was that they moved like crazy with RH swings. My goal as a builder was to stabilize them. Part of the problem, I'm sure, was that I built them too lightly. Super thin tops, light bracing and, compared to the set-up I have in this one, a flimsy neck block. This guitar still has a pretty thin top (not sure about the exact measurement at the moment), but nothing is telegraphing through. It sounded good from the get-go and has opened up beautifully.
I've been playing this one for close to a year now, and asides from dialing in the action after it had been strung for about a month (mediums), I haven't had to touch it at all.
PostPosted: Tue Jan 19, 2016 9:58 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Way to go Alain, I'm glad you found some time
Mike McNerney
PostPosted: Wed Jan 20, 2016 12:44 am
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
Beautiful work!
I really love the body shape. Nice headstock too.
PostPosted: Wed Jan 20, 2016 9:22 am
First name: Danny
Last Name: Vincent
Nice Alain! That one looks like it's all you.
PostPosted: Wed Jan 20, 2016 12:28 pm
Thanks guys for you kind comments.
And Danny, yours is especially heart felt. I know it's hard to reinvent the wheel, so to speak, but I've been tweaking and changing design aspects to really try and make something that is my own.
PostPosted: Wed Jan 20, 2016 12:31 pm
Leo, thank!
I basically took my old Takamine dread contour. Then I pinched the waist, flared the bouts, slopped the shoulders and on this model here, I took off about an inch of width. LOL
PostPosted: Thu Jan 21, 2016 3:21 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Beautiful guitar!
Nice to see you step out of the box on the bracing.
keep up the good work. [:Y:]
Mike Collins
PostPosted: Fri Jan 22, 2016 6:25 am
Thanks Mike!
PostPosted: Fri Jan 22, 2016 2:12 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Beautiful walnut. Great looking guitar.
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
