It is currently Sat Aug 16, 2025 7:14 pm
 Post subject: NECK SYSTEM
PostPosted: Sat Jan 09, 2016 5:27 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi, I wish you all Happy New Year.
I send this picture from Ken Parker Guitar neck system. What do you think about that? Do you explain for strength,
construction, string tension or other thing about this neck? I see this interesting and elegant neck. thank's alot.
 Post subject: Re: NECK SYSTEM
PostPosted: Sat Jan 09, 2016 11:36 am
I've played a few of these, and they really are incredible. Neck joint aside, the guitar overall is quite amazing and unbelievably versatile. Obviously great in the hands of a skilled jazz player, but last year I sat playing folk tunes around a campfire on one of these Ken brought out with him, and was amazed at how well it could cross over to work just as perfect flat picked with fiddle and mandolin.
I've looked at them broken down, played with adjusting the neck, and it is incredibly rock solid for what appears to be such a small and fragile support. There's a lot of engineering and very selective choice of materials that went in to designing the system, but it really does work as well as he says. Quite genius really.
These users thanked the author David Collins for the post: herry tze (Sat Jan 09, 2016 6:27 pm)
PostPosted: Sat Jan 09, 2016 6:30 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Thank's David, who ever built neck system like this? how the constructions?
PostPosted: Sat Jan 09, 2016 9:01 pm
I wish I had taken photos of it apart. It's a brilliant piece of Ken Parker ingenuity through and through. You literally can adjust the action with one screw, and it stays perfectly in tune.
PostPosted: Sat Jan 09, 2016 9:10 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Could you please explain this more? Is it steel reinforced? I have a hard time believing that it's not.
PostPosted: Sat Jan 09, 2016 10:10 pm
Unfortunately I honestly do not recall how significant a presence of steel there is in the post beyond the threaded portion for adjustment. When I get back to my computer on Monday I'll skim through my photos to see if I have any better details.
What I do recall is that Ken has put a great deal of focus on the type, weave, and orientation of the carbon fibers in layup, which has a huge influence on properties of effective strength and stiffness. I seem to recall a modest amount of aluminum framing in the body supporting the neck post, but I believe the strength of the post itself lies primarily in a well engineered carbon layup.
PostPosted: Sat Jan 09, 2016 10:14 pm
Looked through photos on my phone, but this is the only one I could find with Ken (checking out our bridge slotting mill ;) ).
These users thanked the author David Collins for the post: Durero (Sun Jan 10, 2016 2:01 am)
PostPosted: Wed Jan 13, 2016 2:53 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
http://kenparkerarchtops.com/kenparkerarchtos.html
look this tread of Ken Parker's neck / body joint
PostPosted: Wed Jan 13, 2016 8:53 am
I've never seen anything like that and really can't imagine how it works but just having took a quick looks at Ken's website... he makes some beautiful looking works of art that's for sure.
PostPosted: Wed Jan 13, 2016 12:51 pm
City: Escondido
Zip/Postal Code: 92029
At $35k a piece, they better be!
PostPosted: Thu Jan 14, 2016 7:47 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Ken explained this to me. He has a mold the shape of the back of the neck- where your hand rides. He first puts in a thin veneer of maple so you see it when the piece is taken out of the mold. He then lays CF hairs (I think he called them bolts??) in epoxy into the mold on top of the maple. They start at the nut and travel down to the vertical post where they turn down. At the soundhole end of the neck, shorter hairs are laid in and they also turn down the vertical post. IIRC, CF is also laid the full length of the neck. Epoxy is then used to fill to the top of the mold. When it is dry, it is removed from the mold and trimmed. Again IIRC, the neck block is used to support the vertical piece with the help of some more CF.
It has been a few years
Ed
PostPosted: Thu Jan 14, 2016 9:11 pm
City: Escondido
So the neck shaft is CF with a wood veneer?
PostPosted: Fri Jan 15, 2016 6:34 am
Last Name: Minch
City: Chestertown
YEs, the neck shaft is CF with a wood veneer
Ed
PostPosted: Fri Jan 15, 2016 1:22 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Wow! I never would have guessed that. Sounds like one very complicated layup!
Are you sure he fills the neck with epoxy afterwards though? I would have thought that would dampen the sound a lot.
Pablo Picasso
PostPosted: Fri Jan 15, 2016 4:42 pm
It also seems like this would make for a very heavy neck.
PostPosted: Fri Jan 15, 2016 5:05 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I saw this before. I think it's amazing. He builds some unique guitars. This instrument has some traditional elements and then it takes a radical departure with this neck joint. I love it!
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
PostPosted: Tue Jan 19, 2016 1:34 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
This is the copied from Ken Parker's web
Ken Talks about Fingerboards and Necks On His Archtops:
About fingerboards:
In order for any stringed instrument to play optimally, the fingerboard surface must be shaped to address each string’s path and cross sectional shape when played. Because the string spacing is much greater at the bridge than at the nut, and therefore the strings are not parallel, the correct surface is always a conical section. There is no way that a “flat”, or constant - arc (cylindrical) surface can do the job, although that doesn’t stop most manufacturers from ignoring this fact to save money.
Every bowed instruments’ fingerboard, from Medieval to Modern, has been shaped in this conical way. Tragic - comically, this conical surface has been mis-named a “compound radius” by the guitar magazine pundits. To listen to them, you might get the idea that this was discovered in California in the 1970’s. As you know, a radius is a simple straight line measurement, and cannot be a compound anything!
I use a subtly altered conical section, just like the Medieval Viol builders did. The subtle alteration is a very slight longitudinal “hollow” parabolic curve to acomodate the shape of the vibrating strings, especially the lower notes of each string. This curve is called “relief” , and needs to be greater for heavy strings, high action, and an aggressive attack; and less for low action, light strings, and a light touch. The lower pitched strings always need slightly greater relief than the high strings. Precisely adjusting the relief to address these parameters is the key to optimal playability and low action. For the most demanding players, it’s necessary to observe quite strict temperature and relative humidity control in order to minimize wood movement that would affect the shape of the neck.
I normally use a 12”r at the 12th fret, which, combined with the difference between the string spacing at the nut and the bridge, gives 10.3”r at the nut, around 13”r at the 22nd fret, and 14”r at the bridge. Of course, this can be altered to suit the customers’ desires.
I use EVO fretwire, an exceptional product from the German company Mnzerna, which has a beautiful gold color, and outwears nickel fretwire many times.
I’m using the medium size, which is .090 wide, and .050 high. Because I work very carefully to shape the ebony fingerboard playing surface, virtually no height is lost to fret leveling.
I must say that I get very few comments about these things when I hand someone a guitar. I usually have to ask at least twice to get a comment on the neck, frets, or board arc. This is a good sign that the whole is greater than the sum of its’ parts.
Action is my speciality. I’m obsessed with action and playability. I understand that all of us are constructed differently, and I have devoted a big chunk of my worklife to facilitate the guitarist’s healthy and long - term interaction with the instrument. I can get an electric guitar to play perfectly at 1mm bass, .75 mm treble @ the 12th, but for expressive purposes, this action is too low to get a desirable dynamic range from an acoustic guitar. I normally build the guitar for D’Addario EXP (coated)Phosphor Bronze strings “012” - .053”. As a builder, I believe these strings to be superior to all others.
About neck stability:
I believe that neck stiffness is very important, especially contributing to even response. If the neck is too weak, it can cause all kinds of chaos. It’s also useful to remember that your hand is constantly modifying the behavior of the neck as it moves along it, as it acts as a fleshy nodal point.
The attractiveness of lower tuning peg weight for me is largely for physical balance. When you think of the guitar body’s waist as a fulcrum, the tuning pegs are quite far away, and exert a force much larger than their weight might suggest at first glance.
Why I recommend 12 gauge strings:
I’ve been at this repair/building thing for 35 years, and have worked for many guitarists who have had soft tissue problems that spoiled their ability to play. The sad part is that everything is fine until it isn’t, and then there’s no going back and doing it differently. In my opinion, based on this experience, 13s are too much for many of us, and it’s kinder on the body to consider the organism’s limitations. What a tragedy to be unable to play or practice the way you would like! I believe that the curves of humans and guitars cross at 12s, and have designed the guitars to respond optimally to the tension of this set. In my experience, shifting to 11s cuts the output greatly, but so does shifting to 13s! The greater force applied to the top seems to clamp it so hard that it’s no longer as sensitive, and tends to bark more than ring. “Clamped Shut” is what the guitars sound like to me when they see too much downpressure.
The guitar, unlike a bowed instrument, has to be very efficient to have any useful dynamic range. The difference between the most powerful guitar and a “normal” good guitar isn’t a huge difference. In order to offer the player a useful dynamic range, it’s necessary to build a powerful instrument that also sounds great at low volume, and is easy to “start” at low volume. This condition I think of as efficiency, and it has a lot to do with the relationship of the strength of the body relative to the downbearing force of the strings.
PostPosted: Tue Jan 19, 2016 1:46 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
http://www.kenparkerarchtops.com/kenparkerarcht-2.html
PostPosted: Tue Jan 19, 2016 8:43 am
Obviously, Mr. Parker is a very clever fellow.
Users browsing this forum: gregorio, ptourin and 11 guests
cron
