It is currently Sat Aug 16, 2025 9:39 pm
 Post subject: Cutting Purfling Layup
PostPosted: Fri Jan 01, 2016 9:24 pm
First name: Danny
Last Name: Vincent
In another thread a while back someone posted a pick of a set up for cutting purfling with a knife blade rather than a table saw.
I did look in the achieves to know avail. I'd be grateful if whoever posted it could re post it. Promise to bookmark it this time.
Thanks!
These users thanked the author DannyV for the post: wbergman (Sat Jan 02, 2016 6:44 pm)
PostPosted: Fri Jan 01, 2016 9:39 pm
FWIW, I still find it easier to use the fret slotting blade and a feather board on the tablesaw...
PostPosted: Fri Jan 01, 2016 11:35 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Hey Danny, I posted a pic of cutting with a marking gauge, worked well.
PostPosted: Sat Jan 02, 2016 9:12 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use a 3 ft starrett st edge , but get inaccurate cuts witha vy sharp knife . The cuts are not straight Now using a 2 sided veneer saw, which seems to work better for me. Saw needs to be vy sharp before using Iuse the rip teeth for long cuts.
PostPosted: Sat Jan 02, 2016 9:22 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Here is a method from Dave Stewart
viewtopic.php?f=10117&t=19132
Ken
PostPosted: Sat Jan 02, 2016 10:13 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I've always found the table saw with my stewmac fret slotting blade works better than slicing for anything over .02" really.
PostPosted: Mon Jan 04, 2016 12:23 pm
First name: Danny
Last Name: Vincent
Thanks for the replies. I didn't see the one I was looking for though. I think it was a blade setup from one of the regulars here.
I guess I could use my fretting blade on the t/s. I kinda like to leave that dedicated to the task but I suppose it won't do much wear.
Wonder how Gurian does it?
PostPosted: Tue Jan 05, 2016 1:06 am
Last Name: Shanklin
City: Windsor
State: ON
Danny, is this the one you were looking for?
http://www.leevalley.com/en/Wood/page.aspx?p=69874&cat=1,43314,69873
Bob
PostPosted: Tue Jan 05, 2016 12:58 pm
First name: Heath
Last Name: Blair
City: Visalia
FWIW, I use my fret cutting blade on the table saw. I've heard stories of shops using their blade to cut slots on thousands of fretboards, so I figured cutting up purfling for my little shop wouldn't be too much wear for the worse.
I use a piece of MDF or plywood against my rip fence to keep the thin (0.023") veneers from sliding into the gap between the fence and table. I made enough 0.100" tall purflings to last me multiple years at the rate I build (or mentally build) in an hour or two. The key to consistency, for me, was using a homemade push-stick. The one I made is about 3" wide by almost 3 feet long. It's faced with sandpaper to help grip the veneer and has a small kerf running down the full length for the blade to pass through. At the trailing end, I glued a small piece of veneer across its width to catch and help push the last few inches of stock through the blade, which I initially had trouble with. Hope that makes sense.
sweat the small stuff.
PostPosted: Tue Jan 05, 2016 2:28 pm
First name: Heath
Last Name: Blair
City: Visalia
One important thing i forgot to mention. Use a zero clearance insert with a piece of purfling glued in as a splitter. I think I originally got this method from Rod True? Maybe?
PostPosted: Tue Jan 05, 2016 9:19 pm
Bob
I have one of those, but it doesn't work for me.
Just saw a post on Luthiercom.org of a system using a clamping system with magnets and a Japanese saw that works pretty well.
PostPosted: Tue Jan 05, 2016 9:28 pm
First name: Danny
Last Name: Vincent
Thank you all. Still not the one I saw. I should have book marked it.
I've cut lots on the table saw with a Freud blade. I was just looking for a better yield. I guess the fret blade it will be.
Cheers!
