It is currently Sun Aug 17, 2025 4:49 am
 Post subject: Laminated neck blocks?
PostPosted: Wed Dec 02, 2015 1:50 pm
I've had to resort to making 2pc laminated necks. There an awful lot of waste wood, which looks large enough for laminated neck blocks. I can't see an issue with it, especially as I use a bolt on butt joint.
Any thoughts?Image
PostPosted: Wed Dec 02, 2015 1:54 pm
City: Tyler
I have used neck blocks made from more than one piece. I just keep the seam perpendicular to the body length so it's always under compression (also compressed by my bolts). Don't know if it's the 'right way' but I've done it and haven't had a problem yet.
PostPosted: Wed Dec 02, 2015 2:02 pm
Should not be an issue with a bolt-on. For dovetails I would not use laminated blocks because come reset time, and it will.... the steam may delaminate the neck block.
These users thanked the author Hesh for the post (total 2): jack (Wed Dec 02, 2015 3:38 pm) • Bryan Bear (Wed Dec 02, 2015 2:21 pm)
PostPosted: Wed Dec 02, 2015 2:21 pm
First name: Danny
Last Name: Vincent
[:Y:] Mine are almost always 2 piece.
PostPosted: Wed Dec 02, 2015 4:15 pm
I use the same type joint and mine are all 3 or even 4 piece. Blocks, linings and the like are good areas to use pieces of wood that fall on the shop floor ;)
+1 on the dovetail though.
PostPosted: Wed Dec 02, 2015 4:42 pm
Dovetails are a relic of my past, no fear there...
PostPosted: Thu Dec 03, 2015 12:11 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I made laminated neck blocks... I laminated it with epoxy thinking that when reset time comes, epoxy won't come apart at all.
Typhoon Guitars
PostPosted: Thu Dec 03, 2015 9:22 am
First name: Tom
Last Name: West
State: Nova Scotia
Ed: I've used stacked neck blocks and never had a bit of problem and I think laminated should be OK. As long as one keeps the grain parallel to sides I don't see a problem.
A bit of a note for Tai Fu.................While some epoxies may be impervious to heat, the kinds I have used can be parted with heat.
Tom
PostPosted: Thu Dec 03, 2015 9:32 am
You may not care about this, but I don't think a two piece (or even a 5 piece neck) should be called "laminated". Laminations are thin layers like you see in plywood.
I use laminated heel and neck blocks made from baltic birch plywood. I think there are definite advantages to this approach regarding stability, lightness, and crack resistance.
PostPosted: Thu Dec 03, 2015 10:00 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Trev recommends Epoxy for laminated neck blanks.For his bolt on bolt of necks
Users browsing this forum: stumblin and 10 guests
