It is currently Sun Aug 17, 2025 4:30 am
PostPosted: Wed Nov 18, 2015 9:08 pm
First name: Daniel
Last Name: Henriks Madureira
Country: Close to the great white north
Hi everyone,
This is not a guitar by any means, but I'd like to have your expert input if possible.
This is an electric mandolin I'm building. Something very wrong happened during both the gluing and cutting of the final contour.
Result, the center seam is off-center making it horrible to look at if a do a transparent finish...
Besides painting it opaque and/or starting over...any other ideas?
CNC is a tool, not cheating :)
PostPosted: Wed Nov 18, 2015 9:14 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Looks okay to me!
When I do something like that,
I leave it,
and move on.
Then I try not to do it again !
PostPosted: Wed Nov 18, 2015 11:32 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Is the squared off end of the fretboard the intended final shape? Maybe you could come up with an asymmetrical shape for the end that make it less obvious that the center seam is not centered on the fretboard. Googgle "mandolin fretboard extension" under images for some potential ideas.
Would you consider a centerline inlay with its position biased to the left of the seam so it would end up being centered on the top? Structurally, it would be like a backstrip inlaid into the back seam of guitars. A centerline inlay in the top is a feature of the top-of-the-line PRS Santana electric guitar so it wouldn't be unprecedented. Maybe you could come up with an inlay that echoes the look of the fretboard. For example a wide center strip made of the same wood as your fretmarker inlays flanked by thin strips of the same type of wood as the fretboard.
PostPosted: Thu Nov 19, 2015 1:13 am
First name: Tim
Last Name: Allen
City: San Francisco
The center seam being off is less noticeable, to me, than the f-holes being different distances from the sides. Unless that is just from the camera angle?
Short of taking the top off and making a new one, I think the taking idea of asymmetry in the rest of the mandolin would fool the eye of most viewers. Along with the asymmetric fretboard end (a very good suggestion IMHO) you could do something similar with the tailpiece and pickguard. If it were me I'd do a mock-up in PhotoShop or some similar program to see what worked best.
I understand you feel horrible looking at it because you see your mistakes, but overall it seems like a good looking instrument, and I think if you present it well most people will see what looks good and won't notice what's "off" about the glue-up.
Tim Allen
"Never hurry, never rest."
PostPosted: Thu Nov 19, 2015 1:27 am
First name: Jay
City: Bothell
State: Washington
There are quite a few asymmetric tailpiece designs out there including one that can be bought from Allen Guitars.
PostPosted: Thu Nov 19, 2015 3:24 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I have fixed problems like this by doing a wood burn in a strategic place that would bring the elements back in balance. In your case I would do a wood burned design or some text on the side that is too close to the edge. I would put my wood burn just to the left of the f hole on the right. This will balance the elements visually.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Thu Nov 19, 2015 7:33 am
Finish it and move on.
PostPosted: Thu Nov 19, 2015 8:46 am
plus as mentioned to my eye "F" holes are pretty odd looking.
But -it is what it is -- there are certainly more unusual things being made and sold.
Live, learn, be happy! $.02
Ken Cierp
PostPosted: Thu Nov 19, 2015 10:32 am
Then don't use a transparent finish.
PostPosted: Thu Nov 19, 2015 10:44 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
The top of your headpiece is asymmetrical, so I like the suggestion of some asymmetry at the end of the fret board. That being said, I might just do as Haans' suggested and move on.
PostPosted: Thu Nov 19, 2015 11:41 am
The center seam is slightly off but I would not worry about it. The fret position markers though, those are way off center :D
PostPosted: Thu Nov 19, 2015 11:56 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Plus 1 on finishing and moving on. While building mistakes look huge because your are looking at them With the entire instrument put together with strings, tail piece, bridge it looks like you would have a great looking instrument.
PostPosted: Thu Nov 19, 2015 12:54 pm
First name: Daniel
Thanks for your honest opinions guys :)
And the fret markers isn't a mistake...the guy is a guitar player, that wanted it like this.
So, in your opinion you would still do a transparent finish, with the center seam visible like this?
Maybe some kind of dark dye?
PostPosted: Thu Nov 19, 2015 1:07 pm
The off center seam is not going to affect the instrument's function, the question is do YOU like the look? There are plenty of great (and not so great ) instruments with 'flaws' like that in the world.
Sent fra min SM-G920F via Tapatalk
PostPosted: Thu Nov 19, 2015 2:43 pm
It seems like this may be a commission --- if so, the sound board needs to be replaced.
Ken Cierp
PostPosted: Thu Nov 19, 2015 5:32 pm
City: Tyler
I don't see the position of the seam as a big deal, but the way it shifted the f holes is IMO. If it is for a customer, I'd replace it.
PostPosted: Thu Nov 19, 2015 7:42 pm
First name: Daniel
Funny how camera angles are...
In person, the f-holes don't look too much off center...i think it's just the photo.
I'm going to dry fit the neck properly first, then I might do a center line with abalone or a wood strip...
What do you think?
PostPosted: Thu Nov 19, 2015 10:09 pm
First name: D
Last Name: S
Hey Daniel, cool build!
The pickups and bridge may be enough to break up the line and make it less noticible.
Try placing your harware on it.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Nov 22, 2015 7:04 am
It is fine. Finish it in a burst or tinted amber. It is not a conventional design so it will not be noticed once the pickguard, bridge, strings are on. The way to test these things for yourself if you are doing an original design or even a traditional one is to stand back and look at the whole thing, let your eyes go around the instrument and if there is a hesitation and you find yourself stopping to look at a detail, then it IS a problem.
Ken
PostPosted: Mon Nov 23, 2015 12:54 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
It doesn't look too bad in the photo....its only noticeable at the fingerboard end. I'd do a sunburst. That would shade the area under the fingerboard but still see the nice grain in the middle of the body
PostPosted: Mon Dec 14, 2015 6:10 pm
First name: Daniel
Here are some updates!
I ended up gluing a strip of walnut burl to correct the awkward center line.
The f-holes look off-center, but it's actually just the camera angle.
What do you think?
And a small mock-up before the center strip:
PostPosted: Mon Dec 14, 2015 6:49 pm
First name: D
Last Name: S
Look's great!
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Dec 14, 2015 8:28 pm
I think it looks better without the center strip.
PostPosted: Mon Dec 14, 2015 8:38 pm
First name: Jay
City: Bothell
State: Washington
Cool piece of walnut. What are your plans for the headstock and what sort of pickguard are you going to put on it?
PostPosted: Mon Dec 14, 2015 8:48 pm
First name: Daniel
I'm actually open to suggestions...
For the pickguard i'm still debating about using wood or plastic. Probably i'll make one out of the same wood as the inlays...
It will be a floating pickguard like the F5 mandos.
Suggestions?
