It is currently Sun Aug 17, 2025 4:21 pm
 Post subject: Undersaddle pickup
PostPosted: Mon Oct 26, 2015 1:54 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends. i hope all of u are doing well.
i have purchased an undersaddle pickup fishman 301 presys.
i want to ask that the undersaddle pickup is little longer than the bridge slot.
should i use it as it is and bend the pickup or should i cut from the end of exact size
to fit in saddle?
waiting for ur advice
 Post subject: Re: Undersaddle pickup
PostPosted: Mon Oct 26, 2015 2:34 pm
Don't do ANYTHING to the pickup, or it will no longer function.
Rout the slot out to fit.
PostPosted: Mon Oct 26, 2015 3:01 pm
You don't need to do anything. It's OK if the pickup is a little longer than the slot. Put a little ramp, i.e. file off the edge, of the hole that the pickup goes through so that it's not bending over a sharp edge.
These users thanked the author Pat Hawley for the post: jack (Mon Oct 26, 2015 5:05 pm)
PostPosted: Mon Oct 26, 2015 3:08 pm
"Sonicore" pick ups can be bent -- do not trim
http://www.fishman.com/files/sonicore_g ... nglish.pdf
Ken Cierp
PostPosted: Mon Oct 26, 2015 3:19 pm
Exactly. Drill the hole through the saddle slot at as steep an angle as you can without hitting the x brace inside. Chamfer it just slightly. On the other end of the slot, drill another hole at an angle, but not all the way through, to tuck the crimped end into.
PostPosted: Tue Oct 27, 2015 7:06 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
The Fishman website has installation instructions for both the transducer and the preamp. The transducer instructions show a single hole under one end of the saddle, so I think putting the end of the transducer flush against the non-hole end of the slot, then bending the element 90 degrees at the hole, letting the extra go down the hole with the cable, is what Fishman recommends.
Having said all that, I hope you are putting this into a guitar that is neither objectively valuable nor precious to you. That rectangular hole you have to cut in the upper bout pretty much marries this guitar to this type of pickup. I would go with something less destructive, but that's my curmudgeonly side showing itself.
PostPosted: Tue Oct 27, 2015 7:40 am
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Country: india
Thanks friends
