It is currently Sun Aug 17, 2025 6:26 pm
PostPosted: Sun Oct 25, 2015 11:41 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/m looking for an inexpensive remote control transmitter, our shop fox 1.5 hp dust collector stays on in the on position whether it/s off or on .I checked the wires to the switch and they seem fine. When I checked for continuity with the wires plugged into the switch the switch does not work. It/s either get another cheap switch or buy a remote . the switch lasted for 5 yrs. Thanks
PostPosted: Sun Oct 25, 2015 1:33 pm
Not sure what inexpensive means to you, but we got a remote switch from Oneida. They're about 80$...
You have to go to their site, click on a stationary unit, and scroll the accessories. Must say I love having it.
PostPosted: Sun Oct 25, 2015 1:35 pm
http://www.oneida-air.com/inventoryD.as ... BD394EB%7D
PostPosted: Sun Oct 25, 2015 1:36 pm
I'll be damned! I did a computer thing, and it worked!
PostPosted: Sun Oct 25, 2015 2:45 pm
110v 13 amp we have several of these -- less than $10
http://www.amazon.com/Woods-32555-Outdo ... ote+switch
Ken Cierp
These users thanked the author kencierp for the post: unkabob (Sun Oct 25, 2015 3:39 pm)
PostPosted: Sun Oct 25, 2015 3:16 pm
Wow, that's cheap!
PostPosted: Sun Oct 25, 2015 4:51 pm
Last Name: Farmer
City: Durango
State: CO
Omg have I battled that stinking Oneida remote over the last decade! [headinwall] Waving my arms wildly while clicking, disassembling the remotes to dry them out after putting them through the laundry yet again. Endless battery purchases. The list goes on. When facing replacing them w/ a new set at $80 I cracked. I ordered a bag of 30 alarm reed switches off eBay, wired every gate, and an electrician customer tied them to the old remote switch receiver. It took forever to do, was a pain in the @ss to run the wire. But pure joy is what I experience everyday now. The best part is it forces me to close every gate to turn it off. When I worked in a multi man shop it was extreamly annoying to open a gate and have no suction at all because others had left half a dozen other gates open.[uncle]
meddlingfool, I'm putting you down as a techie! [clap]
PostPosted: Sun Oct 25, 2015 4:53 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Might be obvious, but whatever remote you go with, I suggest you take that faulty switch out, even if it's stuck on. Sounds like it's having a meltdown and probably represents a fire hazard if left in the circuit. Couple of wire nuts and you're good to go.
PostPosted: Sun Oct 25, 2015 7:10 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks tim, works ok , but your right I got some wire nuts.Willl connect together the 2 whites, and the 2 blacks the green gnd is already done .I looked at the motor and it says 16amps , but somehow that may not be so, especially since it/s a chinese motor . A friend said the stamped Hp an amps are not always accurate. Anyone testing these motors.? Otherwise the 13 amp rated rf remote transmitter won/t work as I have the current Dust Collector plug inserted in a heavy duty extension cord. I will check amazon for a 15 amp line .Ken forgot to ask , are these used in your shop on a dedicated 15 amp line , and does some of your equipment draw 15 amps on this single rf circuit ?? thanks
PostPosted: Sun Oct 25, 2015 7:52 pm
Ernie I'm not pushing them at all -- using them to control fans and air cleaners.
Ken Cierp
PostPosted: Sun Oct 25, 2015 8:11 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks ken, so I/m guessing they draw 1-5 amps , is that correct ??
PostPosted: Sun Oct 25, 2015 8:33 pm
Not much, the largest motor is only 1/5 HP we have one of these to tally amps on a circuit
http://www.amazon.com/P3-P4400-Electric ... B00009MDBU
Ken Cierp
PostPosted: Sun Oct 25, 2015 8:56 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Those small remotes are not really appropriate for a 1.5 HP motor whose running draw will max out a 15A circuit. You could use it to safely energize the coil on a contactor, but some assembly required and l wouldn't recommend that to a novice sparky. You're better off with a purpose-built remote for dust collectors.
PostPosted: Mon Oct 26, 2015 8:04 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Tim . I agree with you. abt a dedicated 15 amp rf line . I/m going to lowes this morning to get nut wires . and take out the switch . I won/t be using the DC as it is connected to my 37in woodmaster sander and will see vy little use over the next 6mo . cheers est bon chance est merci beaucoup
PostPosted: Sun Nov 01, 2015 1:15 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
My experience is that the motor draws a lot more current when it is starting, and it will fry the remote. I bought a contactor for a few bucks, and I plan to wire it up.
Total cost for the remote, the contactor, and the wire is less than $20.
These users thanked the author John Arnold for the post: kencierp (Sun Nov 01, 2015 9:48 am)
PostPosted: Sun Nov 01, 2015 9:52 am
I have not taken time it investigate but I am pretty sure it would be easy to wire up a 220 volt version for about the same money.
Ken Cierp
PostPosted: Sun Nov 01, 2015 4:39 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
No worries I went to metro hdwd where I bought the DC, an found a new switch , which I promptly rewired . works fine.I have a jet 2 hp DC with a lone ranger that is for 220 v and in use for 15 years , the box and the transmitter for 115 v lone ranger bliss bliss are about $85 on amazon
PostPosted: Sun Nov 01, 2015 7:34 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Straying off topic a bit - Happy Birthday Ernie, and many, many, more! [:Y:] [clap] [:Y:]
Alex
PostPosted: Mon Nov 02, 2015 6:50 pm
Last Name: Arnold
City: Newport
You are correct. Contactors are available with a 220 volt coil. The contactor I bought is rated 30 amps, and up to 600 volts.
PostPosted: Tue Nov 03, 2015 5:52 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
tnx alex , for birthday greetings. feels like 68 when I get up in the am. lol packing up bsmt with lots of wood. hopefully seeking a bigger shop space regards ernie
Users browsing this forum: Bing [Bot], TripodBob and 14 guests
