It is currently Sun Aug 17, 2025 7:43 am
 Post subject: weld-on #16
PostPosted: Mon Oct 19, 2015 12:40 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
It looks like I have been using expired (7year old, just opened) weld-on 16 to glue ivoroid binding although some of it seems to be holding fine. I just spoke with Weld-on & they said it's only good for 2 years. Can I use anything else ? I'm in Canada (Ottawa).
Mike McNerney
 Post subject: Re: weld-on #16
PostPosted: Mon Oct 19, 2015 2:16 pm
First name: Rob
Last Name: Roither
City: Williamsburg
Zip/Postal Code: 23188
Duco Household Cement is a good substitute for #16 if you can get it up there.
PostPosted: Mon Oct 19, 2015 6:40 pm
Weldon 16 seems to have a little of a "contact quality" to it compared to Duco. Seems to dry faster too. You can bind one side and by the time that side is dry, you can start the other side....
Google it and you will find larger tubes for less $$$.
PostPosted: Mon Oct 19, 2015 9:05 pm
First name: D
Last Name: S
I can't imagine trying to glue multiple binding strips using that stuff.
I always make a big mess just with a single strip.
I've seen web videos of guys using acetone to glue binding, but I have not tried it.
Someone suggested using super glue, but I think plastic requires a solvent cement.
I had a bottle of thin acrylic cement, I may try to get some more. It is used for gluing stuff like acrylic aquariums by wicking the glue into the joint.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Oct 19, 2015 9:45 pm
First name: Fred
City: Winnipeg
Used CA on ABS binding.
PostPosted: Mon Oct 19, 2015 10:14 pm
First name: Ringo
I admit it, I thought I was going to see some kind of welded neck joint on someone's 16th guitar in this thread.
