It is currently Sat Jul 19, 2025 12:52 am
PostPosted: Sun Oct 04, 2015 4:54 pm
Last Name: Wilson
Country: Scotland
Hey guys. I'm doing an upgrade on a steinberger and have changed the HSH setup to a HS.
Have a 4way switch with 2 pots and I'd like to have pos 1 as neck single coil, 2 neck and coil tapped bridge, 3 full bridge in series + neck, 4 bridge in series. I can't seem to find this setup anywhere online as a diagram and I'm having a brain melt trying to work it out. This is what I have so far..
Now I know that as it is I won't have the neck pickup on pos3 but I can't see how to connect it without joining it to pos4 too. Am I missing something here? Can someone show me a better way to do this please. I'm pulling what little hair I have left out here gaah
PostPosted: Mon Oct 05, 2015 5:48 pm
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Hi
Only saw this post a while ago. On the humbucker you don't need to connect the coils via lower switch 2 (3 4) and C. Just join them and connect the joined pair to position 2 on switch. Use the switch to choose one coil or both.
3 and 4 on switch 2 for full humbucker, pin 2 for one coil.
Add a wire to position 3 to your N
I always where possible connect the C or rotary centre to the output.
The only time you need to switch the 2 coils of humbucker, is when you want to change phase, I use a pull switch on volume when this is needed. Make sure the pot cases are connected to each other and ground.
Hope this helps
These users thanked the author Mike2E for the post: mechanix (Wed Oct 07, 2015 4:38 am)
PostPosted: Mon Oct 05, 2015 6:24 pm
First name: D
Last Name: S
Not sure the tone pot will work. Seems like it needs a ground connection?
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Mike2E (Tue Oct 06, 2015 5:59 am)
PostPosted: Tue Oct 06, 2015 5:58 am
Last Name: Lee
City: Albany Creek
State: QLD
Tone pot is missing an earth on my diagram. Well spotted.. Mechanix has it correct, provided the case of the pot is earthed.
PostPosted: Tue Oct 06, 2015 10:10 am
State: AR
FWIW- http://www.dimarzio.com/sites/default/files/diagrams/1h1s1v1t_ep1112.pdf
Takes a different switch but you get a better selection.
And there is a difference between coil-tap and splitting.
Hope this helps.
These users thanked the author Sandywood for the post: mechanix (Wed Oct 07, 2015 4:38 am)
PostPosted: Wed Oct 07, 2015 4:37 am
Last Name: Wilson
Country: Scotland
Guys.. Thank you. Got it wired last night and sounds awesome. Thanks again.
