It is currently Sat Jul 05, 2025 10:25 pm
PostPosted: Wed Sep 30, 2015 11:56 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I was asked in another thread to explain how I did the binding around the sound hole below so as to have the same pattern as the main ring of the rosette.
In the photo below, the rosewood tiles and cocobolo dividers are glued together on the template and ready for routing out the main ring of the rosette. You can see three circular lines on the lower tiles. The two outer ones represent the main ring. The innermost line is the diameter of the sound hole (4"). To make the ring that I used to bind the sound hole, I routed a ring 0.080" wide using the inner line as the inside edge of the ring. Unfortunately, I didn't take a picture of the ring after it was done. The square in the middle was the same thickness as the tiles and it was there to support the router base.
I then routed a channel in the joined top plates that was just barely wider than the binding ring and almost the full depth of the top. I inlaid the ring into the channel with the ring rotated relative to the main ring to align the dividers in the binding with the centers of the main ring tiles. Later, I routed out the sound hole leaving the binding.
These users thanked the author J De Rocher for the post: hermit (Thu Oct 01, 2015 9:51 am)
PostPosted: Thu Oct 01, 2015 10:22 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks for this! I have not yet tried to bind a soundhole (save for a little curly-q hole in a mando), is there anything special you have to do to deal with the endgrain glue joints? with radial binding like this you are actually gluing endgrain in both pieces.
Bryan Bear PMoMC
PostPosted: Thu Oct 01, 2015 11:17 am
First name: Wendy
Last Name: W
State: Arizona
Thankyou for that Jay! I would still like to see pictures of the whole instrument when you get a chance. From the small portion I've seen the design is stunning.
Wendy
These users thanked the author WendyW for the post: J De Rocher (Thu Oct 01, 2015 6:19 pm)
PostPosted: Thu Oct 01, 2015 2:01 pm
First name: Jay
City: Bothell
State: Washington
Are you asking about the joint between the binding and the spruce at the fretboard and bridge sides of the sound hole? Since I didn't route the channel all the way through the top for inlaying the binding ring, the ring actually sits on a thin shelf of spruce so there is side grain gluing under the ring in addition to the end grain gluing around the outside edge of the ring. The shelf is about 0.015" thick. When I did the round over sanding of the binding after opening the sound hole, I used just as much pressure as I use when rounding over the body binding and it didn't budge a bit. It's very solid.
These users thanked the author J De Rocher for the post (total 2): Bryan Bear (Sat Oct 03, 2015 12:40 pm) • Mark Fogleman (Fri Oct 02, 2015 1:32 pm)
PostPosted: Thu Oct 01, 2015 6:30 pm
First name: Jay
City: Bothell
State: Washington
Wendy
I wouldn't say it's stunning compared with a lot of the guitars I've seen on this forum, but hopefully you like the rest of it. Here are some non-glamour type shots taken on the carpet.
These users thanked the author J De Rocher for the post: Pmaj7 (Sat Oct 03, 2015 7:15 pm)
PostPosted: Sat Oct 03, 2015 5:34 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have bound a couple of soundholes with a piece of regular binding using this technique, but this open up a new path - thanks. Very nice guitar by the way.
Ec
These users thanked the author Ruby50 for the post: J De Rocher (Sat Oct 03, 2015 6:29 pm)
PostPosted: Sat Oct 03, 2015 12:42 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I see. So I guess when you sand the roundover, the little bit of spruce under the binding gets blended away. Nice!
Bryan Bear PMoMC
PostPosted: Sat Oct 03, 2015 12:59 pm
First name: Jay
City: Bothell
State: Washington
That's right. It gets blended away at the round over but is still there under the back edge of the binding (about half the width) if that makes sense.
These users thanked the author J De Rocher for the post: Bryan Bear (Sun Oct 04, 2015 9:59 am)
PostPosted: Sat Oct 03, 2015 5:07 pm
First name: Mark
City: Concord
Leaving the shelf of Spruce is a great idea! Thanks for sharing!
PostPosted: Sat Oct 03, 2015 7:18 pm
J De Rocher wrote:
Smart looking heel!
PostPosted: Mon Oct 05, 2015 6:58 am
Last Name: Minch
City: Chestertown
I have done this a couple of times and was advised on a method that worked. Sand the spruce so the top is what you want it to look like, make the soundhole binding groove just less than the depth of the spruce, install the binding, then when you sand for final thickness, do most of it on the back and it gets sanded away.
Ed
PostPosted: Mon Oct 05, 2015 4:49 pm
First name: Wendy
Last Name: W
State: Arizona
Very nice looking guitar! I think everything works together beautifully from the wood choices to the shape of the heel and end of the fretboard. Thanks for posting it. Great work!
These users thanked the author WendyW for the post: J De Rocher (Tue Oct 06, 2015 8:28 pm)
PostPosted: Thu Oct 08, 2015 4:12 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Thanks Jay
I think I am the one who asked for a tute on this and you have explained it very clearly. Nice trick!
Mark
These users thanked the author Mark Mc for the post: J De Rocher (Fri Oct 09, 2015 9:37 pm)
