It is currently Sun Aug 17, 2025 9:38 pm
 Post subject: Carp top thickness?
PostPosted: Fri Sep 25, 2015 11:44 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
What would be a good final target thickness for a carpathian spruce top, for a small jumbo? It is quite stiff at .185" Thanks!
Alex
 Post subject: Re: Carp top thickness?
PostPosted: Fri Sep 25, 2015 12:16 pm
At .185 I would expect so.
There is a real problem with taking tops to a specific thickness, the problem being that the stiffness will be a random factor. Better to take the tops to a specific stiffness and let the thickness be a random factor. Because of the cubed rule of stiffness, even a few thousandths of an inch of thickness can vary the overall stiffness of a top by quite a bit.
I find deflection testing to be quite useful. Lots of info on the net, but in short...
The 'standard' setup is beams at 18" with a 5lb weight. Variations will work of course, the important thing is to take data and track your own work, and keep records.
As always, I recommend the Gore/Gilet books. Worth way more than anything else you could spend your money on in guitarmaking. Maybe not as sexy as a sweet set of guitar woods, but will definitely help you get the most tone out of your tone woods in short order.
As a start, .110 is the standard 'factory' thickness for spruce. It will still almost certainly be stiffer than it needs to be, but it's a place to start. I would build the deflection jig, measure the stiffness at that thickness, take notes, build the guitar, and assess it carefully, hopefully amongst peers, trying to decide if you could eek out more bass or if it's too bassy already. That type of thing. Of course, many other factors come into play such as your brace mass/height/stiffness and the stiffness of the back as well.
Which is why quantification is such a valuable tool. The how's and why's of which can be found in the books...
These users thanked the author meddlingfool for the post: Alex Kleon (Fri Sep 25, 2015 1:04 pm)
PostPosted: Fri Sep 25, 2015 12:17 pm
Righto, double post for whatever reason. The blue face is supposed to be the word
E
E
K
PostPosted: Fri Sep 25, 2015 12:50 pm
Last Name: Colbert
City: Anacortes
Here is what I use.
It's 18" between the risers and allows the dial indicator to hit the center of a 17" wide plate. For accuracy I also cut all of my plates to 17" wide, that being as wide an instrument as I'm likely to build. I also like the brass hex bar stock. Doesn't roll around...
These users thanked the author Michaeldc for the post: Alex Kleon (Fri Sep 25, 2015 1:04 pm)
PostPosted: Fri Sep 25, 2015 1:16 pm
First name: Tom
Last Name: West
State: Nova Scotia
Deflection................yes ..............but no one is telling Alex how much deflection.
Tom
These users thanked the author Tom West for the post: Alex Kleon (Fri Sep 25, 2015 5:09 pm)
PostPosted: Fri Sep 25, 2015 2:25 pm
And no one really can, as we all do things differently, and my numbers might not work for him or his work methods.
Hence testing, evaluating, recording, and repeating in order to find his own numbers.
He's been give a safe thickness number to start his evaluations at, and directions to the Fount of Wisdom.
The rest is up to him.
These users thanked the author meddlingfool for the post: Alex Kleon (Fri Sep 25, 2015 5:09 pm)
PostPosted: Fri Sep 25, 2015 2:41 pm
First name: Tom
Last Name: West
State: Nova Scotia
Alex:
I use 18" spread on the rests and look for .200 deflection with 5 lbs. of weight. As Ed says the rest is up to you but this works for me and what I do.
Tom
These users thanked the author Tom West for the post: Alex Kleon (Fri Sep 25, 2015 5:08 pm)
PostPosted: Fri Sep 25, 2015 5:08 pm
First name: Alex
Last Name: Kleon
City: Whitby
Thanks Ed and Tom. Gore/Gilet is the only thing on my Christmas list, this year! I thinned the top to .110", and measured .165" deflection at 18" and 5lbs. I've entered the info in my build log, and will check again after I do a little sanding.
Alex
PostPosted: Fri Sep 25, 2015 5:25 pm
First name: Tom
Last Name: West
State: Nova Scotia
Alex:
Carpathian spruce (European spruce) always seems to be quite stiff to me. If it was me, doubt if I would go below .100". One can always work the braces more. Also I like to thin the edges of the top a bit. The how much of this also depends on guitar type, finger style gets the least stiffness and a dread more. Another good reference is the Kent Everett video on top voicing. I even work a bit of that into the mix. You can't go wrong on Trevor's books, best overall reference that I have.
Tom
These users thanked the author Tom West for the post: Alex Kleon (Fri Sep 25, 2015 5:36 pm)
PostPosted: Fri Sep 25, 2015 5:49 pm
First name: Alex
Last Name: Kleon
City: Whitby
Thanks, Tom. I'm working from the OLF SJ plans, and the bracing looks to be on the heavy side, so I'll lighten it up. I knew that I wasn't going to get a definitive answer because of all of the variables involved, so a ball park figure goes a long way to getting me in the right direction.
Alex
PostPosted: Fri Sep 25, 2015 9:16 pm
Alex,
I think that's a little stiff still. Try doing what Tom suggested...
PostPosted: Fri Sep 25, 2015 9:42 pm
First name: Alex
Last Name: Kleon
City: Whitby
meddlingfool wrote:
Alex,
I'll whittle it down a bit tomorrow, and see what happens. :)
Alex
PostPosted: Fri Sep 25, 2015 9:51 pm
Last Name: Colbert
City: Anacortes
Alex,
Not sure if you're aware, going from a deflection of .165 to .200 happens really quick! My deflection target before final sanding is .180 with a 4.5 pound weight, an uncut sound hole, and 18" centers on the test rig.
These users thanked the author Michaeldc for the post: Alex Kleon (Fri Sep 25, 2015 9:54 pm)
PostPosted: Fri Sep 25, 2015 11:56 pm
Also Alex, you're right about the bracing. On the plans they are truly epic. I think about 3/4" in height? Much too much, think more like .550 height...and that still leaves room for work.
These users thanked the author meddlingfool for the post: Alex Kleon (Sat Sep 26, 2015 12:16 am)
PostPosted: Sat Sep 26, 2015 4:15 am
Todd Stock stuck his neck out and posted suggested bracing sizes for an OM or OLF SJ to help newbies, but we have lost all his posts.
I wrote notes of these and will pass them on if it helps.
X Braces - 0.250 x 0.550"
Tonebars - 0.250 x 0.500"
Finger braces - 0.250 x 0.575"
UTB - 7/16 x 5/8
Bridgeplate - 0.100 rift sawn hard maple.
No guarantees here, just an indication.
These users thanked the author Colin North for the post: Alex Kleon (Sat Sep 26, 2015 6:52 am)
PostPosted: Sat Sep 26, 2015 6:05 am
State: Tennessee
UTB - 7/16 x 5/8
OM's and up you can have "telegraphing" with 1/4 bracing, of course it depends on your top :mrgreen:
These users thanked the author Clinchriver for the post: Alex Kleon (Sat Sep 26, 2015 6:52 am)
PostPosted: Sat Sep 26, 2015 9:21 am
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
I built the deflection jig. How much, if any, diffence is there between say, a jumbo top and a parlor??
These users thanked the author violinvic for the post: Alex Kleon (Sat Sep 26, 2015 12:29 pm)
PostPosted: Sat Sep 26, 2015 12:03 pm
I'm guessing this a typo on the finger braces. That's awfully tall for a finger brace.
These users thanked the author Jim Watts for the post: Alex Kleon (Sat Sep 26, 2015 12:28 pm)
PostPosted: Sat Sep 26, 2015 12:18 pm
That's what I thought too, but that's what I wrote - I went with 0.525 or 0.500 I believe on the SJ I made, well peaked.
Englemann soundboard at around 0.1" before finish sanded, so quite thin, hence double X-braces on this.
But a pretty lively guitar, reasonably good bass to treble balance, loud, and yes, braces telegraphed though a bit.
First member of the public to try it bought it on the spot, although he'd only come in to buy strings and picks.
These users thanked the author Colin North for the post: Alex Kleon (Sat Sep 26, 2015 12:28 pm)
PostPosted: Sat Sep 26, 2015 12:29 pm
well ok then. Just checking.
PostPosted: Sat Sep 26, 2015 6:48 pm
Deflection was 2.5 mm, 5lbs, 18" across and same roller spacing on that Englemann top.
PostPosted: Sat Sep 26, 2015 7:10 pm
For what it's worth, I made notes on what I think may have been the same post by Todd, and I have the finger brace dimensions as 0.250" x 0.375".
Users browsing this forum: No registered users and 42 guests
