It is currently Mon Aug 18, 2025 3:22 pm
PostPosted: Tue Aug 18, 2015 9:48 pm
Does anyone buff out the body and neck separately (before gluing the neck to the body) when using a buffing machine with large buffing wheels?
Formerly know as Mandodiddle.
PostPosted: Tue Aug 18, 2015 9:59 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Yup.
Doug
PostPosted: Tue Aug 18, 2015 10:00 pm
Yep. Just about everyone does it that way.
PostPosted: Tue Aug 18, 2015 10:09 pm
Yeah, it's just easier.
PostPosted: Tue Aug 18, 2015 11:33 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It's the only way to do it. Ok, that sounded pompous. Just try and do it with neck attached. DAMHIK
PostPosted: Tue Aug 18, 2015 11:37 pm
Yes, do that. There are no advantages (I think) and many disadvantages to doing it after assembly.
PostPosted: Wed Aug 19, 2015 6:16 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I started out by building classicals which require finishing with the neck attached if using a Spanish heel. I continued that method when building steel strings until recently, when I started finishing with the neck detached. The biggest benefit for me was the ability to buff out the area at the neck join before joining the neck.. Also makes for a very crisp neck to body transition.
PostPosted: Wed Aug 19, 2015 6:56 am
Yep.
PostPosted: Wed Aug 19, 2015 7:33 am
State: ON
Same here. I will buff the neck shaft with my big buffing wheels, but usually switch to some hand buffing where the neck shaft transitions to the headstock. It is really easy to buff through the finish on the corners of the headstock if you're not real careful.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed Aug 19, 2015 12:05 pm
Thanks guys,
Do you see any advantage to reducing the number of buffing wheels to just one wheel thick when doing the neck?
PostPosted: Thu Aug 20, 2015 12:52 am
I only use one buff per side.....Hasn't been an issue for me.
PostPosted: Thu Aug 20, 2015 9:44 am
Yup - buffed out as two separate operations here too. Besides it gives me twice the opportunity to have the instrument ripped from my hands and shattered against the floor.....
Seriously though lots of Luthiers have had a guitar either thrown by the buffer or darn near thrown by the buffer. Some use copious amounts of padding, old mattresses, etc. around their buffers in case this happens. I use rubber gloves to get a better purchase on the thing.
PostPosted: Thu Aug 20, 2015 11:45 am
Quote:
Besides it give me twice the opportunity to have the instrument ripped from my hands and shattered against the floor.....
Yep -- everybody loves their spindle buffer until this happens two minutes before the project is complete. RO auto polishers works for me. I believe it was John Greven that talks about this being the most pressure packed (and unwanted jobs) in the guitar factory where he once worked.
Ken Cierp
PostPosted: Thu Aug 20, 2015 12:01 pm
I've come close, but never had it happen. I used a screwed in dovetail grip and an eyebolt in the endpin hole. I sat in a chair, and used the bottom of the buff. That way I could lean into it with my upper leg. Learning which way to buff an area is VERY important.
PostPosted: Thu Aug 20, 2015 12:15 pm
Right you guys are. It's also one of these things that the only way to learn is to accept the risks and go at it.
