It is currently Sun Jul 20, 2025 10:55 pm
 Post subject: Finishing after tung oil
PostPosted: Thu Jul 16, 2015 9:22 am
First name: Alexander
Last Name: Baev
City: Zaporozhye
Zip/Postal Code: 69093
Country: Ukraine
Hello friends.
How should I prepare the wood stained with tung oil if I want to finish it with acrylic lacqyer?
Thanks!
PostPosted: Fri Jul 17, 2015 7:01 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
You will need to sand it to provide a good anchor for the acrylic. If the wood is completely sealed and coated with tung oil sand at 320, otherwise prep at 180 as you would bare wood.
Brian
These users thanked the author B. Howard for the post: baev_al (Fri Jul 17, 2015 8:14 am)
PostPosted: Fri Jul 17, 2015 8:15 am
Last Name: Baev
City: Zaporozhye
Country: Ukraine
I was ready for this )))
But maybe I can remove it with some solvent? Just maybe....
PostPosted: Wed Jul 22, 2015 11:07 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Shellac makes a great barrier coat, tends to stick to just about anything, and is the ideal undercoat for any kind of lacquer. Unless the thing is dripping with tung, I'd mix up some fresh shellac and wipe on a coat to see if it dries well.
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
