It is currently Wed Jul 02, 2025 1:47 pm
 Post subject: Mandolin setup specs?
PostPosted: Wed Jun 17, 2015 11:24 am
Looking for setup specs for an A5 Mandolin - this one will be played bluegrass style
I've found this on the web but don't know if they're any good.
String Height (measures top of fret to bottom of string):
Bass-side string height at 12th fret: 5/64"
Treble-side string height at 12th fret: 2/32"
Relief (measures distance from top of fret to bottom of string while fretting the 1st and 13th fret):
Relief at 5th Fret: .005"
PostPosted: Thu Jun 18, 2015 5:20 am
Those are about right. Monroe referred to "Manly action" on his, but most folks find that too high. I get down to 3/64" on the treble.
You need very little relief. I don't start with any...
These users thanked the author Haans for the post: SteveSmith (Thu Jun 18, 2015 5:24 am)
PostPosted: Thu Jun 18, 2015 5:25 am
Thanks Hans, I was hoping you would see this.
PostPosted: Thu Jun 18, 2015 7:18 am
Last Name: Farmer
City: Durango
State: CO
I'll just second that a lot of folks around here have the treble side down around .040" if they can.
These users thanked the author david farmer for the post: SteveSmith (Thu Jun 18, 2015 9:03 am)
PostPosted: Thu Jun 18, 2015 7:35 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
It is possible to get a little lower than that. 8-) Very low action is achievable with the high tension of the strings. I use a dime at the 12th as a gauge for the G strings. Many players like very low action. Be sure your intonation is very good before you set your action. For the lowest action you will usually need a very slight amount of relief.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
These users thanked the author Cush for the post: SteveSmith (Thu Jun 18, 2015 9:04 am)
PostPosted: Thu Jun 18, 2015 6:06 pm
Thanks everyone - I'll be working on this tonight.
PostPosted: Fri Jun 19, 2015 8:08 am
Nice thing about action on the majority of mandolins...it's easily adjustable.
PostPosted: Fri Jun 19, 2015 8:21 am
I used an adjustable bridge on this one so it's hard to beat.
PostPosted: Fri Jun 19, 2015 9:05 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
If you go for the lowest possible action be sure to have all 8 strings at full tension when you test. There is some deflection of the top plate at full tension. On a new build I like to wait a few days before I do the final lowering of the nut slots. String tension can have effects on the top and the neck. Cutting a new nut is no fun and tends to slow things down.
Mark Twain
These users thanked the author Cush for the post: SteveSmith (Fri Jun 19, 2015 9:58 am)
PostPosted: Fri Jun 19, 2015 9:57 am
Good points Matt, thanks. I took the nut down but not all the way figuring I would wait till the finish was done and did the final tweaking on the action.
PostPosted: Fri Jun 19, 2015 10:22 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
That's good thinking Steve. It sounds like it is time to get a finish on her right now. :)
Mark Twain
PostPosted: Fri Jun 19, 2015 12:34 pm
Waiting on some dye that's due in today then a few test panels. Hope to have it done with nitro on it and curing by 6/29 cause I'm having shoulder surgery on 6/30 and it can cure while I cure too laughing6-hehe
