It is currently Mon Aug 18, 2025 4:57 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 27, 2015 8:11 am
First name: Tom
Last Name: West
State: Nova Scotia
Mike O'Melia wrote:
Bending is about getting the wood hot enough that it becomes "plastic". Super Soft is a spray that veneer workers use to aid in the process. Again, a number of us use that. Very effective.
YES............Lots of general info out there about STEAM BENDING, but in reality for bending sides HEAT is the important factor. While bending IRW does not require Super Soft I have started to use it for all my bending. As Mike says very effective.
Tom
These users thanked the author Tom West for the post: Cablepuller (Wed May 27, 2015 11:23 am)
PostPosted: Wed May 27, 2015 8:39 am
Page two of the link I posted earlier in this thread shows the control box and the wiring is explained -- the controller has a timer which in my view is mandatory.
http://www.acousticguitarconstructionfo ... 4&start=10
Ken Cierp
PostPosted: Wed May 27, 2015 10:44 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
While I now use a heating blanket set-up, I did my first two on a pipe bender with the ole electric charcoal starter as the heat source (total investment less than $20). Takes time and patience to get the bend, but it will do the job. Have to ask, how thick are your sides? I usually work somewhere between 0.08 and 0.09 inches.
PostPosted: Wed May 27, 2015 1:16 pm
Yes around about the same thickness on the sides..but may have been a bit thinner in this spot.
PostPosted: Wed May 27, 2015 1:32 pm
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
I don't know where in the UK you are based, but if you are any where around Milton Keynes you are welcome to borrow my electric bending iron to give that a try?
PostPosted: Wed May 27, 2015 1:33 pm
Thanks flounder but down in sunny devon
PostPosted: Wed May 27, 2015 10:31 pm
City: Escondido
Zip/Postal Code: 92029
I know it has been said before but a bending machine is neither difficult to build nor overly expensive. If you are already thinking a digital temperature control, a half mold, and a heating blanket you are 90% there.
I know there are many builders that say they love the art of bending on a pipe, but I note you said you are not enjoying the process. A bending machine has a much lower learning curve and good repeatability.
These users thanked the author rlrhett for the post: Cablepuller (Thu May 28, 2015 12:58 am)
PostPosted: Sat Jun 06, 2015 3:04 pm
Tom
Hi tom
Have found uk equivalent of supersoft here..
How do you use it to bend..is it an additional thing you use with heat or use it alone
And how long is it on before wood is workable
PostPosted: Sat Jun 06, 2015 3:07 pm
Mike O'Melia wrote:
Well, that's a very creative idea. Two thoughts. If u are stateside, order a bottle of Super Soft II. Spray on wood, wrap in paper towels, wrap that in foil, let set for 24 hours. Then, instead of using the body itself, make a tracing on plywood. One half the body, bring it in the thickness of your wood. Join two sides of plywood every 1.5-2" with spars. Now u will have an appropriately sized mold, strong work surface, and guarantee symmetry by using a single half mold.
Thanks mike
Am looking at buying some supersoft equivalent in uk
Just Fter more tips please
Is the wood more pliable before you use heat or does it just help during bend
Got some binding to bend ..how would you approach it (using spray)
PostPosted: Sat Jun 06, 2015 3:56 pm
I spray it on the night before - liberally. Let it dry then bend with heat as you normally would. The SuperSoft will just make it easier. Thin pieces of wood, sides and some bindings, will feel more flexible after you apply the SS and let it dry.
These users thanked the author SteveSmith for the post (total 2): pdolan (Sat Jun 06, 2015 9:04 pm) • Cablepuller (Sat Jun 06, 2015 3:56 pm)
PostPosted: Mon Jun 08, 2015 12:22 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
As others have said you need to up your bending equipment. The break is in the right place to put in a very deep scoop or make into a florentine shape.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
These users thanked the author Goat Rock Ukulele for the post: Cablepuller (Wed Jun 10, 2015 4:15 pm)
PostPosted: Wed Jun 10, 2015 3:40 pm
First name: Kevin
Last Name: Feeney
City: Teddington
Country: UK
Hi cablepuller. If it's any consolation I just completely split one of a pair of beautiful flamed maple ribs clean through. I was bending it on an electric heating iron and did the first rib spot on. Then I bent the second one and nearly finished before realising I'd bent it exactly the same as the first one - in other words I'd have 2 treble sides!!! So I carefully started to bend it back the other way , but not nearly careful enough and crack - it ended in two pieces!
I suppose I could have tried to glue it, but this guitar is too important so I went out and bought a new set. One week later and I'm back where I started, but I've just put it down to experience....
These users thanked the author Polaris for the post: Cablepuller (Wed Jun 10, 2015 3:59 pm)
PostPosted: Wed Jun 10, 2015 4:14 pm
Hi polaris
Feel your pain my friend. Found it a tough unforgiving stage and theres an art to bending that i need to master..thanks for sharing it .. seems like this scratch building is going to be a real test
I did salvage mine..not perfect though but good enough.. i superglued the inside and made sure the side support covered it too..then i carefully sanded out the crease.. it will be thinner at this point but supported from behind so should be ok
I cant see the crease but can just about feel it..too scared to sand anymore
PostPosted: Fri Jun 12, 2015 1:28 am
First name: Kevin
Last Name: Feeney
City: Teddington
Country: UK
I didn't want to say otherwise when more experienced members were recommending throwing your bent piece away, but I had a similar experience with my first guitar. I bent the rosewood sides on a "Fox Bender" and a biggish flap came away on the inside of one waist and left a crease on the outside face. WIth my teacher's advice (at South Thames College) I stuck this back down and then cabinet scraped and sanded the crease away. Scary but it worked and you can't see it on the finished guitar!
These users thanked the author Polaris for the post: Cablepuller (Fri Jun 12, 2015 11:03 am)
PostPosted: Fri Jun 12, 2015 10:42 am
You are not the first nor will you be the last to make that classic mistake ;)
These users thanked the author jfmckenna for the post: Cablepuller (Fri Jun 12, 2015 11:04 am)
PostPosted: Fri Jun 12, 2015 11:06 am
Thanks polaris good to know..i might keep sanding/scraping then to eradicate the crease.. still got some thickness to play with
PostPosted: Sat Jun 13, 2015 12:15 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Super Soft. I apply it to a well prepped board. Wrap in paper towels. Soak them too. Then wrap it all in aluminum (aluminium in the UK) foil and let it set 24 hours. Then, unwrap an towel dry. I also let it dry out a bit before hitting the bender. Then wrap in Kraft paper, steel slats either side, water spritz before that, and into the bender. Heat blanket on top of slats.
I think the thing to remember is that the super soft causes the lignum to become semi-plastic, the heat is then more effective. Stress risers less likely. The heat will also reset the lignum. It will also come out quite the mess. But scraping cleans it up. As for your steam bending, I'm not sure if I can tell u what to expect, yet, it's got to be better than what u were dealing with.
These users thanked the author Mike OMelia for the post: Cablepuller (Sat Jun 13, 2015 12:45 am)
PostPosted: Sat Jun 13, 2015 12:23 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Another thing. Don't worry if you can't tell that the wood is more flexible after a 24 hour soak. It's still 0.1" or so thick. Not quite the definition of a veneer. With veneers (0.6 mm or less) u can indeed feel the difference. The effect is "felt" by the bender. Does not have to get as hot or work as hard (IMO). If the wood contains internal stress risers (pin knots), all bets are off. I have a very expensive set of coco sides that will attest to that. Very nice crack.
These users thanked the author Mike OMelia for the post: Cablepuller (Sat Jun 13, 2015 12:46 am)
Users browsing this forum: No registered users and 39 guests
