It is currently Mon Aug 18, 2025 3:02 pm
PostPosted: Mon Mar 23, 2015 5:56 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Are these any good, or should I get Stewmac's? http://www.ebay.com/itm/GeetarGizmos-FR ... 20e93dc432
Thanks for any and all opinions!
Alex
PostPosted: Mon Mar 23, 2015 6:07 pm
Last Name: Kincheloe
Looks good to me. Or you could save even more cash and just buy a nibbling tool and cut a groove in the face yourself with a dremel wheel. That's what I did, and it works well for normal fretwire. Still needs a little cleanup with a file, but I'm not sure the StewMac tool would be any better.
The groove does need to be sized for the fretwire you're using, or else the fret end gets bent. I need to make another one for uke wire. I've been doing them the hard way with flush cut nippers, which also requires even more file cleanup.
These users thanked the author DennisK for the post: Alex Kleon (Mon Mar 23, 2015 6:11 pm)
PostPosted: Mon Mar 23, 2015 8:32 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
I had a student that bought one once. As I remember they didn't work all that well. That is a general trend from eBay tools, they tend to be based of off cheap Chinese made tools modified by someone. For something you will use as often as tang nippers, I would spring for the stewmac version. They will last virtually for ever and they are guaranteed to work.
These users thanked the author uvh sam for the post: Alex Kleon (Mon Mar 23, 2015 8:40 pm)
PostPosted: Mon Mar 23, 2015 8:54 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I agree with Sam. Everytime I use the StewMac nipper, I'm just pleased with how well they work. I can't even remember what I payed for it, but I'd replace it in a heartbeat,
These users thanked the author Imbler for the post (total 2): jack (Thu May 21, 2015 5:13 pm) • Alex Kleon (Mon Mar 23, 2015 8:58 pm)
PostPosted: Tue Mar 24, 2015 3:31 am
I also bought from SM, muttering uncomplimentary words like "thieves and robbers" under my breath when I paid for it, especially with the customs and import duties on top!
But I must admit the cost has long since been forgotten with the pleasure of using it.
Even on my first fret job with it, just learning how to best handle it, some of the cuts needed barely a touch with a needle file.
These users thanked the author Colin North for the post: Alex Kleon (Tue Mar 24, 2015 5:46 am)
PostPosted: Tue Mar 24, 2015 7:21 am
I made my own and it works very well. The key is to use a quality tool to start with, also, the slot has to be the right size and in the right position. If I had not already had a quality nibbler I would probably have opted for the SM version.
These users thanked the author SteveSmith for the post: Alex Kleon (Tue Mar 24, 2015 8:12 am)
PostPosted: Thu May 21, 2015 4:21 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
Do any of you have both the medium and large Stew Mac nippers?
The only difference is the slot depth correct? (To account for the width of the fret crown)
Any reason the large nipper wouldn't work for nipping medium fret wire?
PostPosted: Fri May 22, 2015 8:09 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I bought that one off e vil bay and it gets 5 out of 10 stars. To me it/s time vs money if you were building every day I would go with the stew mac, for once a month it/s ok . I find a small diamond file works to clean up the clipped end of the fret.
PostPosted: Fri May 22, 2015 8:37 am
That nibbler has been around for a long time it was about $8 at Radio Shack easy to modify if you care to take the time. I posted the mod about 8 years ago, all you need to do is grind a little channel on the platen. The Stew Mac nibbler is a modified Klein tool currently $26 basically the same mod is required for the conversion.
http://www.skygeek.com/aircraft-tool-su ... gQodIGcAHg
http://controlscentral.com/eCatalog/tab ... gQodjmwAsQ
Ken Cierp
These users thanked the author kencierp for the post: dpetrzelka (Fri May 22, 2015 1:08 pm)
PostPosted: Fri May 22, 2015 10:29 am
Another +1 on make your own. 8 bucks and about ten minutes of your time.
PostPosted: Fri May 22, 2015 12:33 pm
City: Escondido
Zip/Postal Code: 92029
Careful what nibbler you start with. There seem to be two styles out there. The one the ebay nibbler looks like and the one the stewmac nibbler looks like. The big silver one is a POS. The little cutting blade has so much slop the tang gets pinched rather than sheared. That, in turn, puts pressure on the cutting plate that you just scored to make room for the fret crown. The hole thing gets jammed up and eventually breaks.
The black ones with the spring on top similar to the Stew Mac one seem to be much better construction. If you are going to modify an end nipper go with one of these.
PostPosted: Fri May 22, 2015 1:20 pm
First name: Daniel
State: Washington
Perfect- I have a small stack of these from when Radio Shack had then on $2 clearance.
PostPosted: Fri May 22, 2015 1:23 pm
First name: Aaron
Like Ken stated about the StewMac version being a modified Klein, I bought a Klein tool from Amazon (I think I remembered to link from above) and modified it. Wasn't perfect, but it worked - still needed filing, but I saw no reason to get another, until it started to kink the wire out of shape.
I can't see myself paying that much for the StewMac modification. Of course, I'm not always about logic and forked up for the Hosco version instead. Its a keeper.
http://www.ebay.com/itm/Medium-Fret-Tan ... 19e87bd5b5
Users browsing this forum: Freeman and 31 guests
