It is currently Sun Sep 14, 2025 1:45 am
PostPosted: Sat May 02, 2015 9:35 pm
Stripping all electronics and hardware.
Before:
Stripped:
Now just waiting for delivery of bits. In the meantime I would like some advice on if there is anything I can do about the lifting nitro on the headstock. Close up:
My wiring scheme:
PostPosted: Sat May 02, 2015 11:00 pm
Ummmm.... pretty sure there's no nitro on an Eppy LP.
PostPosted: Sat May 02, 2015 11:25 pm
Ok. What is the finish? Wbpu?
PostPosted: Sun May 03, 2015 7:28 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
The finish is a polyester. Delaminations like that are quite common over the plastic headstock veneers. You can try wicking some thin CA in under it, sometimes that gives a satisfactory repair sometimes it stays cloudy. It's about a 50/50 from my experience here. A complete refinish of the headstock face is my typical repair.
Brian
PostPosted: Sun May 03, 2015 7:38 am
Ty
PostPosted: Sat May 09, 2015 7:54 pm
HELP!!! I need a couple of yards of 6 core 22 awg shielded cable for the run from the Freeway switch to the pots. The Belden part number is 5504FE. I can only find distributors sell 500 or 1000' spools. Can anyone in the US source this?
PostPosted: Sun May 10, 2015 8:28 pm
First name: Freeman
Last Name: Keller
I'm retired now but let me call the electronics shop where I used to work. They have all kinds of scraps of all sorts of different multi conductor cables.
PostPosted: Sun May 10, 2015 9:12 pm
First name: D
Last Name: S
You can probably wrap a wire around the bundle for the ground shield.
Not many guitars are wired with shielding these days.
Man, that looks like a complicated wiring scheme.
Very good diagram.
I'm eager to know how it works out for you.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon May 11, 2015 7:19 am
Thanks Freeman
Sent from my Nexus 7 using Tapatalk
PostPosted: Tue May 12, 2015 6:52 am
I found the cable by the foot in the US and ordered 10' for delivery to friends there (wouldn't ship to Oz). My friends will mail on next week.
PostPosted: Tue May 12, 2015 10:18 am
First name: Freeman
Last Name: Keller
I also found a piece and was going to offer to send it to you today. If you want it PM me a snail mail address.
PostPosted: Sat May 30, 2015 9:42 pm
Finished!! Thanks to Freemann for the 6 core shielded cable to run from Freeway switch to cavity. Neck and bridge pups are GFS Alnico II. Middle is the GFS Dream 180. All pots are 500k push-pulls in 3V/1T Series/Parallel setup. New stop piece, bridge, machine heads, pickguard bracket, and jack.
Thanks for the tip re the bubble under the poly on the headstock. The CCA worked great!!
PostPosted: Sat May 30, 2015 10:55 pm
Nice. Now play it 'til your fingers bleed.
