It is currently Thu Aug 21, 2025 11:56 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 16, 2015 12:19 pm
rlrhett wrote:
I have to admit I am confused by the carbon fiber thread. I've done some work with carbon fiber and have experienced both it's surprising stiffness and strength in some areas and total weakness in others. I just don't see where these threads can add stiffness to the brace.
The threads are on the top and bottom of the braces and act in tension to limit vertical deflection of the brace.
PostPosted: Mon Mar 16, 2015 12:45 pm
Last Name: Kincheloe
That pirate inlay is awesome! Should look great against the shimmering figure of the sipo. But not one piece of black pearl? :lol:
Is there a theory behind "inlaying" the braces, or are you just experimenting?
I'm still debating whether to do falcate on one of my in-progress guitars or not, and this is tipping me back toward yes...
PostPosted: Mon Mar 16, 2015 12:56 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
think of the braces as "I" beams with the carbon fiber taking most of the stress and the wood taking the shear stress, carbon fiber virtually eliminates cold creep that is experienced with traditional braces..it's all in "The Books" and Trevor can explain it much better than I can.. [:Y:]
MK5acoustics.com
PostPosted: Mon Mar 16, 2015 12:58 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Kind of experimenting with the channels in the braces, one idea is that the layup was much easier to do and to keep from fraying the carbon tow!!
MK5acoustics.com
PostPosted: Sun Mar 29, 2015 5:11 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Finally some progress??!!!!!! wow7-eyes
this one is getting solid linings top and bottom, the bottom linings are zebrawood..linings are bent then the laminates are glued together using the rim for a form, then shaped sanded and glued in place..
MK5acoustics.com
PostPosted: Sun Mar 29, 2015 5:13 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
rims finished and the bottom fitted.. bliss
MK5acoustics.com
PostPosted: Tue Mar 31, 2015 7:59 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
glued the UTB on a 70' radius form, glued on final carbon tow.. eek
MK5acoustics.com
PostPosted: Wed Apr 01, 2015 10:13 am
Looks good. It looks like you didn't fan out the CF tow onto the top at the brace ends. Any reason on that one?
PostPosted: Wed Apr 01, 2015 1:44 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
more for asthetics and the ends are right next to the pockets
MK5acoustics.com
PostPosted: Sun Apr 05, 2015 10:28 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Top is braced and glued to rim, I glue the back on first only reversed with back on the bottom so I can clean up insides, plus easier to line up the back , and the soundboard on top for same reason , much easier to line up!! beehive
MK5acoustics.com
