It is currently Sun Aug 17, 2025 5:54 am
PostPosted: Mon Mar 30, 2015 9:00 am
Here is the latest Luthier Tips du Jour video - The topic is using shellac and sawdust as a pore fill
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
Enjoy!
These users thanked the author Robbie O'Brien for the post (total 4): mcsulla (Fri Oct 30, 2015 10:14 pm) • qrwteyrutiyoup (Mon Oct 19, 2015 11:11 pm) • RogerC108 (Mon Oct 19, 2015 2:56 pm) • pdolan (Sun Oct 18, 2015 9:01 pm)
PostPosted: Mon Mar 30, 2015 9:48 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Thanks for the tips!!!!
MK5acoustics.com
PostPosted: Mon Mar 30, 2015 10:04 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Great video. Just what I was looking for! Thanks Robbie.
Doug
Interesting. I was doing something not too distant from that method only yesterday. I sanded an actual Back and then rubbed the sanding dust into the pores using my fingers. I then brushed on a coat of Shellac, going across the grain. Of course it didn't fill them in one go but I was surprised at how effective it was. The colour match (I used a dark seedlac,on Walnut) was as good as it gets. Your method might be more efficient. I'll try it!
PostPosted: Mon Mar 30, 2015 4:21 pm
I've just tried this on scrap wood. I don't have a belt sander so I had to use 120G by hand. It's has to be the most painless pore filling method known to man and health wise relatively benign. I can always buy a cheap belt sander and do the sanding out of doors.
PostPosted: Mon Mar 30, 2015 5:43 pm
First name: George
City: Seattle
Yup, two big thumbs up to Robbie. [:Y:] [:Y:]
I've been filling pores this way for a while. Haven't had any problems with it. I just use Zinsser Seal Coat right out of the can.
George :-)
These users thanked the author George L for the post: Tim L (Sun Oct 18, 2015 8:54 pm)
PostPosted: Mon Mar 30, 2015 8:09 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
Thanks Robbie!
PostPosted: Mon Mar 30, 2015 9:00 pm
First name: D
Last Name: S
Thanks Robbie!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Mar 30, 2015 9:16 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Thanks Robbie.....great timing.....
PostPosted: Mon Mar 30, 2015 9:24 pm
First name: Ringo
I've thought about doing this many times but was scared the slurry will shrink over time and show the pores... I bet that using a thin cut so that there's actually very little shellac in the pores is key.
PostPosted: Tue Mar 31, 2015 1:18 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It took a while to find the video... it didn't appear in the post. It's under Mailbag....
I wonder about a variation to this method: In the past I had compatibility issue between shellac and lacquer (the lacquer would not stick well to the shellac undercoat, leading to finish peeling) so what about using very thin lacquer solution (or whatever finishing material you use, like EM6000) for the pore fill instead of shellac?
Typhoon Guitars
PostPosted: Tue Mar 31, 2015 10:03 am
I am really new to trying to do a serious finish. But I took an idea from a YouTube video: My first coat of poly I rubbed in with 400 or 600 sandpaper, creating the slurry. The matte poly finish does have some artifacts, but I think they are due to my sanding. I was surprised how smooth feeling the end result was, almost like glass. This was on spruce and pine which probably didn't really need it.
PostPosted: Fri Oct 16, 2015 7:57 pm
First name: D
Last Name: S
I am using this process on a Mahogany / Walnut solid body.
So far, this is working like a charm!
Mahogany was filled with three applications, Walnut is taking a bit more.
I apply it and then sand until I'm left with shiny grain showing, and repeat.
I don't want the slurry to cloud the overall look.
I should be able to start lacquer spraying tomorrow.
Question: is there any point to spraying a vinyl sealer next, or just go straight to lacquer?
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Oct 16, 2015 8:51 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
According to a recent conversation I had with the Mohawk Finishes tech, you don't ever have to use sealer if you don't want to. It is mostly for sanding ease, according to him.
It will probably be alright.
PostPosted: Fri Oct 16, 2015 9:12 pm
First name: D
Last Name: S
Thanks Greg!
I'm using Behlen which I believe is a Mohawk finish.
The shellac is really making the figure pop. I think it will look great under lacquer.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Oct 18, 2015 5:44 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Outstanding, Robbie. Thank you!
PostPosted: Sun Oct 18, 2015 7:23 pm
You are quite welcome. Enjoy.
PostPosted: Sat Nov 21, 2015 6:07 pm
First name: D
Last Name: S
Thought I'd share result of shellac-dust filler.
The dark pores add contrast.
Fantastic!
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Rod True (Sun Nov 22, 2015 2:27 am)
PostPosted: Sun Nov 22, 2015 2:28 am
Dan, that looks fantastic!!!
These users thanked the author Rod True for the post: dzsmith (Sun Nov 22, 2015 10:52 am)
PostPosted: Sun Nov 22, 2015 3:11 am
First name: Danny
Last Name: Vincent
Thanks Robbie. I've always been a little suspect of the bond between fillers and finish but I know the bond between shellac and any finish is good. The process looks a little therapeutic also which is always good.
