It is currently Tue Aug 19, 2025 12:41 pm
PostPosted: Wed Mar 25, 2015 9:28 am
First name: Bryan
Last Name: Patrick
I’m trying to finish up an acoustic guitar. I have sprayed it with KTM-9, but have run out. I probably have enough coats, but I’m thinking a couple more coats wouldn’t hurt. I’m switching over to EM6000 from the KTM-9 on future builds and have a brand new quart of EM6000 ready to go. Properly scuffed with 400 grit and sprayed with denatured alcohol prior to spraying, would a final spray with EM6000 be advisable?
Thanks for any advice!
PostPosted: Wed Mar 25, 2015 10:10 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I am not so sure how it would adhere. If it could adhere I would not do just one final coat. .003" wet coat (recomended) * .24 (%solids) = .00072" dry coat. I am not sure you could sand and buff it with out going through that coat and getting witness lines. I have had some problems with Em6000 adhereing to zpoxy and now always use shellac in between without issues.
These users thanked the author johnparchem for the post: okrausonia (Wed Mar 25, 2015 10:12 am)
PostPosted: Wed Mar 25, 2015 10:14 am
First name: Bryan
Last Name: Patrick
That's interesting since I've read that zpoxy and shellac aren't supposed to play well together. There's nothing like real life trial and error...
PostPosted: Wed Mar 25, 2015 10:19 am
Last Name: Parchem
City: Seattle
State: Wa
Zpoxy on shellac may have issues, shellac on zpoxy is fine. Basically pore fill on bare wood. Then it is OK to use shellac on a zpoxy fill. I have about 12 instruments pore filled with zpoxy, some french polished shellac and some with a stack of zpoxy, shellac and finished with EM6000.
PostPosted: Thu Mar 26, 2015 3:51 pm
Online
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Years ago, when I tried KTM-9, I believe that the current Target Coatings product at the time, the precursor to EM6000, was recommended to repair a KTM-9 finish. So, the EM6000 ought to stick. If it were one of mine, I would probably buy the extra can of KTM-9 rather than mix the finishes. The KTM-9 seems much harder than the EM6000 and while soft over hard can be safer than hard over soft, I wouldn't do it. They may respond differently to temperature changes over the years.
These users thanked the author bobgramann for the post: okrausonia (Thu Mar 26, 2015 4:26 pm)
PostPosted: Thu Mar 26, 2015 4:28 pm
First name: Bryan
Last Name: Patrick
Here's the official response from Target Coatings:
Jeff Weiss wrote:
Yes, EM6000 will work well over the KTM-9. Clean the cured KTM-9 coats with water and denatured alcohol mixed 1:1, then fine sand with 600-grit aluminum oxide sandpaper. Proceed with EM6000 directly over the KTM. I recommend a minimum of two more coats of EM6000 to ensure that sanding scratches do not telegraph.
JW
PostPosted: Thu Mar 26, 2015 5:46 pm
Last Name: Beaver
City: Lake Forest
I suspect the 'cured KTM-9' part is the key. That takes about two weeks. I would stick to KTM-9 for this one
Joe Beaver
Maker of Sawdust
