It is currently Mon Aug 18, 2025 8:02 pm
PostPosted: Tue Mar 24, 2015 10:14 pm
The title says it all. Before I take a blade to wood I like to know what angle will minimize tear out on ribs and back. I've never worked an exotic wood before so I appreciate your insight into this regard.
-jj
PostPosted: Wed Mar 25, 2015 12:47 am
First name: Trevor
Last Name: Gore
City: Sydney
For hand planes, plane across grain with a standard angle (45 degree) plane set up as a shallow crescent scrub plane to remove the bulk. To finish up in line you'll need at least 60 degree pitch angle set up as a fine smoother.
http://www.goreguitars.com.au
PostPosted: Wed Mar 25, 2015 1:05 am
Trevor, from the bottom of my sole a hearty thanks.
I glean from "finish up in line" you imply "desired thickness" by smoothing with the grain, correct?
-jj
PostPosted: Wed Mar 25, 2015 1:12 am
First name: Trevor
Last Name: Gore
City: Sydney
Correct.
PostPosted: Wed Mar 25, 2015 1:51 am
The other way to finish off is to set the chipbreaker mighty close to the edge of the blade, within 0.5 mm and less of a seriously sharp blade. Set fine and a standard angle might be OK.
PostPosted: Wed Mar 25, 2015 12:07 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Since you're just starting, I'll recommend you go to Mr. Gore's website and buy his books.
They are not cheap, but they are the best reference available for the design and construction of steel string guitars.
PostPosted: Wed Mar 25, 2015 12:34 pm
Thanks, I'll check it out.
