It is currently Tue Aug 19, 2025 11:28 am
PostPosted: Sat Mar 14, 2015 4:27 pm
Hi
Anyone know if there is a uk supplier of 6" deep bridge clamp at a reasonable price
Found 2 suppliers but they want £30-35
Which is very pricey for a clamp
thanks
PostPosted: Sat Mar 14, 2015 5:25 pm
You can always make one. This design works pretty well.
These users thanked the author Michael.N. for the post: Cablepuller (Sun Mar 15, 2015 3:24 am)
PostPosted: Sat Mar 14, 2015 5:30 pm
Klemmsia cam clamp 200 x 150 mm from Axminster at £13.96 each. http://www.axminster.co.uk/klemmsia-cam-clamps
Works for me.
http://www.luthiersforum.com/forum/download/file.php?id=47412
One would probably be enough
These users thanked the author Colin North for the post: Cablepuller (Sun Mar 15, 2015 3:34 am)
PostPosted: Sun Mar 15, 2015 3:55 am
Works for me.
Thanks colin
Dont think the Axminster has deep enough reach (need6") it only has 110mm .. cant open your other link for some reason..might be my phone
Cheers anyway
PostPosted: Sun Mar 15, 2015 4:41 am
Personally I find the Klemmsia a bit cumbersome as a Bridge clamp, I'm sure they work though.
The homemade clamp that I showed previously was given to me over 30 years ago when I was at instrument making school. The guy who was teaching just used one single clamp but used a caul on top of the Bridge that gave 3 points of clamping, central and at each end of the bridge wings. It was like a sprung caul. Simple thing made from wood. Worked for him for 30 years, as it has for me.
This particular one has a 165 mm reach. I had to cut off some of the back end because it wouldn't fit in my small Torres model - but that has a relatively small soundhole. The top arm can swing out of the way although the clamp wasn't originally designed to do that! It can be a useful feature though. The internal caul pivots on the little dowel and it's position can also be adjusted.
PostPosted: Sun Mar 15, 2015 5:01 am
Thanks micheal
Is that a pivot at the end ..if so is it shaped from the wood or using something else
PostPosted: Sun Mar 15, 2015 5:24 am
It's just a very short section of 12 mm dowel, glued to the bottom clamp section.
It looks like he glued the bottom section of the clamp to the top section. Drilled a 12 mm hole at the appropriate place and then has sawn through the centre of that hole, releasing the bottom and top sections. That gets your pivot point without too much fuss. The slotted hole in the top section is important, it certainly needs to be a slot rather than a hole.
PostPosted: Sun Mar 15, 2015 5:35 am
Another important point. I put the whole clamp and the inside caul into the Guitar before getting either the Bridge or the glue out. The Top clamp arm is swung out of the way (that's it's one advantage). The glue and Bridge is applied to the soundboard and then the top clamping arm is swung into position. The extra long bolt is useful too, it helps to hold the clamp when moving the arm. Whoever came up with this design had clearly thought things through.
The inside caul on it's little pin or dowel needs to be a fairly tight fit, you don't want it so that it can swing around too freely.
These users thanked the author Michael.N. for the post: Cablepuller (Sun Mar 15, 2015 5:58 am)
PostPosted: Sun Mar 15, 2015 6:45 am
Last Name: Matthews
State: Surrey
Country: England
Tonetech http://www.tonetechluthiersupplies.co.uk/luthier-tools/clamping.html have Ibex bridge clamps and also this little beauty which is quite expensive.
http://www.bobmatthewsguitars.co.uk
These users thanked the author Bob Matthews for the post: Cablepuller (Sun Mar 15, 2015 3:44 pm)
PostPosted: Sun Mar 15, 2015 3:18 pm
He thinks £30 -£35 for one clamp is expensive (he might be right). £100 is getting pretty excessive.
PostPosted: Sun Mar 15, 2015 3:44 pm
Cablepuller wrote:
Works for me.
Thanks colin
Cheers anyway
Cablepuller, Axminster have Klemmsia cam clamps and the 200 mm capacity(depth) is available in 110, 150, and 200 mm throats(reach)
I have some of each of them, and they are my most used clamps.
I did check they were in stock before I posted.
These users thanked the author Colin North for the post: Cablepuller (Sun Mar 15, 2015 3:49 pm)
PostPosted: Sun Mar 15, 2015 3:48 pm
All built this afternoon... thanks for the tip and pictures Michael
Tried it on a dry fitting and it worked a treat
Saved me £30 or £100 lol
Thanks again
PostPosted: Sun Mar 15, 2015 3:51 pm
Colin North wrote:
Cablepuller wrote:
Works for me.
Thanks colin
Cheers anyway
Thanks for getting back to me colin
It must be my fat fingers but i could only get the one depth option when i tried it..might be because i was looking on my phone
Cheers though
PostPosted: Sun Mar 15, 2015 3:53 pm
Looks like you managed fine on your own Cablepuller!
These users thanked the author Colin North for the post: Cablepuller (Sun Mar 15, 2015 3:57 pm)
