It is currently Wed Aug 20, 2025 7:56 pm
 Post subject: discolored ebony
PostPosted: Wed Mar 11, 2015 4:58 am
Country: Ireland
Hi all,
I bought some very cheap low grade ebony blanks thinking they'd be useful for early builds. I don't mind the streaking etc but they look like they've been splattered with oil and it goes right through the wood. still visible after applying lemon oil and black spirit stain.any ideas?
 Post subject: Re: discolored ebony
PostPosted: Wed Mar 11, 2015 5:44 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
That is called mineralization. It is usually composed of calcium carbonate. You could try removing it from the surface with an acidic solution like C-L-R or white vinegar.
PostPosted: Wed Mar 11, 2015 4:23 pm
First name: kurt
Last Name: thomas
City: colden
State: ny
Zip/Postal Code: 14033
Acid solutions will take it off but be careful, I am building with a set of nice EIR that had great figure but some minor mineral spotting which I tried to remove with some safe acid that I had (Modified salt of HCL). The spots came out fine but it started to lighten up the overall color of the rosewood where I had applied it so now that side will become the inside of the guitar. What I ended up doing and had success with, was using distilled water and just wiping it on the spots several times. By daylight, I am an industrial water treatment guy so I know that water is the universal solvent, but make sure it's distilled or DI water, not hard water from the tap. You want to remove the mineral spotting which is most likely calcium carbonate based, which is why it reacts with acid. Using hard water is just throwing more calcium and magnesium into the wood, especially if you have really hard well water. If just plain old DI or distilled doesn't quite do it, then go ahead with the CLR which is actually oxalic acid I believe, but dilute it down with the water first. And come to think of it, oxalic acid may actually intensify color removal from the wood, you might even try vinegar which is acetic acid and I believe would be less aggressive at color change than the oxalic.
_____________________________
Kurt Thomas
"There's a first time for everything even if you do it by mistake."
PostPosted: Wed Mar 11, 2015 4:40 pm
First name: Danny
Last Name: Vincent
Very timely. Thanks!
PostPosted: Thu Mar 12, 2015 1:59 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Don't mess with Oxalic acid... it is used to bleach wood.
You may try Hydrochloric acid but I don't know how it will affect the wood's coloring.
Typhoon Guitars
PostPosted: Thu Mar 12, 2015 3:35 am
Country: Ireland
Thanks all.i tried white wine vinegar after John's suggestion as it was all I had. It worked but did lighten the wood but I don't really mind as it's quite a characterfull piece anyway.
PostPosted: Thu Mar 12, 2015 4:59 am
Hey Mike - Some great suggestions here already.
However you go at this you might want to treat an additional piece of scrap exactly the same way and then use this piece as a finish mule applying finish how you intend to to see what the results of your labor are. Might save you some trouble down the road.
PostPosted: Thu Mar 12, 2015 5:51 am
Country: Ireland
I wasnt planning on putting any finish on, do you finish ebony fingerboards?
PostPosted: Thu Mar 12, 2015 6:54 am
No but folks nearly always finish ebony head plates, back plates, heel caps, etc. Additionally folks do finish the sides of fret boards helping to make the side markers pop. Don't think that you mentioned how you plan to use the ebony so I'm trying to cover as many applications as I can.
PostPosted: Thu Mar 12, 2015 12:42 pm
Last Name: Arnold
City: Newport
I darken ebony fretboards with alcohol soluble black aniline dye.
PostPosted: Thu Mar 12, 2015 12:44 pm
Are you sure all this was necessary? I've often found that it all goes away when you put oil on the fingerboard.
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think a lot of people do this, in fact LMI sells a special dye designed to darken fingerboards because some customers must have jet black ebony... the dye is meant to cover the streaks found in West African ebony.
Typhoon Guitars
PostPosted: Thu Mar 12, 2015 4:31 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I have found the same thing on the boards I've had.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Thu Mar 12, 2015 7:33 pm
First name: Danny
Last Name: Vincent
What sort of oil? Howard's Wax N' Feed doesn't seem to make much difference.
PostPosted: Fri Mar 13, 2015 5:58 am
Country: Ireland
As I said lemon oil made no difference.
PostPosted: Fri Mar 13, 2015 6:58 am
If you already put wax or oil on the boards you need to remove it with strong solvents. The so called "special fingerboard dye" is not so special it is actually "Fiebing leather dye" even available at Walmart. The oil base version for some reason ends up looking blacker (if there's such a word) than the water based formula. But it will only work if it can be absorbed into the wood surface--- and it does work very well.
Ken Cierp
PostPosted: Fri Mar 13, 2015 7:43 am
I use Teak Oil, and I don't use it often. I think most players obsess about how the board looks and put too much oil on the board. Cleaning the fingerboard with naphtha may also darken some of those mineralizations. It may not get it all the way out, and you have to decide whether and what to do.
These users thanked the author dberkowitz for the post: DannyV (Fri Mar 13, 2015 12:39 pm)
Users browsing this forum: Bing [Bot], J De Rocher and 21 guests
