It is currently Mon Aug 25, 2025 3:46 am
PostPosted: Thu Jan 29, 2015 6:03 pm
I know Shane is in the middle of creating a post about a PID controller but I thought I'd show my simple set up.
Here are the components:
Auber Instruments SWA-2442C - 1/16 DIN PID Process Controller w/ Timer & Alarm This controller has 10A relay contacts, most blankets run 5-8A so no solid state relay is required.
Auber Instruments TC-K5 - k Type Thermocouple, Bare
International shipping to Canada was $12 US
The on/off switch is just a basic house switch.
The single plug I pulled off the non-working router speed controller I got years ago from John Hall, so is the power cable.
Here's the schematic I used, thanks to Dave Fifield
You'll notice in my actual wiring job that I jumped post 11 & 12. This needs to happen in order for the timer to be enabled.
Total cost to me was under $100 CAN. Took about 2 hours to fully set up, including slight modification to my bender base. Took another 1.5-2 hours to figure out the "programming".
I like this controller as it controls both the temperature and has the timer built in. Works like a charm!
The rest is pretty easy.
These users thanked the author Rod True for the post (total 2): James Orr (Fri Oct 14, 2016 11:43 pm) • Pmaj7 (Thu Jan 29, 2015 8:22 pm)
PostPosted: Fri Jan 30, 2015 6:51 pm
Nice Rod. I am hoping to wire mine up soon as well and will photo document. I started putting the "inside" shop together and put the timer on hold while I get that mostly done. We will see if I can do something comparable to what you have done. Although mine is for two blankets and separate timer functionality for each....
Thanks for post Rod.
PostPosted: Fri Jan 30, 2015 8:00 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I would advise adding a bathroom style timer between the controller output and the blanket, much less chance of a scorched side or burned shop.
I also like simple and straight forward, my controller also has enough output for the blanket without the external relay.
Fred
Fred Tellier
