It is currently Mon Aug 18, 2025 4:05 pm
PostPosted: Sun Jan 25, 2015 12:58 pm
Hot off the presses at Ann Arbor Guitars is our latest video put together by David Collins.
https://www.youtube.com/watch?v=HgkcA9ikHFQ&app=desktop
enjoy!
These users thanked the author Hesh for the post (total 3): Lonnie J Barber (Thu Jan 29, 2015 1:43 pm) • Mark Fogleman (Mon Jan 26, 2015 9:43 pm) • DannyV (Sun Jan 25, 2015 3:30 pm)
PostPosted: Sun Jan 25, 2015 1:10 pm
Nice video - lots of techniques to see there. Thanks for sharing that.
These users thanked the author SteveSmith for the post: Hesh (Sun Jan 25, 2015 1:18 pm)
PostPosted: Sun Jan 25, 2015 1:24 pm
First name: Tom
Last Name: West
State: Nova Scotia
Love to see ex machinists at work...........!! Nice video..!!
Tom
These users thanked the author Tom West for the post: Hesh (Sun Jan 25, 2015 3:02 pm)
PostPosted: Sun Jan 25, 2015 2:39 pm
Pretty slick trick on the rabbeting with the Dremel... how did you hold the Dremel?
PostPosted: Sun Jan 25, 2015 2:56 pm
Last Name: G
Wow, That saddle slotting mill is (fill in the blank, here).
Did David ever do a small run of them like you talked about here ? :
viewtopic.php?f=10101&t=43204
This one looks like a new version.
cheers
These users thanked the author SteveG for the post: Hesh (Sun Jan 25, 2015 3:12 pm)
PostPosted: Sun Jan 25, 2015 3:09 pm
State: ON
For a while now I've been trying to figure out a good setup for rabbeting along the bottom edge of the bridge. Now I know how. Thanks.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
These users thanked the author Josh H for the post: Hesh (Sun Jan 25, 2015 4:40 pm)
PostPosted: Sun Jan 25, 2015 3:12 pm
This is a pretty well-known process and Collings Guitars does it as well. I think that Terry Kennedy also does it this way or has.
The Dremel is mounted in a modified Stew-Mac router/Dremel base and a false table with a slight radius to mirror the radius of tops is imparted to the false table. Stops are adjustable for the .003" inset that Dave likes and the .010" inset that I need to be capable of even seeing it..... :? Stops are also adjustable for finish thickness and depth of cut.
It makes for a very neat installation with the finish tucked ever so slightly under the bridge but still the wood-to-wood contact is at times expanded 40% beyond what the manufacturer left us..... More wood-to-wood, decent HHG techniques, scraping prior to gluing and this is about as good as it gets without using lag bolts... It also mirrors how the instrument originally looked as well with the finish undisturbed and intact.
There are actually a ton of imbedded tips and tidbits in this specific video.
One of the very most useful ones has yet to be mentioned and that is the set-up for gluing the bridge with HHG and more specifically the use of the clamp, risers, masking tape, etc. to preposition the clamp so that once the HHG is applied the clamping pressure can be done very quickly. I think that Dave mentioned 30 seconds in the video but we are very capable of having the clamp in place and snugged down in less than 15 seconds. A useful thing with HHG. Note too the caul under the top is also captive to the prepositioned clamp - pretty cool and this is one of Dave's innovations as far as I know as well.
PostPosted: Sun Jan 25, 2015 3:23 pm
Yep the Collins Saddle Mill(s) are now available and in production. It was unveiled at an invitation only event last summer at Bryan Galloup's that drew many of the biggest names in the business.
The saddle mill received critical acclaim from many of the folks at this gathering and will be going to some of them soon.
It's not nor was it ever intended to be a hobbyist tool and the costs associated with producing these make it likely economically out of reach for the hobby builder. But... for folks who have to true up a saddle slot for say the installation of a UST (under saddle transducer) or who are authorized or even not authorized to do say Martin repair work where moving a saddle slot is not an uncommon thing with 70's Martins it's a life saver....
For builders who work in the trade, appreciate the very best and are convinced that slotting the saddle slot on the finished instrument is more precise than leaving all of this to where the bridge gets glued on it's also an option.
There are other applications as well such as imbedding an UST under a through saddle and/or installing a UST in a classical but not doing anything that shows to the instrument in the process.
We never anticipated a total lifetime market for these mills of more than say a dozen or so but that never stops us from wanting to advance the craft and do the very best work that we can, always.
Lastly it looks a little different because the last time that we showed it here on the OLF was the last of several pre-production prototypes. The production models are anodized, come with router installed AND calibrated including a special and very expensive chuck and bit to keep the tolerances tight.
These mills are being sold direct and though personal contact with prospective clients who we know to have the volume of work and the level of interest to be interested. Much like the PLEK model by the way.
PostPosted: Sun Jan 25, 2015 3:35 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Don't forget the custom brass knobs instead of the old plastic ones ... [:Y:]
These users thanked the author murrmac for the post: Hesh (Sun Jan 25, 2015 4:40 pm)
PostPosted: Sun Jan 25, 2015 6:44 pm
State: Tennessee
Very nice job, thanks for sharing. Giving the customer what they want is the bottom line.
The existing bridge plate appears to be plywood, would it be too invasive to replace it with a nice maple or ultimately black locust bridge plate?
These users thanked the author Clinchriver for the post: Hesh (Mon Jan 26, 2015 10:30 am)
PostPosted: Sun Jan 25, 2015 7:05 pm
David showed that jig a number of years ago on the OLF and I made a crude copy that works well.
I made a 30' radiused base that I attached to the StewMac Dremel router base. I used the SM edge guide with a wood post so the router bit could push into it and expose only a portion of the 1/8" bit.
I just clamp it in the vise and use initial climb cuts followed by conventional cuts. I usually do test cuts on scrap to get the depth right so the ledge just clears the finish.
I made the mistake of not getting the corners of the wings cut evenly and not getting the finish removed perfectly in the corners and had a couple of wings lift and had to reglue down the line early on but after that got fixed the technique has worked great.
Great video
These users thanked the author Terence Kennedy for the post: Hesh (Mon Jan 26, 2015 10:30 am)
PostPosted: Sun Jan 25, 2015 8:13 pm
First name: Patrick
Last Name: Hanna
State: Missouri
That's excellent! Very nice and informative video. I used to have one of those plastic bridges on my old Gibson LG 1. I didn't even know it was plastic until it started to curl up. I made a new bridge for my guitar (all but routing the saddle slot) back sometime in the 70s. I chickened out at the end and hired a repair man to install it and rout the saddle slot for me. It was my first attempt at a guitar repair. I doubt my guitar has all the fastidious hole plugs and bridge plate repairs featured here, but it has held up well. Again, a very informative video. It shows me how much there will always be to learn, and techniques to which I can aspire. Thanks for posting this. (Man...that was a LOOOOONG time ago...)
These users thanked the author cphanna for the post: Hesh (Mon Jan 26, 2015 10:31 am)
PostPosted: Sun Jan 25, 2015 8:28 pm
Great video.
These users thanked the author James Orr for the post: Hesh (Mon Jan 26, 2015 10:31 am)
PostPosted: Sun Jan 25, 2015 9:56 pm
Thanks everyone. I've just started getting in to making videos, and am having fun with it (plus it allows the business to buy some nicer cameras and video equipment, which I can borrow from time to time :) ).
Terence - Perfect! Gets the job done quite nicely and efficiently, doesn't it?
Clinch - yes, it would have been nice to put a solid plate on this, but this particular top was a rare example of one of these holding form quite nicely with the original plate. Without any current problems though, I couldn't advocate the extra expense for the owner, especially on an instrument like this which was not really the highest value to begin with. Plus the glue they used during this era (appears to be some form of resorcinol?) can be a ticking time bomb. Sometimes it holds up fine, but often it seems to become very brittle and fracture quite easily. Touch one brace on the inside, and three others immediately fall off kind of thing. Since everything appeared to be holding quite well as it is, I prefer to touch as little as possible in these things, which can respond a little less predictably than others.
PostPosted: Mon Jan 26, 2015 8:43 am
Hey Dave,
Great video, Dave!
Any chance of doing a tutorial (wouldn't have to be video) on your little Dremel-powered bridge edge-rabetting jig?
Max
Max Bishop
Brighton, Michigan
These users thanked the author MaxBishop for the post: Hesh (Mon Jan 26, 2015 10:35 am)
PostPosted: Mon Jan 26, 2015 9:31 am
I agree. Lots of useful tips. I paid special attention to the set up for fixing the caul and the clamp in place with the wedges. I have been thinking on that one for a while and am embarrassed that I did not think of it. Getting that stupid caul and clamp in place "after" the glue is applied is really time consuming.
Thanks to Hesh and David for sharing these tips. I also used several of your tips in earlier posts on leveling and dressing frets. The tip on crowning the frets was very useful.
Thanks guys.
James
These users thanked the author guitarjtb for the post: Hesh (Mon Jan 26, 2015 10:35 am)
PostPosted: Mon Jan 26, 2015 10:35 am
MaxBishop wrote:
Hey Dave,
Great video, Dave!
Max
Hey Max! Happy 2015 to ya my friend!
Instead of a video that would take some time to do and right now is a very busy time of year for us with Mother Nature cracking guitar after guitar why not just come on by our shop and we would be happy to see you too. We can go over the jig, you can take pics if you like, and we can show you how we use it too.
Let me know if this sounds like fun to you, we would love to see you and catch up too!
Hesh
PostPosted: Mon Jan 26, 2015 10:43 am
Thanks guys.
James
Hi ya James! Around eight years ago when I was apprenticing with Dave was my first exposure to his set-up for prepositioning clamps for bridge reglues with HHG. It was so very simple that it was complicated! :D I kicked myself a few times too over not being able to come up with this on my own.
For years I have been wanting to post a pic of the set-up because it's simple, it works, does not require more stuff, and permits those on the fence with their HHG chops to be capable of having the clamps in place very quickly making HHG an option for some where it was not prior.
Now that the cat is out of the bag (no cats were harmed in making this statement....) I'm happy because I no longer have to worry about shooting off my mouth over this.... :D
Glad that you liked the video too!
PostPosted: Mon Jan 26, 2015 11:15 am
Hesh,
Thanks for the invite. I have been thinking about paying a visit. What would be a good day/time? I'm pretty flexible.
Max
Max Bishop
Brighton, Michigan
PostPosted: Mon Jan 26, 2015 11:58 am
Thanks guys.
James
Yep. I don't even care about the Gibson. I doubt I'll ever have to breathe life into one ;) Loved seeing David's bridge-making process, the gluing setup, etc.
PostPosted: Mon Jan 26, 2015 4:04 pm
MaxBishop wrote:
Hesh,
Max
Hey Max: Any week day would be fine although I'm out this Friday but usually we are both here M - F, 10 - 6 and closed on weekends.
So really any time is great and it will be good to see you too my friend!
PostPosted: Mon Jan 26, 2015 6:33 pm
Hesh,
How about this Thursday at around 11:00 AM?
Max
Max Bishop
Brighton, Michigan
PostPosted: Mon Jan 26, 2015 8:18 pm
MaxBishop wrote:
Hesh,
Max
Perfect - see you then!!
PostPosted: Mon Jan 26, 2015 8:20 pm
Lookin' forward to it.
Max Bishop
Brighton, Michigan
PostPosted: Mon Jan 26, 2015 8:29 pm
Closed on weekends?
Incontheviable!
Users browsing this forum: Kbore, kfish and 12 guests
cron
