It is currently Sat Aug 23, 2025 2:08 am
PostPosted: Mon Jan 12, 2015 9:54 pm
Last Name: Colbert
City: Anacortes
I'm using the 14" buffs for the 1" arbore from Stewmac. The fibers in the buffs are scratching the finish. I've dressed and trimmed them as per recommendation from SM, but am still not completely happy with the final results. Let me say that the finish looks very good! I just want better... Any recommendations?
Thanks, Michael
PostPosted: Tue Jan 13, 2015 7:07 am
I use flannel and cotton wheels from grizzly
I also use mazzerna 18 16 and maquires swirl remover and 3 m products.
These users thanked the author bluescreek for the post: Michaeldc (Tue Jan 13, 2015 8:34 am)
PostPosted: Tue Jan 13, 2015 8:33 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Try less pressure on the final compounds. And make sure to reload the compound often, let the compound do the work, not the buff.
Brian
These users thanked the author B. Howard for the post (total 2): JasonM (Tue Jan 13, 2015 4:21 pm) • Michaeldc (Tue Jan 13, 2015 8:35 am)
PostPosted: Tue Jan 13, 2015 9:37 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I use the StewMac buffs and I can tell you it takes a long time to really break them in and get them trimmed properly. I still rake and trim mine every so often and they get better with each use. I use scissors parallel with the face of the buff edge to trim the buffs so they are flat when spinning, making sure to snip off any stray threads that stick out. I wet sand with 800 and 1000, then buff with Menzerna coarse, medium, and fine on three dedicated buffs. I've found that I have to buff with the coarse several times to get all the wet sanding scratches out. The coarse buffing scratches then buff out pretty easily with the medium and fine. Anytime I find scratches left, its almost always due to not enough time on the coarse wheel. Rake and recharge the buffs often as you work. Little pieces of compound that harden on the buffs will scratch and have to be removed via the rake.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: Michaeldc (Tue Jan 13, 2015 9:40 am)
PostPosted: Tue Jan 13, 2015 1:44 pm
Last Name: Tulloch
State: Vermont
I have the Stew mac wheels also...and they are scratching too. Plan to send em back.....will be trying the Jescar wheels next.
PostPosted: Tue Jan 13, 2015 2:30 pm
Try using Flannel and Like Brian said Light touch load often.
PostPosted: Tue Jan 13, 2015 3:05 pm
Having tired lots of differnet brands and suppliers I currently ended up with this company:
http://eickelit.de/
Really very good, not cheap, but for sure worth every cent.
Compounds menzerna....
cheers, alex
PostPosted: Tue Jan 13, 2015 5:26 pm
wonder if they have any north american distributors. looks like good stuff
http://eickelit.de/
cheers, alex
PostPosted: Tue Jan 13, 2015 6:43 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
John and Howard, how many times would you say was "often."
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Tue Jan 13, 2015 7:16 pm
you have to watch the surface. When I don't see a dust layer follow the wheel I reload. I am also feeling the surface. you don't want to build up a lot of heat. the more you load the less heat. Yes it will feel warm. It is all in the touch. There are times you push but as you get closer to the final buff it is all about finesse and touch.
PostPosted: Tue Jan 13, 2015 8:41 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
John, do you buff in multiple directions or do you follow the predominant grain of the wood?
Doug
PostPosted: Wed Jan 14, 2015 8:05 am
Last Name: Howard
City: Magnolia
State: Delaware
I do not worry about following the grain of the wood. You have to be aware of how the buff is coming off the edges....even the soundhole. Buffing into an edge can grab the guitar out of your hands or burn through. There is a definite feel that you need to develop for this. It is easy to miss abrasions from sanding or the previous compound, so be sure that what you are seeing is actually not from a previous compound. Also final finish off the wheels will depend on what compound you finish with. Those of you finishing with GW16 may want to consider going up to Atol6.
Brian
PostPosted: Wed Jan 14, 2015 8:33 am
Last Name: Colbert
City: Anacortes
Thanks for all of the suggestions and advice!
I hadn't considered using a heavy buff compound to start. I do use separate buffs for each compound. I will also work on breaking in my SM buffs more. I will try a lighter touch on the last pass, and load the buffs more often.
Herr Dalbergia, I will try to track some of these down next time we are in Germany. Most of my wife's family live around Hamburg.
M
Cheers,
PostPosted: Wed Jan 14, 2015 10:47 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Clean the buffing compound residue from the surface when changing to a finer compound. I also often back up to course compound if I see marks I missed when using medium or go back to medium after fine if I see issues. These work real well http://www.caswellcanada.ca/shop/acryli ... wheel.html also a caswell site in USA.
Fred
Fred Tellier
These users thanked the author Fred Tellier for the post: Michaeldc (Wed Jan 14, 2015 11:27 am)
PostPosted: Wed Jan 14, 2015 3:12 pm
Last Name: Sollod
Often I don't see the scratches until I go to finer grits... I have had to go back more than once... gaah
www.swiftcreekguitars.com
PostPosted: Wed Jan 14, 2015 3:24 pm
Last Name: Colbert
City: Anacortes
Me too.
I don't really mind unless I have to change a buff wheel.
PostPosted: Fri Jan 16, 2015 12:50 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Thanks for the link Fred - I assume you use two of these doubled up on each side?
Rob
PostPosted: Sun Jan 18, 2015 1:37 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Getting ready to buy a shop fox buffing assembly. I have a 1/3hp motor, a v belt ,not sure what size pulley needs to go on the motor . The fox is a 3/4in rod with a 3 step pulley. I/m assuming I can buy 2, 12in buffers . I/m not sure where to buy them or from whom.? John says flannel and cotton . I need one for rough polishing after 4000 abralon and 1 for final buffing out .Any recommendations. It/s a subject I/ not familiar with .Thanks for your help.
