It is currently Tue Aug 19, 2025 3:14 pm
PostPosted: Fri Dec 12, 2014 11:03 pm
First name: Greg
Last Name: Anglin
City: Ocala
Zip/Postal Code: 34476
I am a novice & also not a woodworker, so need to know if there is any type of jig for a Dremel tool to cut a straight line in the head stock so i can inlay an abalone strip. Thanks.
PostPosted: Sat Dec 13, 2014 12:17 am
Do you have the stew mac Dremel router base?
PostPosted: Sat Dec 13, 2014 12:31 am
Or the Dremel router base. Or any type of base for it that can follow a straight edge or use an edge guide.
PostPosted: Sat Dec 13, 2014 1:03 am
Good point. The Dremel one is probably cheaper...
PostPosted: Sat Dec 13, 2014 7:55 am
First name: Greg
Last Name: Anglin
City: Ocala
No, but I had looked on-line & saw a couple Dremel router bases. I didn't know how to keep the tool straight however. Do you have to hand-make an edge guide or do they sell something? Thanks. Greg (Mutoscope)
PostPosted: Sat Dec 13, 2014 9:46 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
For a simple straight line an exacto knife may be all you need. Sometimes low tech can speed things up. Some knife work is needed on many inlay jobs. Routers can't cut a square corner.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
These users thanked the author Cush for the post: Mutoscope (Sat Dec 13, 2014 3:12 pm)
PostPosted: Sat Dec 13, 2014 1:14 pm
Just run the router base up against a board with a straight edge that is clamped to the headstock the appropriate distance from your desired cut. Easy cheesy.
These users thanked the author Barry Daniels for the post: Mutoscope (Sat Dec 13, 2014 3:10 pm)
PostPosted: Sat Dec 13, 2014 3:11 pm
First name: Greg
Last Name: Anglin
City: Ocala
duhhh, why didn't I think of that! Thanks so much. Greg (like I said, I'm a novice to this stuff)
PostPosted: Sat Dec 13, 2014 3:14 pm
First name: Greg
Last Name: Anglin
City: Ocala
Thanks for the input. I had originally thought I would have to do the whole thing with an x-acto and then a miniature chisel set. And yes, I see where i would have to do the corners with an x-acto type blade. Greg
Users browsing this forum: DennisK and 25 guests
