It is currently Tue Aug 19, 2025 4:16 am
PostPosted: Mon Dec 08, 2014 10:53 am
First name: Wendy
Last Name: W
State: Arizona
For masking the bridge position during finishing, which type of frisket do you use and where do you get it. Also, what is the advantage over the blue masking tape?
Thanks, Wendy
PostPosted: Mon Dec 08, 2014 11:30 am
Frisket 1 thou, matt, extra tack, after recommendation here.
I got mine from ebay in UK, not familiar with US suppliers though.
Advantage - well, being so thin, the finish seems to just flow over it after spraying a few coats, no ridges, so leveling and buffing is easy.
But it's still easily visible due to it being matt.
PostPosted: Mon Dec 08, 2014 11:55 am
First name: Wendy
Last Name: W
State: Arizona
Thanks Colin. So is Frisket clear? Your reply makes me think that it would be difficult to find if you were doing a matt finish. Also, is there a problem with it pulling fibers out of the soundboard on removal when you use extra tack?
PostPosted: Mon Dec 08, 2014 12:01 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Here's what I used but I got it from a local art supply store.
I don't recall it pulling wood fibers out. It's much thinner than masking tape so you don't get as large of a bump at the edge.
Kevin Looker
http://www.amazon.com/Grafix-Extra-Fris ... isket+film
I'm not a luthier.
PostPosted: Mon Dec 08, 2014 12:44 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Yes, frisket is clear and very thin. No reason to look for high tack. Gloss or matt also doesn't make much difference -- depending on finish and top wood, both can be tricky to see under the finish. I cut mine a tad smaller than footprint, and cut a rabbet around perimeter of bridge to clear the narrow strip of finish left. If you use this method, you can run a pencil around the edge of the frisket to make it easier to see the edge. Great stuff and a roll will do a lot of guitars.
PostPosted: Mon Dec 08, 2014 12:52 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Hobby Lobby has the frisket Kevin linked to, that is what I use also.
Fred
Fred Tellier
These users thanked the author Fred Tellier for the post: WendyW (Mon Dec 08, 2014 2:11 pm)
PostPosted: Mon Dec 08, 2014 5:30 pm
You can write (or mark) the matt with a pencil - would make it easier to see if using a matt finish.
Never had a problem removing the film and pulling fibres from the wood - it's repositionable sticky stuff, bit like a post-it.
PostPosted: Mon Dec 08, 2014 8:13 pm
City: winnipeg
State: manitoba
Country: canada
We used to use frisket to add a typed bill of materials to a mylar drawing. It saved a lot of lettering in the drafting office, back in the good old days.
Bob :ugeek:
PostPosted: Tue Dec 09, 2014 12:52 pm
It definitely doesn't have enough tack to warrant worrying about pulling up fibers. At least not in my (limited) experience using it. The amount of tack actually seems perfect. Just enough to stay in place and pull up with little effort when the time comes.
I have a template of my bride that I use to cut it. The template is a hair smaller than my actual bridge. Don Williams designed and made it for me. I locate the bridge and lightly trace the template onto the top. Then I plop it down on the film, trace with an exacto, and roll the film on inside the outline.
PostPosted: Tue Dec 09, 2014 1:35 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Wendy, decades ago, I used frisket for all kinds of commercial art jobs. While being cut, it feels different than almost any other material. You don't need much pressure at all. I recommend you practice cutting on some scraps until you develop just the right touch to cut the frisket cleanly without scoring the wood fiber too deeply. The other thing to consider is the tack. The stuff I formerly used was low tack, true, but we often burnished it down to make it stay in place. Then it can have a pretty strong tack. Ergo, practice applying and rubbing it down, too, then cutting and peeling until you have a real good feel for it. Good luck!
Users browsing this forum: No registered users and 39 guests
