It is currently Wed Jul 23, 2025 8:23 pm
 Post subject: 20th Fret width
PostPosted: Sun Nov 16, 2014 10:41 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi, hello, I need help about my 20th fret width
I'm building 34" bass with Precision Bass pickup neck through body, 80%done, but, when I measured nut width 42mm and oops_sign 20th fret width just 52mm (heel) idunno duh
What you think? about 20th fret width just 52mm, is that too narrow? what should I do?
I need your suggestion, thank you so much
herry tze [uncle]
 Post subject: Re: 20th Fret width
PostPosted: Sun Nov 16, 2014 9:54 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Have you glued the neck to the wings yet? You're in better shape than I was on my last bass. Messed up with a router and had to cut out the wings and cut off the FB to get the truss rod out. Made a new neck and did it right the second time. Learned to fasten down a neck template a little better, LOL.
You might split it down the middle and add a 10+mm accent strip. Purpleheart looks cool in a maple neck. Or walnut, mahogany, etc. You will probably have to add a bit more after you get thru sanding, joining, etc.
Neck cut out.
Finishing with new neck.
These users thanked the author JimO for the post: herry tze (Mon Nov 17, 2014 2:27 am)
PostPosted: Mon Nov 17, 2014 2:32 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Neck cut out.
Yes Jim, I ve done glued the neck to the wings. And problema for me the body semi hollow and I ve laminated the back and top too. oops_sign duh
