It is currently Fri Jul 18, 2025 9:05 pm
PostPosted: Thu Nov 24, 2011 12:10 am
First name: Pete
I get asked regularly about this type of headstock on another forum. here's my video on how to execute the slot cutting. Ramping and drilling takes the whole time fram up to 30 minutes with close on 8 minutes of that being very fine hand sanding...
These users thanked the author Pete Howlett for the post: pkdz (Sat Jun 11, 2016 6:47 am)
PostPosted: Thu Nov 24, 2011 9:27 am
Simple, works great. I like it.
PostPosted: Tue Feb 12, 2013 8:41 pm
First name: Larry
Last Name: Hawes
Just built one of these for my slot head design - WORKED ABSOLUTELY BRILLIANTLY!! What a great design and idea. Took me 3 -4 hours without the jig - 5 minutes with the jig. Again, brilliant!!
Thank You and Best To All
PostPosted: Tue Feb 12, 2013 9:25 pm
That's brillant!
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Feb 12, 2013 10:06 pm
First name: Larry
Last Name: Hawes
It took a bit to get it just right with the router pattern offset but once complete it works great. Now I can choose almost any slot head design and have them finished in minutes instead of hours. Sweet, and thanks again to Pete for posting this.
These users thanked the author LarryH for the post: pkdz (Sat Jun 11, 2016 6:47 am)
PostPosted: Wed Feb 13, 2013 6:35 am
Pete,
Many thanks for sharing your jig design. It will save me many tedious hours.
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue May 27, 2014 4:56 pm
the video s gone - bummer!
cheers
charliewood
PostPosted: Wed May 28, 2014 10:56 am
First name: Wendy
Last Name: W
State: Arizona
What happened to the video!!!???
PostPosted: Wed May 28, 2014 1:19 pm
Last Name: Sollod
I want to see the video too, but it's not there...
www.swiftcreekguitars.com
PostPosted: Sat May 31, 2014 10:08 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Pete removed all of his tutorial videos. I think he's either selling them now or offering classes.
PostPosted: Sat May 31, 2014 11:54 pm
Yeah, what a bummer. I wanted to try that one too. Looks like he is offering classes now. I guess, no more milking the cow for free!
PostPosted: Tue Jun 17, 2014 11:02 am
Mabye one of the people who have already seen it .. and preferably built the jig, could illuminate us darkened fumblers...????
Please? Please? Pleeeeeeeaaaase? (obvious Kramer reference there) :)
cheers
charliewired
These users thanked the author charliewood for the post (total 2): Alex Kleon (Tue Jun 17, 2014 3:14 pm) • Doug Balzer (Tue Jun 17, 2014 11:37 am)
PostPosted: Wed Jun 18, 2014 8:15 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
I saw Howlett's video a couple of years ago and this is my adaptation of his routing jig. The dowels are a press fit into the holes so they can be positioned to protrude from both sides of the jig. Disregard the filled in slot on the plywood. False start!
The Martin shaped peg head fits this way.
Grip the side dowels and the peg head in your vise. Rout the slot with a plunge router and a collar.
Tap the dowels through to the other side.
Again clamp the dowels and peg head into your vise. And rout the other slot.
Produces balanced slots.
Remember to drill the side holes for the tuner shafts BEFORE you cut the slots.
These users thanked the author Dan Pennington for the post (total 6): MikeWaz (Sun Nov 08, 2015 1:53 pm) • Pmaj7 (Wed Mar 25, 2015 10:01 pm) • kwerry (Thu Jul 31, 2014 1:32 pm) • Doug Balzer (Fri Jul 25, 2014 9:40 pm) • Colin North (Thu Jul 03, 2014 4:51 am) • Beth Mayer (Wed Jul 02, 2014 5:19 pm)
PostPosted: Wed Mar 25, 2015 8:17 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
Great demo! Thanks for sharing.
Another variation which doesn't depend on the headstock shape:
You would have to lay out and drill holes the diameter of the slots at the end of each slot (another simple jig).
Use the holes on one side to align index pins of same diameter so that you can cut the other side. Then push the dowels to the opposite side, flip and repeat.
You can also add a slot to contour the top of the head and it should be symmetrical by design.
PostPosted: Mon Aug 10, 2015 9:47 pm
Thanks penndan,
thats exactly what I needed to see
cheers cw
